Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 12-25-2004, 10:48 AM   #1
RS25Tuner
Member#: 59920
2004 STI
Question 03 WRX and Valentine One = Weird Problem
Here is my problem. You mix a 2003 WRX and a Valentine One together and I get a LASER alert every time I accelerate hard. Once I am at speed the LASER alert stops and I am fine again until I accelerate hard again. I have looked the car over inside and out and I cant seem to find anything that could emit light that would cause a false alarm. Has anyone else with a Valentine and a WRX had this problem? Would anyone happen to know what may be causing this false alarms?
RS25Tuner is offline   Reply With Quote
Old 12-25-2004, 10:50 AM   #2
ms3p
Member#: 51596
2007 G35S 6MT
2006 SV650S blue hotness
That does sound very weird. Try changing the location of the V1 and see if it happens again.
ms3p is offline   Reply With Quote
Old 12-25-2004, 11:11 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Interesting, another post about this just yesterday-
http://forums.nasioc.com/forums/showthread.php?t=687619
It's actually a long-known issue with some older V1's, there is an updated power adapter that solves the problem. Contact Valentine and they should send you a new adapter. If your unit is brand new then this is unusual, the newer ones aren't supposed to have that problem.
Old 12-25-2004, 02:53 PM   #4
RS25Tuner
Member#: 59920
2004 STI
Yes - my unit is about 5 or 6 years old. I will contact Valentine tomorrow and see if I can get this problem resolved.
Thanks for everyones input so far!
Old 12-25-2004, 02:55 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't think they'll be there on a Sunday, try Monday.
Old 12-25-2004, 04:26 PM   #6
ardinos
Member#: 61590
2005 WRX STI
Grey
I sometimes had the same problem, for me in my 2005 sti it happens when I adjust the HID beams up or down currently. The laser goes off until the lights stop moving. Strange. In my 2002 WRX it would happen about 5% of the time, I'd start the car and drive, then when accelerating hard it would go off. Shut down the car, start it back up, the problem would go away.
ardinos is offline   Reply With Quote
Old 12-25-2004, 07:24 PM   #7
e28fixer
Member#: 25037
Another problem but mine is with a Bel 985...
My detector is hard-wired and comes on when I start the car. 90% of the time it will give a major X-band false alarm 2-3 minutes after startup. If I simply turn the detector on manually I never get the false alarm. Very weird.
Scott
e28fixer is offline   Reply With Quote
Old 12-30-2004, 07:02 PM   #8
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
My V1 had the problem when I first wired it in to the cigarette lighter circuit. I moved to another, unswitched, hot source on the back of the relay stack and no more problem. Unfortunately I forget at the moment which connection I tapped...
(And yes, mine's an older one: 1st gen w/ laser.)
GravelRash is offline   Reply With Quote
Old 12-31-2004, 01:06 AM   #9
RS25Tuner
Member#: 59920
2004 STI
If you remember which one it is, please let me know.
FS: (WI) 2005 sti v2 cobb ap and Valentine One stirider Engine/Power/Exhaust 7 06-20-2009 11:40 PM
Subaru Bucks and Valentine one njskatchmo Accessories & Misc 10 01-05-2009 04:07 PM
WTB TEIN FLEX /W EDFC and VALENTINE ONE dewmudgeon Private 'Wanted' Classifieds 9 12-24-2008 06:31 PM
Installed HID Kit on 08 WRX and have one problem - Help! aoisubaru Electrical & Lighting 14 09-24-2008 08:26 AM
VF39 and STi Fuel pump into 03 WRX.. bolt right up or problems? Dakken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-18-2005 01:09 PM
