Old 12-20-2004, 06:08 PM   #1
robfuqua
Member#: 39125
2005 STI
A lil' better than stock
Impreza WRX STi What tire pressures are you using on '05 STI?
The book says 36 front and 30 rear, but it also goes into saying that the AWD system (and computers) are very sensitive to tire pressure. THE PROBLEM I'M HAVING IS "BUMP STEER"; CAR GETS ALL SQUIRRELY ON GROOVED OR CROWNED PAVEMENT; TWITCHED LEFT AND RIGHT.
Any help would be appreciated....
Rob (2005 STI, Stock Bridgestones--36psi front, 30 rear IAW Owner's Manual)
robfuqua is offline   Reply With Quote
Old 12-20-2004, 07:05 PM   #2
awilson529
RIP
Member#: 38867
11 Mazda
My STi gets "squirrely" on rutty and grooved pavement also. I think its just something we have to live with. BTW, my allignment is to-spec, I have Falken Azenis tires and a Perrin rear bar.
Adam
awilson529 is offline   Reply With Quote
Old 12-20-2004, 08:42 PM   #3
robfuqua
Member#: 39125
2005 STI
Impreza WRX STi
Thanx, I think I might try fooling-around with the tire psi a little, I'm probably going to drop the car soon onto a set of STI Pinks... I think that'll be my first mod....and maybe it'll help the handling.
Rob
Old 12-20-2004, 08:44 PM   #4
majmun
Member#: 18298
2004 STi
I use the stock settings for every day driving. If I'm going to head up the mountain for some fun, I may increase the pressure a couple of psi. There's been quite a bit of discussion on tire pressures, so do a search to find out all that you'd want to know.
majmun is offline   Reply With Quote
Old 12-20-2004, 09:06 PM   #5
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
The STi tire is a relatively low profile tire. I've been keeping mine around almost 40 psi. That's a bit high, but it also doesn't cause tire wear. BTW, I don't live where it snows, so that isn't a factor for me.
Mika
finnRex is offline   Reply With Quote
Old 12-21-2004, 08:53 AM   #6
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
You have good summer times with low-profile, stiff sidewalls that track with the road. This is normal.
Cabal is offline   Reply With Quote
Old 12-21-2004, 01:33 PM   #7
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
You have a very stiff sidewall ultra performance summer tire (actually a street race tire). You will feel everything on the road so nothing to worry.
For winter, I have switched to P Zero Nero's (245/40/17) and it is a little forgiving but I can still feel the transition, bumps, etc. The twitching will not be fixed by pink springs.
powerslide23 is offline   Reply With Quote
What restrictor pill are you using on your 17psi+ vf34?? WheelsCSM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-09-2007 03:50 AM
what tire pressure are you using? bklynbaja Baja Forum 10 06-08-2006 12:52 AM
what tire pressure is everyone running on stock sti potenza's STI1981 Tire & Wheel 7 08-26-2005 03:31 PM
calling all EJ20 swappers, what boost controllers are you using on your cas? Homemade WRX Subaru Conversions 15 11-27-2003 10:49 AM
What Tire Pressure Are You Using In Your Snows? slowme Brakes, Steering & Suspension 1 11-01-2002 08:42 AM
