Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-25-2004, 05:58 PM   #1
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
Default 2005 OEM foglight bulb information
i just finished replacing my H3 foglight bulbs on my wrx. the procedure to replace them is pretty straight forward but i encountered some difficulty.
1. the two rivet clips holding the splash guards (on either side) were very difficult to remove for the first time. removing the center-piece of the rivet would always take up the base too. you have to pull out the rivet ~0.5cm to remove the whole clip. (i used a flat-head, 4 clips total for both sides)
2. the passenger side foglight bulb is difficult to access if you still have the oem airbox/snorkel installed. i removed the stock bulb pretty easily...it's getting the new bulb installed, that is a challenge because of the room limitation...small mirror and good lighting helped.
FYI:
1. you need H3 bulbs with a male quick-disconnect end (the flat square one)...i bought some with a pin terminals and had to re-crimp.
2. the stock bulbs are 55w german-made osram units
kennyvb is offline   Reply With Quote
FS : 2005 OEM STi struts w/ springs & 2006 OEM STi struts w/ springs Chris G. MAIC Private Classifieds 13 06-24-2010 03:38 PM
02/03 Oem Foglights Yellow rockblocker & bulb the real suby dude Exterior/Styling 16 02-15-2009 07:32 PM
FS: 2004-2005 OEM Foglight Covers (Aspen White) WRXwagon04 SCIC Private Classifieds 5 01-16-2007 12:52 PM
2005 wrx wagon headlight and foglight bulb sizes. tacomaprime Electrical & Lighting 3 12-05-2005 06:53 PM
2004-2005 WRX Headlight and Foglight Bulbs Killian Maynard Electrical & Lighting 1 12-24-2004 08:32 AM
