Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-23-2004, 05:15 PM   #1
ScottC
Member#: 66664
02 BugEye
400plus awhp
Default frount mount on cobb stage 2.5
I have seen some people run bigger tmic on there cobb stage 2.5 settup. I was woundering if anyone has tried to run a fmic with this settup and if so was there any ill effects.
ScottC is offline   Reply With Quote
Old 12-23-2004, 05:27 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes, people have done this. I am not 100% sure if it's 100% safe or not, but there really is no reason to do this. Save your money for something else or just get a bigger top mount as it would be safer/cheaper.
Old 12-23-2004, 07:26 PM   #3
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Another option you have is to keep waiting and waiting for the accessport tuner. And run a front mount than. Who knows when that will be though
Hayaboosted is offline   Reply With Quote
Old 12-23-2004, 10:14 PM   #4
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
currently running it, for about 8k miles now.. Runs great.
03WRX83 is offline   Reply With Quote
Old 12-23-2004, 10:22 PM   #5
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
I am only @ cobb stage 2 currently but I don't see any problems running the front mount . Cobb runs pretty safe ( rich ) maps to begin with . I plan on adding front mount with my turbo upgrade and 2.5 map in the spring and im not too worried about it .
Butt this is my opinion and I am far from an expert !
wrxsubaruwrx is offline   Reply With Quote
Old 12-23-2004, 11:51 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Not that I doubt this or anythign like that, but without the ability to adjust the map to accomodate for a FMIC, running a map designed for a TMIC results in a noticably slower and constipated-feeling car.
Although I don't run Cobb's ecu solution (I have the other reflash), when I went from my TMIC (TurboXS) to a FMIC without any other adjustments, I went from putting down 290 whp on my tuned TMIC map(1820 +other trimmings) to not being able to keep up with a stock Dodge SRT4 at all.
The additional piping throws off both the boost and A/F curve when compared to a TMIC map, and has to be adjusted accordingly to realise the gains. The ecu does do a good job though of keeping things together, but that's about it... Car NEEDED a retune before it would surpass its previous power levels
jigga is offline   Reply With Quote
Old 12-24-2004, 02:36 AM   #7
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
i know one guy here in houston had a 02 wrx cobb 2.5 with a FMIC and it ran lean and fryed his pistons, he ran 12's till it fried though
Twiztidunreal is offline   Reply With Quote
Old 12-24-2004, 04:28 AM   #8
file_id
Member#: 28197
2003 WRX w/ VF34
Even if your car is stock with just a FMIC it will make it run lean unless you have a custom tune with engine management. Wait for the accesstuner or go with any one of the other EMS. Friend with his APS DR500 FMIC, turboback, no engine management had his car dyno'd with a/f readings. It got down to around 8:1 lean.
file_id is offline   Reply With Quote
Old 12-24-2004, 06:00 AM   #9
jugger
Member#: 64228
8:1= lean
jugger is offline   Reply With Quote
Old 12-24-2004, 06:31 AM   #10
file_id
Member#: 28197
2003 WRX w/ VF34
Yeah, I'm smoking crack today. Too tired. I'm off to bed. I'll see if he still has the a/f readings from his dyno sheet.
Old 12-24-2004, 10:34 AM   #11
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
ran lean? lol, i see rich conditions. He must have had something else on it that caused that.
Old 12-24-2004, 09:20 PM   #12
ScottC
Member#: 66664
02 BugEye
400plus awhp
Thanks guys for the info. I still don't know what I am going to do. I have a vf 30 sitting in my garage and I have not had time to pick up the injectors. I did know if I wanted to get a fmic or not. I will be honest I just want it because it just looks real good on a wrx. I already have cobb's stage 2 and ran 13.3 @ 100mph, I am looking to get a 12 sec pass out of the car and then I will be stopping and be doing alot autoxing and roadraceing. But I still might drag every so often. If it will not slow me down I will put it on.
Old 12-24-2004, 11:27 PM   #13
blackie
Member#: 42979
03 wrx
blizzzack stage IV
I wouldnt do that because your adding like 12-15 ft of extra intercooler pipeing, this will throw the mafs of more so than adding a bigger top mount. i added a huge tmic and it worked out just fine, but im sure the front mount will need a custom tune.
blackie is offline   Reply With Quote
Old 12-25-2004, 01:02 PM   #14
jawbrkr
Member#: 37822
2004 Uber Stock WRX
I have used sti injectors for 320 if you want them, with 8k on them.
but on a side note, it'd be awesome if somebody had a cobb 2.5 /w fmic who could get an a/f reading to find out how close the car is running to stoic to determine wether its safe. I mean if it is exactly 12:1 i'd be kind of sketched, if it was something like 10:1 i'd feel better about it.
jawbrkr is offline   Reply With Quote
Old 12-25-2004, 01:12 PM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
As I said before, when I went from upgraded TMIC to a FMIC (dr500), the car went from dropping 290whp to being unable to keep up with a stock SRT4. The car was SLOW, even slower than a stock wrx...... and felt plain uncomfortable with itself (if such a thing was possible).
Old 12-25-2004, 09:21 PM   #16
ScottC
Member#: 66664
02 BugEye
400plus awhp
that sucks. what were you running for engine management, maybe I will just do a big topmount with an ic sprayer.
Old 12-26-2004, 01:15 AM   #17
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
LOL @ all of you.
Old 12-28-2004, 11:12 AM   #18
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I had ECUtek for management... The ECU was able to keep the car running, but that was about it... the power had disappeared completely
When I put a bigger tmic on the car (prior to being tuned for it), I noticed thatthe car had more torque everywhere with it. - More so downlow in the rev range.
A TMIC I feel can go on without much further alterations to the existing map.. But not a FMIC.
Cobb Stage 2.5 (VF34) or Stage 2.0+Meth Injection? hampster AccessPort 2 02-14-2007 04:26 PM
Driving with VF39 on Cobb stage 2.5 map without JDM pinks... gopsu AccessPort 16 08-01-2006 10:50 PM
Will ECU Explorer work on Cobb stage 2.5 car? txl146 AccessPort 3 05-23-2006 05:26 PM
pinging on cobb stage 2.5 WrXwaBBit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-25-2005 02:59 AM
Who has used an MBC to hit target boost on cobbs stage 2.5? blackie Engine Management & Tuning 2 04-01-2005 02:28 PM
