Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-23-2004, 02:15 PM   #1
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Default Where can i get a HIGH ENERGY coil-pack & 10mm wires for my ej22t?
I've always been a fan of strong spark. Id just like to know where i can pick up a nice "strong" coil pack and large spark plug wires i.e. 10mm
Mike
lotus2843 is offline   Reply With Quote
Old 12-23-2004, 03:16 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I don't think anyone makes a drop-in coil/ignitor pack for Subarus like that, but I bet with a little work you could retrofit a GM one pretty easily.
10MM wires would more then likely have to be hand-made.
Old 12-24-2004, 12:28 PM   #3
-k-
Member#: 43881
01 25RS
2.5RS coilpacks are the normal upgrade that I've seen. You could also use a MSD one but I don't know the details on install.
-k- is offline   Reply With Quote
Old 12-24-2004, 08:02 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
http://boxer4racing.com/ has 8.5, I have really large ones with my TEC 3, not sure what size they are. DLC had an MSD coil on his old LT which is now owned by biggreen96.
If you want supper high (almost stupid) amounts of spark then look at a TEC, I think my coils are 66k.
subiekid is offline   Reply With Quote
Old 12-24-2004, 09:48 PM   #5
DamienX
Member#: 66331
If you really like a stronger spark, get the diamond coil packs off of a 2.5 RS and a MSD DIS-2 with some NGK wires
DamienX is offline   Reply With Quote
Old 12-27-2004, 08:07 AM   #6
ncarn8
Member#: 71419
lengething the factory wiring and installing ford(bosch) EE12024 (i think) or Bosch Hec 716 and getting some shortened 10mm leads made up works well, sparks fine up to standard redline, better than factory coil on plug setup. And cost effective as well. This wont provide Hard core spark like MSD et al but if you have an ignition problem it should sort it
ncarn8 is offline   Reply With Quote
Old 01-10-2005, 06:25 PM   #7
TheWicked
Member#: 78258
Jacob's makes a very strong ignition system for tons of cars.
i do have one comment though about the "10mm" wires. the conductor is the same size you know. the rest of the diameter is insulation. bascially you will be fine with an 8 or 8.8. just buy a set of accel universal wires, and make your own. best part is that you can make 2 sets for 50 bucks out of the universal v8 kits. just make sure you get the right ends for your coil.
TheWicked is offline   Reply With Quote
Lost the wiring harness for my stereo, where can I get a new one? oRenj9 Car Audio, Video & Security 5 04-11-2008 12:51 AM
where can i get an ignition module (dis4-03 made by hitachi) for my ej16 spongemjc Private 'Wanted' Classifieds 9 06-17-2006 06:54 PM
where can I get an 18x1.5 bolt or 18x1.5 tap for O2 bung? nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 04-21-2004 08:42 PM
where can i get a cheapest downpipe with flex & uppipe wif flex. wrx2sti Private 'Wanted' Classifieds 2 02-27-2004 05:07 AM
Where can I get a 10mm wrench? codemunky Southern California Impreza Club Forum -- SCIC 5 03-09-2003 03:19 AM
