Old 12-21-2004, 07:07 PM   #1
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Default Question to all those with Modded injectors and cold starting?
If this post ain't in the right place move it but it seemed to be the place to ask others about there modded injectors?
So I have a set of em obviously and I have an auto start in my car, nice thing in the winter I gotta say. So I went to start it yesterday on a like 9 degree morn and the car didn't start
Figured I left it in gear so it doesn't start Go on out and put the key in and it wouldn't start. Just cranked over for a bit. So I floored the gas while cranking it and it finally lit but, man it almost was stalling so I had to keep giving it a bit of throttle till it got a some heat into the heads.
It started this morn but, I heard the engine strugling a bit till it got some heat into the valves at least.
So I'm curious if anyone else has had any experiences now that the cold is here
2002WRXSTi is offline   Reply With Quote
Old 12-21-2004, 09:59 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
can you list more about your mods?
ecu?
ok modded injectors..
fuel pump?
you get it..do you have the supporting mods
to run the injectors correctly?
what type of oil? 5w-30 5w-40 10w-30?
Old 12-21-2004, 10:09 PM   #3
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Yeah sure ...
RA Spec-C
QuickTime Header
FP Green
UTEC
Modded Stockers
Walbro FP
Turbo-XS FMIC
Sunoco 93 380WHP
Forget what oil I have in it but it is a lighter wieght...
There are no tumblers on my engine which may ad a bit to the cold weather suckiness
Runs like crap till there is some heat in the engine tho
Old 12-22-2004, 07:58 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
check your fuel trims with an obd2 scanner.
Old 12-22-2004, 08:38 AM   #5
b0dh1
Member#: 35269
2011 WRX
Hey Tad.
I dont know if it's normal or not but my car runs pretty crappy on cold starts with the modded injectors as well. It starts and it runs but my idle is really wobbly(for lack of a better word).
Before you had this starting problem, how was the start up/idle?
b0dh1 is offline   Reply With Quote
Old 12-22-2004, 08:42 AM   #6
2002WRXSTi
Member#: 58647
02 Exedy Carbon
That is not going to do anything for me. I am trying to see if anyone out there also has modded injectors and what kind of extremely cold start issuse they are having?
I have already richened the idle fuel parameters up when it was done originally. Now that the temps have taken a extreme dive the modded injectors do not atomize the fuel so it is a PITA.
I am starting to think I am the only damn one with modded injectors that actually is daily driving the car
Old 12-22-2004, 08:45 AM   #7
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Originally Posted by b0dh1
Hey Tad.
It was fine, then I went with the 10 pound flywheel settup and it threw some cell's but Junior fixed that pretty much.
Now it's just in the extreme cold it don't want to start and really is crappy untill there is heat in the engine.
Old 12-22-2004, 10:09 AM   #8
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
For what it's worth, I have modded stockers (829cc) and RA-C TGV deletes and the car started right up when we had a couple of single digit/low double digit days and nights.
02R6 is offline   Reply With Quote
Old 12-22-2004, 10:55 AM   #9
2002WRXSTi
Member#: 58647
02 Exedy Carbon
How is it that your modded stockers are 829cc?
I am wondering if I got a bad tank of gas then? It did start this morning but it wasn't as cold as the 9degree's it was the day it gave me problems
Old 12-22-2004, 11:02 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
why are you being ignorant? check the fuel trims.
the car runs OPEN LOOP for a few seconds on startup. why? because the o2 sensor isn't up to temp yet.
during that time, it's using the MAF sensor and the LTFT to run the car. if the LTFT is pegged in either direction, the car runs like poop. as well, most agree that the car runs better with the LTFT pulling fuel instead of adding it... ie LTFT is negative, not positive.
but whatever. you seem to know everything. funny--you're the one whose car doesn't run right.
Old 12-22-2004, 12:13 PM   #11
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
I am having the same problem and my stft stay between -.8 and -1.5 at idle. Odd thing is, my ltft never seem to drop into the negatives.
el~sharko is offline   Reply With Quote
Old 12-22-2004, 12:15 PM   #12
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Ouch, ride5000 is right though. Modded injectors require additional tuning of the 0% column and the use of the coolant temperature compensation feature of the UTEC. A combination of these will produce a car that starts in the morning and runs well at temperature.
