Old 12-26-2004, 09:55 PM   #1
tpmann
Member#: 73935
03 WRX, s13 sil80
Midnight Blue
Default need electrical help bad
okay ive been trying to wire up an omori electric boost gauge all day and im frustrated i hate when i cant figure something out...im trying to wire it using the fuses behind the change holder...i tapped the number 4 fuse for gauge power which is the fuse for the cigarette lighter and i tapped the number 12 fuse for illumination which is the lighting controls for the headlights and what happens is when i start it up the gauge reads right but doesnt illuminate then when i turn my headlights on it acts as if its off it has no reading at all and still no illumination...so obviously im doing something wrong but its frustrating me cuz im really close to getting it working anyway any help would be greatly appreciated thanks
Tyler
tpmann is offline   Reply With Quote
Old 12-26-2004, 11:19 PM   #2
tpmann
Member#: 73935
03 WRX, s13 sil80
Midnight Blue
bump
Old 12-27-2004, 12:19 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Well - I can't help you with the fuse box, as I didn't dig in there (best to consult a wiring diagram before you connect in there) - I grabbed everything off of the clock harness (the back of the clock is even labelled) - everything you need is there - ground, switched +12v, and the +12v lead of the illumination circuit (Subaru uses a variable ground for the illumination system) - that's how I wired in my Omori electronic boost gauge - just used taps on those three leads.
Old 12-27-2004, 12:24 AM   #4
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
Question
Sounds like not enough ground, I would run the illumination and power circuit together on a key switched power source if that is possible. Is it led or lcd?
Idahoser is offline   Reply With Quote
Old 12-27-2004, 01:10 AM   #5
atomicapples
Member#: 12626
02 2.5 rs
this may sound crazy but, i wired my guages to my alarm... all the wires are mapped out
atomicapples is offline   Reply With Quote
Old 12-27-2004, 02:10 AM   #6
tpmann
Member#: 73935
03 WRX, s13 sil80
Midnight Blue
Yeah it was not enough ground...i had grounded it to a spot where there was paint and didnt realize that would mess up the circuit...i moved the grounds and it works perfectly now but thanks for your help
Tyler
Need Electrical Help! Koji North West Impreza Club Forum -- NWIC 19 10-23-2008 01:28 PM
Legacy owners: need electrical help ScubaruImpreza05 Legacy Forum 14 01-04-2007 07:53 PM
i really need electrical help subyrally Mid Atlantic Impreza Club -- MAIC 0 08-24-2004 12:51 AM
I need electrical help for ceiling fan light Eggroll Off-Topic 4 07-27-2004 09:59 PM
Need Electrical Help skullguy North West Impreza Club Forum -- NWIC 10 11-09-2002 01:40 PM
