Old 12-22-2004, 01:52 PM   #1
sopdadope
Member#: 53437
Default Lights acting funky on my Legacy
Hey guys. I've had my '98 Legacy LS for a year and half now. Ever since I purchased it from the previous owner, I've noticed that the brake lights are always on when I switch the headlights on. Additionally, the hazard lights are always on too, not blinking, but just turned on.
I took a look at the wiring, and it looks like some numbskull disconnected the wires to the brake light on the rear spoiler and wired it up to the high-mount, decklid light instead.
Because of this, my car wouldn't pass a safety inspection so if anyone has any info. to help me out, it'd be greatly appreciated.
sopdadope is offline   Reply With Quote
Old 12-22-2004, 06:10 PM   #2
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
As I recall, there's a relay for those. Maybe your excited-to-rewire numbstick did something that fused it closed.
EDIT: My Haynes book's wiring schematic uses the same symbol for relays as for switches (thanks, guys). However, the one for the brake lights is labelled "STOP/BRAKE SWITCH" while there's other things that are called "(Something) RELAY," so I'm guessing now that there's not a brake light relay.
I am 95% sure, however, that there's also a blinker-element that makes the hazards blink similar to the one that operates the turn signals. Since you mentioned that the hazards are "on all the time," it's possible that the blinker-element fused shut. It happens fairly regularly when they fail as they get pretty hot.
Al_Smokemcrack is offline   Reply With Quote
Old 12-23-2004, 11:35 AM   #3
sopdadope
Member#: 53437
Thanks for the quick response! I'll check it out as soon as the weather permits, and then I'll post a follow-up. Thanks!
fog light wiring problem on 2005 legacy I sedan shadow33 Legacy Forum 0 09-21-2004 04:03 AM
ABS light w/knocking on 95 legacy mrmojorisin Brakes, Steering & Suspension 0 05-17-2004 12:55 AM
Offsets question. What would happen if I used my VW rims on my Legacy ? Legacy Brakes, Steering & Suspension 9 11-10-2001 01:11 AM
G-Tech Pro Result on my Legacy Turbo!! Ben Legacy Forum 1 04-02-2001 09:56 AM
Weird alarm issues on my Legacy wagon. gtguy Legacy Forum 0 08-31-2000 10:19 PM
Message Board Statistics All times are GMT -4. The time now is 03:59 AM.
