Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 12-21-2004, 06:23 PM   #1
turbowrx2004
Member#: 61219
2004 STI
Default headlight condensation
My buddy had hid's put on his 04 rex and one of the headlight gets condensation in one of the headlights. Any way to stop that. When the lights are running it dry's off when shut off then in the morning one headlight is all foggy inside. Any suggestions? Will subaru fix under warrenty?
turbowrx2004 is offline   Reply With Quote
Old 12-21-2004, 06:26 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
He modified his headlights so as soon as the dealer sees that he's on his own. The HID bulb bases probably don't seal correctly in the housings, that's the only place water will get in unless the lights were also opened up to be modded at the same time and not resealed properly.
Old 12-21-2004, 06:45 PM   #3
Sports Wagon
Member#: 43081
There may be trapped moisture in the assy. Have him remove the assy. and put in the dryer for about 2 hours. Use the dryer shoe drying rack so the assy stays put. Just take all the bulbs out while it's in the dryer so it gets dry on the inside.
Sports Wagon is offline   Reply With Quote
Old 12-21-2004, 09:14 PM   #4
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Most aftermarket HID kits for the 2004-2005 require that a hole be drilled in the removable cover on the back of the light. This hole is used to pass the bulb wires through. A rubber grommet goes in the hole, but it usually doesn't seal properly. I ran into the same problem when I installed a Catz HID kit in my 'old' 2004 WRX. I fixed it by drying out the lights with a hairdryer and then installing the grommet using non-corrosive silicone sealer.
However, the real solution is to ditch that sub-par light setup and get the STi HID lights.
jac04 is offline   Reply With Quote
Old 12-22-2004, 09:27 AM   #5
suby4ub
Member#: 35812
2008 WRX 5 Door
Dark Metallic Gray
i have the same problem with my fog lights i think ill just get new ones when i get a new bumper
suby4ub is offline   Reply With Quote
Old 12-22-2004, 09:28 AM   #6
turbowrx2004
Member#: 61219
2004 STI
thanks i will try doing that with him
Headlight condensation OBPNUT Interior & Exterior Modification 3 02-01-2008 12:47 AM
2006 Headlight Condensation Ukezu Interior & Exterior Modification 17 01-10-2007 10:56 PM
headlight condensation turbowrx2004 Warranty Issues & SOA Problems 1 12-22-2004 01:57 PM
Headlights Condensation? Acejam2k Electrical & Lighting 5 11-21-2003 02:34 PM
DIY Headlight condensation? pDXZ Interior & Exterior Modification 2 12-18-2001 06:32 PM
