Old 12-19-2004, 10:23 AM   #1
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Default 03 fuel temp sensor? EJ20 Swap code
My only CEL with the 03 EJ20 swap into 99 RS is a fuel temp sensor code. Looks like my car didnt have one.
Any work arounds? (resistor etc...)
Costas is offline   Reply With Quote
Old 12-19-2004, 12:54 PM   #2
AKGC8
Member#: 1305
2000 Impreza
Your car does have a fuel temp sensor. It's a blue/black wire coming off the pump going to pin 26 on connector B136 at the ECU. It's grounded in the rear of the engine bay somewhere. So unless you pulled a lot of the stock vehicle harnesses out the ground should still be good. Mine was in my 99l/02WRX swap and I pulled the entire stock engine wiring harness out of the car.
AKGC8 is offline   Reply With Quote
Old 12-19-2004, 02:27 PM   #3
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Awesome, I have to check it out
Thanks!
Old 12-19-2004, 11:49 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The 2003+ cars actually have an additional solenoid that the older cars don't have. I expect that code will show up. The fuel temp sensor should be there on your car, though.
-Jon
wrx swapping, fuel temp sensor? ToastermonkeyPat Subaru Conversions 6 07-08-2008 04:36 PM
Faking out fuel temp sensor - 03 wrx ecu bryan_johnson Subaru Conversions 4 05-24-2006 06:46 AM
CEL for fuel temp sensor?!? Benjamin Tang Engine Management & Tuning 0 05-22-2004 12:29 AM
P0183 Fuel Temp Sensor A Help Kevin Thomas Normally Aspirated Powertrain 7 11-25-2003 10:26 AM
CEL, Fuel Temp Sensor?? fastsubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-14-2003 04:53 PM
