Old 12-20-2004, 02:54 PM   #1
jasona
Member#: 11786
02 TS
Black on White
Default Please help, no headlights!
1st of all I have some of the cheap "EBay headlights" that have seperate lights for low and high beams. I've had them for a few months with no problems. They came wired wrong from the factory, but once I got that straightened out they worked great. About a week ago my passenger side low beam went out. A few days later my passenger side high beam. Then my driver side low beam. I took the bulbs out and they weren't blown, but I put new ones in just in case and it didn't help. The drivers side low beam was burnt out when I took it out, but it smelled freshly burnt so I think it must have done it when I was messing with it. Anyways, I got the drivers side light to work right when the passenger side was unplugged, low beam on and high beam off when I set it to lows, and vice versa. But when I plug the passenger side in, ALL the lights will stay on all the time, and they're really dim. The Drivers side low and high still get bright when I turned them on, but not the passenger ones, and they shouldn't be on all the time and dim like that. So I swapped the siring around to see if that helped, and apparantly I touched some that shouldn't have, cuz it blew out both of my underhood headlight fuses. I put new fuses on, but now NONE of the lights will turn on at all. There's a loud clicking sound coming from the area of the underhood fuse box, I don't seem to remember it doing that before. The headlight relays are in the fuse box, but I can't tell if that's where the clicking is coming from or not.
Any ideas?
jasona is offline   Reply With Quote
Old 12-20-2004, 03:10 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
You might have blown another fuse in addition to the ones for the headlights. Check the rest of the fuses in the underhood box.
You can probe the connections at the lights with a test light or voltmeter to determine if there is a loss of power, ground or (unlikely) both.
Check the lights themselves for shorts or damage to the harnesses and connectors.
Test all your bulbs with an ohmeter to see if they are really good or not.
Old 12-20-2004, 03:42 PM   #3
satrya
Member#: 5887
2002 GDAA
797
In this instance, do you mean they are all on with the keys in the ignition on position and hand brake released? Could this be a combination between damaged DRL relay and a short in the ground path on the connectors?
I had the brief opportunity to test these WRC-look headlights ( http://forums.nasioc.com/forums/showthread.php?t=609978 ), but didn't get the chance to see how well the wiring lasts over time. I'd be interested if you could share what you could find out about this problem.
satrya is offline   Reply With Quote
Old 12-21-2004, 01:49 PM   #4
jasona
Member#: 11786
02 TS
Black on White
I checked the rest of the fuses in the underhood box and all were good. Test light shows no power at any of the lights. Did I blow my relays?
satrya, I didn't think to test it with just the DRL's, as I was parked in my garage with the handbrake on while I was messing with it, and now I can't cuz it won't work at all.
Old 12-21-2004, 01:59 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
There should be power at the center pin of the headlight connectors, that is the common power. If you don't see power there with the headlight switch fully on, it's either a blown fuse, bad relay, or wiring problem.
Old 12-21-2004, 02:12 PM   #6
jasona
Member#: 11786
02 TS
Black on White
Would blwoing just 1 relay cause both headlights to go out, or would it have to be both?
Old 12-21-2004, 02:36 PM   #7
suby4ub
Member#: 35812
2008 WRX 5 Door
Dark Metallic Gray
never trust lights off ebay, i learned the hard way. besides now they make silverstars for subarus they are costly but worth in imo
suby4ub is offline   Reply With Quote
Old 12-21-2004, 02:38 PM   #8
jasona
Member#: 11786
02 TS
Black on White
Is there any way I can test the relays themselves?
Old 12-21-2004, 04:46 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The relays are independent for each side so for both lights to be out you'd have to blow both of them which is unlikely (but anything is possible). You can try swapping in another relay from a different position in the fuse box, as long as it's an identical one. Just do this temporarily for a test in case it's for something important, don't leave it like that.
Old 12-21-2004, 07:53 PM   #10
jasona
Member#: 11786
02 TS
Black on White
Here's what someone told me to do on a local forum:
"But I would reccomend rewiring your headlights. All you'll need are two relays for each side. Wire the hot side of the relay to a fused terminal on your battery with at least 14 gauge wire. Just find the output voltage to each light after the stock relay, and simply use this wire for the turnon wire for your new relay. That way, your aftermarket bulbs won't draw enough current to burn up the stock wires/relay."
Should I do this?
Old 12-21-2004, 08:07 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Fix your problem with the existing wiring first before you consider any further modifications. Something is wrong with your factory wiring if there is no power to the headlights so you need to deal with that.
Old 12-21-2004, 10:00 PM   #12
jasona
Member#: 11786
02 TS
Black on White
Okay, remember I said I tryed changing some wires around and blew both headlight fuses? Well I put new fuses in but forgot to fix the wiring, so the new ones just blew too. I put the wiring back like it was and put new fuses in and everything is fine now. No idea what caused the problem in the 1st place but it's gone now Thanks for all the help!
Should I consider the mod I posted above or will 2 55w bulbs be fine on the stock wiring?
Old 12-21-2004, 10:01 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
I would say, that if you have it working now put the 55W bulbs in and call it a day. That's stock wattage so the existing wiring is fine.
Old 12-21-2004, 10:03 PM   #14
jasona
Member#: 11786
02 TS
Black on White
Also, I feel like a dumbass for doing this but... when I was swapping other relays in to check I forgot which points I took them out of. I have 2 relays that came out of 3 possible plugs, "Main Fan 1", "Main Fan 2", and "Sub Fan 1". Which 2 of these are supposed to have the relays in them?
Old 12-22-2004, 08:13 AM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Main Fan 1 and Sub Fan 1.
Old 12-22-2004, 12:30 PM   #16
jasona
Member#: 11786
02 TS
Black on White
That's what I thought, thanks!
4eat tranny specialists please HELP! no 3rd or 4th gears please help!!! willyp Transmission (AT/MT) & Driveline 9 10-12-2008 08:59 PM
Please help!! No boost or spool at all!!! Bluwerx1 Factory 2.0L Turbo Powertrain 4 09-16-2006 11:35 PM
PLEASE HELP! No Speed Pulse Signal mzdrati Car Audio, Video & Security 4 12-23-2005 09:00 AM
Please help, one headlight dim, but bulb fine? tooocool49723 Electrical & Lighting 2 02-23-2005 09:43 PM
PLEASE HELP QUICK - headlight problem jpsimon Electrical & Lighting 5 05-10-2004 06:17 AM
Message Board Statistics All times are GMT -4. The time now is 06:32 PM.
