Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 12-23-2004, 12:53 PM   #1
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Default The crank pully on my ej22t is "wobbly" WHATS UP??
Today i noticed that the crank pully on my legacy had some play in it while in motion. Whats up with that??
lotus2843 is offline   Reply With Quote
Old 12-23-2004, 01:58 PM   #2
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Maybe try to tighten the bolt...I know of a few instances where the bolt came loose.
maciek is offline   Reply With Quote
Old 12-23-2004, 09:52 PM   #3
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Yes, may have worked itself back. However, some look like they wobble slightly even when the bolt is tight. Brian
bheinz57 is offline   Reply With Quote
Old 12-23-2004, 09:56 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...optical illusion in most cases.....my pulley has looked 'wobbly' for years....
Old 12-24-2004, 03:23 AM   #5
wrxsubaru
Member#: 65133
If its trulley wobley, it broke. Theres a spring mechanism to cusin the blow of the AC on the crank pullie when the AC starts up, and spring can break and make the pullie look wobblie, becasue the pullie is kindof seperating. I would definitley replace it as soon as you can.
wrxsubaru is offline   Reply With Quote
Old 12-24-2004, 01:03 PM   #6
Porter
Member#: 486
2004 Forester XT
bug spattered
There is a keyway in the pulley and a small metal key (tab) that inserts into a slot in the end of the crankshaft. If that slot in the crank is becoming worn, it can cause lots of problems, including random shifts in mechanical timing that can lead to motor failure. Make sure you take it apart and check it.
Alternatively, it may be the rubber layer in the crank pulley... the pulley is actually two pieces, an inner and an outer that are separated by a rubber layer that acts as a harmonic dampener. As the rubber ages sometimes it delaminates from the metal and allows the outer ring to sit crooked on the inner part, causing a wobbling motion. If that is the case you will need to replace it. Having the outer part of the crank pulley come off while driving is not my idea of fun.
Good luck!
Porter is offline   Reply With Quote
Old 12-24-2004, 03:35 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I have one if you need a replacement...
Old 12-24-2004, 05:46 PM   #8
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Im pulling the engine to build and put in my GC8 impreza. i plan to use a billet pully
Old 12-24-2004, 06:25 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you are going to use a 14lb or lighter flywheel, you will want to seriously consider using the stock pulley. Gains with pullies on boosted cars are minimal at best, and if the rotional mass gets too low, the heads can skip teeth on the timing belt among other things...
http://www.spdusa.com/pulley_kit.htm
Old 01-10-2005, 10:07 AM   #10
subarurabbit
Member#: 4083
2011 OB 3.6R
Mine fell off. it sucked.
replaced it as a good chunk of material was missing from original... also got a new sprocket and t-belt while in there.
good luck.
Roger
subarurabbit is offline   Reply With Quote
Old 01-10-2005, 10:45 AM   #11
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
Mine looks like it wobbles too. And i get a kind of skreething annoying noise slighly from the engine bay. I don't know if the belt is worn or what but it only has 50,000 miles on it, i dont know what to do either.
DJ_STI is offline   Reply With Quote
Old 01-10-2005, 11:28 AM   #12
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
i may just go to subaru for it
Old 01-13-2005, 03:07 AM   #13
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
i know that on the 300 zx tt, the crank pulley being loose means crank walk. thats when your crank actually slides over alittle bit, and ****s your motor up. id say look into that too.
jared nelson is offline   Reply With Quote
Old 01-13-2005, 11:39 AM   #14
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Coming from a dsm world i have heard about crank walk a million times, i havnt even touched the car yet. im going to get a socket on it and see if its loose
Old 01-15-2005, 12:30 AM   #15
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I would pull the accessory belts off and remove the crank pulley. You should really check the condition of the woodruff key before you just tighten it and potentially crap it up worse.
Tim Sanderson is offline   Reply With Quote
Old 01-15-2005, 07:58 PM   #16
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Thats pretty high for a belt.
jamesfacts is offline   Reply With Quote
The Security light on my dash is flashing fast MtnXfreeride Car Audio, Video & Security 3 10-26-2009 02:51 PM
Crank Pully (sorry if this is a repost) explicit_03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-13-2009 03:55 PM
I bought the extra insurance on my mazda 6 rental...what should i do kaisersouse Off-Topic 26 06-08-2005 07:39 AM
The security light on my dash is flashing...why?? mgc9876 General Community 10 11-11-2004 03:57 AM
The crank pully is a torsional dampner too. ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 07-20-2003 10:46 PM
