Old 12-24-2004, 10:41 AM   #1
abstractpoetic
Member#: 51560
2008 Impreza
Default Forester oil change- plug torque
Hey everybody;
I have a 2004 Forester X, and I have a question about changing the oil. I've been changing oil regularly with no problems, until it occured to me that I may need to have a specific torque on the drain plug, because of the crush washer. Does anyone know of a spec on this? Or am I just being way too over-careful (cough*anal*cough) on this?
Thanks; -Ed.
abstractpoetic is offline   Reply With Quote
Old 12-24-2004, 02:15 PM   #2
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
Well, the WRX one is 33 lb/ft, iirc.
realwomble is offline   Reply With Quote
Old 12-25-2004, 08:12 PM   #3
Hayes
Member#: 11808
My 2000 Forester is 33 ft/lbs. I use a new crush washer and when I feel the crush washer crush to snug I give it about another /14 turn. Never a leak in 80,000 miles
Hayes is offline   Reply With Quote
Old 01-02-2005, 09:55 AM   #4
abstractpoetic
Member#: 51560
2008 Impreza
Thanks for the replies.
33 it is! I did so, and everything looks good.
HOWEVER, I did notice a problem with the application of the new crush washer. When you place it on the plug, there is a tiny bit of play. I had a waher on for a couple hours and had the smallest leak-- when inspecting the crush of that washer, I noticed that it was off center a bit-- so much so, that the 'crush marks' went right up to the edge of the washer, which would possibly cause the drop-or-two leak that I was having. So, I applied some grease on the plug to keep the washer in place when tightening it (to 33, of course), and we're in business. So, for next time:
- lightly grease the plug to keep the washer in place (just where the washer sits)
- torque to 33.
Thanks! -Ed.
Old 01-02-2005, 02:44 PM   #5
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
I installed a Fumoto drain plug so that now I don't need to worry about drain plug torque anymore.
drees is offline   Reply With Quote
Old 01-04-2005, 11:12 AM   #6
Hayes
Member#: 11808
Fumoto drain plugs are nice but::: to drain ALL the oil you need to pull the Fumoto valve OR modify it for your car by filing a grove in it so all the oil drains.
Old 01-04-2005, 11:24 AM   #7
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Or...just cut off half the threads before you install it.
OneOBS is offline   Reply With Quote
Oil drain plug torque numbers?? nuggetWRX Normally Aspirated Powertrain 18 06-25-2008 12:59 PM
2005 WRX Oil Drain plug Torque specs? ragejed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-21-2005 01:16 AM
Oil Drain Plug Torque Specification? toobee1 Service & Maintenance 3 06-08-2004 02:20 AM
oil drain plug torque mmms Service & Maintenance 2 06-23-2003 10:50 PM
Oil drain plug torque Sea Dragon Rex Service & Maintenance 6 05-30-2002 03:01 AM
