Closed Thread
Old 12-22-2004, 05:10 PM   #1
DumbUglyDragon
Member#: 61077
1993 WRX
Default Someone Help! Oil over fill from Jiffylube
Okay, I was in a hurry and decided to have someone else do my oil change this time. I brought the oil (Motul Synthetic 5w-30) and filter. Before I let them start I told them to becareful, the bottles are liters not quarts. Well...shows how bright I was letting someone else work on my suby.... they emptied all 5 bottles into my engine!
So, the question is: How detrimental is overfilling the engine oil to the car?
DumbUglyDragon is offline
Old 12-22-2004, 05:25 PM   #2
DumbUglyDragon
Member#: 61077
1993 WRX
Anyone??
Old 12-22-2004, 05:29 PM   #3
WRXVT
Member#: 17979
335i Blue
check how high it is on the dipstick.... if its too high drain some of the oil. you should be ok if its only a little above the F
WRXVT is offline
Old 12-22-2004, 05:30 PM   #4
WRXVT
Member#: 17979
335i Blue
It can hurt you if its way overfilled. Can cause frothing of the oil-check how high it is on the dipstick.... if its too high drain some of the oil. you should be ok if its only a little above the F
WRXVT is offline
Old 12-22-2004, 05:32 PM   #5
DucatiBoy
Member#: 31904
02 WRX Wagon
Overfill is bad. The oil can foam up starving the oil pump. That's what I have been told not sure if it is a myth or not but others will probably concur. Just open the drain plug a little and let some out. Use a rubber glove to eliminate too much on your hands.
DucatiBoy is offline
Old 12-22-2004, 05:38 PM   #6
DumbUglyDragon
Member#: 61077
1993 WRX
It is full full, above the notch full
Old 12-22-2004, 05:52 PM   #7
spyordie007
Member#: 67276
2008 spec.B
2006 Forester (Grey)
Like was already said if it's only a little bit you're probably going to be okay. But if it's more than a few mm you should pull the plug and drain a little bit of the oil out.
spyordie007 is offline
Old 12-22-2004, 06:06 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
take it back and make them drain some out so you dont get dirty.
dipstick
first hole = low
second hole = full cold
notch = full hot (engine at temp)
jay
munkis is offline
Old 12-22-2004, 06:37 PM   #9
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
You're what, a 1/2 quart too high, maybe a bit less? Not sure what I'd do about it, probably let a little out (easier said than done without making a mess).
But I agree this shouldn't be your problem.
Snowphun is offline
Old 12-22-2004, 06:58 PM   #10
f3rr3t
Member#: 46285
04 wrx/your mom
wrb for both ;)
Jiffy did that to me with my 3000gt
soo much smoke came out my tail pipe
f3rr3t is offline
Old 12-22-2004, 06:58 PM   #11
suby4ub
Member#: 35812
2008 WRX 5 Door
Dark Metallic Gray
gotta love the geniouses(sp) that work at jiffy lube. i went there before i had a suby now that i care about my car i make sure i do my own. even to the point where i would rather change it early to make sure i have the time
suby4ub is offline
Old 12-22-2004, 11:02 PM   #12
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
An easier way than loosening the drain plug is to take off the oil filter, dump out the oil, and put it back on. And never ever go to Jiffy Lube again!
Mike Wevrick is offline
Old 12-23-2004, 02:59 AM   #13
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
You should point out to them that they should not lube up their jiffies while working on cars they don't own; it's bad form and very unprofessional.
Al_Smokemcrack is offline
Old 12-23-2004, 11:00 AM   #14
Virrdog
Member#: 71439
1993 Legacy S.S.
'89 GL 4x4
I heard from a used car lot owner (read... stupid owners) that way overfilling the oil will eventually kill the oil pump. Too much pressure or something.
I third not going to Jiffy Lube... ever. Most dealerships have deals on oil changes, they sometimes try to compete with those quicky places. But they will try to find more things wrong with your car or recommend maintenance. Just tell them your headlight fluid level is fine, you topped it off last month.
Virrdog is offline
Old 07-26-2013, 10:50 PM   #15
Fonic_Artes
Member#: 363485
I can easily tell you're a Rooster Teeth fan by the ending of your comment.
Yeah, I have issues with Jiffy Lube, they seem to have the wrong year and model, so I'm having to go back and get them to drain the quart they overfilled off.
Fonic_Artes is offline
Old 07-26-2013, 10:54 PM   #16
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
I can tell you're new here as you bumped a thread from 2004...
Also, Rooster Teeth FTW.
Loyale93 is offline
Old 07-26-2013, 11:13 PM   #17
bondo007man
Member#: 247030
Stop Looking At Me
Swan
Yeah take the car back...nearly 10 years later lolz
bondo007man is offline
Old 07-26-2013, 11:28 PM   #18
Oni04project
Member#: 193543
2004 WRX (PSM)
2006 Evo9MR (sold)
take them to court!
haha bump for old thread.
Oni04project is offline
Old 07-26-2013, 11:37 PM   #19
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Tape the shop vac hose to the dip stick tube ( with the dip stick removed ) and pull it out that way. If it above the tube bottom it's far too high, if not your fine. You may get a little bit of smoke after a real hard pull but that is all.
Be thankful they gave you more then not enough!!
dangerousatom is offline
Old 07-26-2013, 11:39 PM   #20
anonmassive
Member#: 158464
YER MOM
BLURPLE
DaFAQ?
anonmassive is offline
Old 07-26-2013, 11:42 PM   #21
grizbone
Member#: 360526
2013 WRX Premium
Plasma Blue Pearl
Well now that it's bumped up I want to know if the helpless engine survived.
grizbone is offline
Old 07-27-2013, 01:11 AM   #22
eNx
Member#: 268580
eNx is offline
Old 07-27-2013, 01:51 AM   #23
manualmotive
Member#: 339206
RIP Totalled 13 WRX
White 14 BRZ
Jiffylube? JIFFYLUBE? YOU TOOK YOUR CAR TO JIFFYLUBE?!??!
You sir were asking for it. And yes I am aware this thread is almost 10 years old. Damn, the internet is getting old...
manualmotive is offline
Old 07-27-2013, 02:11 AM   #24
IamGipper
Member#: 318749
2002 Impreza WRX
SRP Stage 2
I'd rather run the oil a little longer than have some goon at a shop change it. Them overfilling it probably caused more harm to the engine than if you would have just ran the old oil and waited to do it yourself.
IamGipper is offline
Old 07-27-2013, 02:42 AM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
we neeed a LOCK up in heer
Uncle Scotty is offline
Closed Thread
Over-filling the engine oil Rabid Dog Service & Maintenance 40 08-17-2013 01:10 PM
Could oil over fill cause knock? Kastley85891 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-23-2008 02:51 AM
Need Help! Oil Return Line From Turbo 84SubaruDL Mid Atlantic Impreza Club -- MAIC 22 08-09-2006 01:11 PM
tranny oil, over filled? subywrxdude Transmission (AT/MT) & Driveline 5 02-28-2006 01:14 PM
over filling oil Jerry Seagreaves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-09-2003 05:27 PM
