Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 12-27-2004, 07:03 PM   #1
kendo
Member#: 24829
2000 Forester S 4EAT
Default Instruction to fix a broken Forester overhead clock problem
I was checking my wheel bearing issues and come across this excellent post.
Figure some other Forester owner will want to know.
Sympton: Forester overhead clock stop working.
Problem and Fix: There is one resister(R510) on the clock's
surface mount is badly manufactured and come loose on the inner side.
Just solder it back.
Credit: To reader TTL on subaru forester forum.
Here is the original post I read with picture of the problem in the middle.
http://www.subaruforester.com/viewto...forester+clock
-Kendo.
kendo is offline   Reply With Quote
Old 01-01-2005, 01:19 PM   #2
Wild Bill
Member#: 78549
Kendo- Thanks man for posting this! I knew it was an intermitant connection somewhere and had hit all the terminal joints without success. Just about to give up when I saw this and Low and Behold... R510 was the cause! Fixed in less than 5 min. Thanks again, the Forester clock was driving my nuts! - Wild Bill
Wild Bill is offline   Reply With Quote
Old 01-31-2005, 03:00 AM   #3
paxsys
Member#: 80635
Default Timely Post!
My clock went out about 4 months ago. After checking the fuse and the voltage with a meter (12V was getting to it and through it), I was just about to give up on it and by a new one for $42.00. Gave it one more search and found yours. Sure enough the solder joint on the R510 was no longer connected!!!
This is obviously a defect and should have been a recall/warranty item. Thanks for saving me $42.
paxsys is offline   Reply With Quote
Old 07-28-2005, 10:24 PM   #4
tagvestibule
Member#: 71103
This is so cool! Thanks! I would have never thought to check the resistors. Sure enough, R510 was the culprit. The whole thing took me 15 minutes (5 of it trying to find my soldering iron). A note to anyone attempting this- when pullling apart the clock, the buttons (for setting time, etc.) tend to fall out all over the place, so be careful.
tagvestibule is offline   Reply With Quote
Old 07-28-2005, 11:22 PM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Just an FYI, it is not always the connection that is bad. I see more burnt out displays than broken connections.
WTB: Button for overhead clock 98-01 Forester/Legacy/Impreza BossGVR4 Private 'Wanted' Classifieds 2 06-02-2005 09:06 AM
1999 Forester overhead clock removal tcmo Interior & Exterior Modification 2 04-17-2005 12:28 PM
OVERHEAD CLOCK in 1998 Forester -- how to fix it? PeterPatnter Interior & Exterior Modification 4 01-30-2005 09:28 AM
How to fix a broken timing belt engine? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2003 11:30 AM
