Old 12-26-2004, 02:08 PM   #1
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
Default TT Boost Read / vacuum host
TT is electrical but.. tapping in for boost is more of an engine thing.. but this is for an electrical device afterall.. so my question is where is the vacuum located. i see a tube consist of 2 tubes, connected by a two way conjuntion and then its connected to another tube with a three way conjunction. i'm not sure if that is the tube to pull apart and for me to insert the three way conjunction provided by blitz.. any remarks?
hey1 is offline   Reply With Quote
Old 12-26-2004, 02:13 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
For a boost gauge or other measuring device you need to tap a direct manifold connection. The easiest one to use is the vacuum line to the factory bypass valve on the intercooler. That is where the optional Subaru boost gauge gets connected, as well as most aftermarket ones.
Old 12-28-2004, 04:47 AM   #3
file_id
Member#: 28197
2003 WRX w/ VF34
Let me know if you need any help hey1. I'd be willing to guide ya thru it. But yah like Mulder says the location is correct to tap the boost gauge and you run the line to the rubber grommet thru the firewall.
file_id is offline   Reply With Quote
How to read vacuum on Digital Gauge kfckrew Electrical & Lighting 5 05-12-2010 11:45 PM
prosport boost gauge not reading vacuum dirtbikeridr12 Electrical & Lighting 4 10-23-2009 06:22 PM
FT: Blitz TT/Boost gauge for Boost Gauge Bobalouy Interior/Dressup/Audio & Security 0 02-26-2008 05:47 PM
Reading vacuum in 1st PS_REX Newbies & FAQs 6 05-20-2007 12:19 PM
Manual Boost Controller - Factory Boost Selenoid vacuum line. skimobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-30-2005 10:51 PM