To fine tune these things right you have to monitor the Long Term and Short Term fuel trims. This data is the key to tuning for larger injectors. Once you know what they are doing you can modify your map and account for different senarios.
mick_the_ginge is offline   Reply With Quote
Old 12-22-2004, 12:17 PM   #13
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I say between +-7 is pretty good. What is the LT doing?
FYI - Their is another parameter that effects fueling in the ECU that requires an ECU reset to clear (STI only).
Old 12-22-2004, 12:35 PM   #14
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
When I start the car up, the STFT goes right to -.8 for a while. Then the LTFT will start dropping from the +teens and settle around +10ish.
Old 12-22-2004, 12:40 PM   #15
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Sounds fine to me, what does it do when you rev the car up and hold it at selected RPM's?
FYI - As LT is positive the ECU is having to add fuel. UTEC is removing to much fuel which the ECU is putting back. Change the UTEC stock size to be slightly closer to the UTEC injector size. Less difference means less UTEC compensation.
Old 12-22-2004, 12:41 PM   #16
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
I have almost the same set up as you except no lightened flywheel and had my TGV valves removed and the housing ported and sealed up the holes. I also did the FPR mod for more fuel pressure. I have no problems at start up even when the temps dropped to 8 degrees the other night. Do you have a Spec-C ECU? I do, have my injectors set at 550 stock and 800. I can't check my fuel trims because the JDM ECU won’t let you, at least with the normal scan tool. Also with the JDM C ECU you do not need the O2 sensors at all. You can unplug them and car will run perfect, but you will get a cell. You might have to get the JDM STI ECU and hook up the AVCS to fix the problem. Could just be a sticking idle air solenoid when it's freezing outside, clean it.
fatray is offline   Reply With Quote
Old 12-22-2004, 01:29 PM   #17
2002WRXSTi
Member#: 58647
02 Exedy Carbon
That is a slight problem that I have. My ECU is a JDM ECU and I went to Rallispec to have it Ecutek flashed and it is not a supported ECU
Old 12-22-2004, 02:16 PM   #18
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
I'm sorry to kinda hijack this thread, but I've been trying to find a resolution to this problem for months now. Turboxs set my inj. sizes to 520/810, I have taken it back since then(to fix jumpy crossover with no success) and they didn't touch the scaling. When I blip the throttle, it almost stalls out. Is this just something I have to live with? cause no one has been able to shed any light on this. Drivability is horrible w/ the choppy crossover that txs could not fix, I'm debating whether or not to just go back to stock turbo/inj.
Old 12-22-2004, 02:33 PM   #19
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
If you need i have an af481 ecu which is supported. PM me for a price if you might be interested
Soon2Bgreat is offline   Reply With Quote
Old 12-22-2004, 03:19 PM   #20
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Living in the frozen north where it has already been below -10f, 2 cars that I know of are running modded injectors and having NO problems starting.
My STI-UTEC with modded Perrin injectors and no ST LT fuel adjustments, I just punched in 800cc in UTEC and ST LT are good using Delta dash. FWIW no hesitation whatsoever ever.
HOK's car-2.2 rs turbo closed deck running Hydra EMS and modded WRX stock injectors.
Wombat North is offline   Reply With Quote
Old 12-23-2004, 12:57 AM   #21
02R6
Member#: 22157
'02 WRX '04 350Z
Dunno, that's what the printout RC sent back with the injectors said they are flowing.
Also, I haven't dicked around with the fuel trims either. I just told the UTEC what stock is/was and what the modded examples are. Car starts just fine.
question to all those w/ heavy spring setups Penguinking Motorsports 1 05-04-2004 08:37 AM
To all those with Whiteline springs and stock struts on your WRX JLMarx Brakes, Steering & Suspension 2 05-09-2002 10:34 AM
To all those with exhaust modifications, please read. Cosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-27-2002 11:22 AM
To all those with MBC, what do you have and why do you like it drftsub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2001 12:39 AM
to all those with s-tech/kyb agx suspension stimpy Technical Forum Archive 5 06-22-2000 11:49 AM
