Old 12-27-2004, 07:32 PM   #1
austenf740
Member#: 21519
02 WRB WRX
98 RS
Default speedometer not working
I recently had to get behind my cluster to remove some wires from a gauge and them i turned the car on the low fuel light was on and the speedometer did not work. I messed around with the wires a bit then and then the low fuel light went off but the speedometer still does not work. Does anyone know what wires i should be looking at or where else i could look to solve the problem?
austenf740 is offline   Reply With Quote
Old 12-27-2004, 08:35 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
That's a tough question.The speed wire itself (as well as the tach wire) is located on the smallest of the three connectors a 10 pin connector.I would disconnect it and snap it in again. However i think the speedometer is also influenced by the cruise control circuit. If i recall correctly haing a blown fuse in the cruise control stopped the speedometer from working. Because those gauges work off a circuit board other things could cause it not to work Hopefully it something simple.
brunetmj is offline   Reply With Quote
Old 12-27-2004, 10:18 PM   #3
austenf740
Member#: 21519
02 WRB WRX
98 RS
I looked at the fuse and they were all good but it was night so ill check again later. Which small connector is it the left or the right? When i tried to adjust the small ones the low fuel light went away so im assuming that more adjusting or checking of the wires would solve the speedometer too since it happened at the same time. Does anyone know what wire exactly to look at?
Old 12-28-2004, 09:04 PM   #4
brunetmj
Member#: 8023
2004 2.5 RS
see this thread for the speed wire and it's connector.
http://forums.nasioc.com/forums/showthread.php?t=472333
Old 01-01-2005, 04:49 PM   #5
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Are you sure that it is properly connected - no bent pins, no swapped harnesses, completely plugged in?
Trunk_Monkey is offline   Reply With Quote
Old 01-02-2005, 03:46 AM   #6
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
No Speedo means No miles put on your car
darksands is offline   Reply With Quote
Old 01-02-2005, 01:02 PM   #7
austenf740
Member#: 21519
02 WRB WRX
98 RS
Thanks for all the help but i got it to work again. One of the pins must have just not been contacting properly.
Speedometer not working contretemps Outback Forum 1 05-22-2006 09:06 PM
Speedometer Not Working byronchaudoin Transmission (AT/MT) & Driveline 11 01-21-2006 07:16 PM
Speedometer not working (Legacy '96 2.0 Auto FWD) itzik93 Service & Maintenance 11 07-21-2005 04:20 PM
Speedometer Not Working bradandrose Electrical & Lighting 5 05-27-2004 03:21 PM
WRX conversion done but speedometer not working! subispeed Subaru Conversions 8 04-21-2003 06:32 PM
Message Board Statistics All times are GMT -4. The time now is 06:12 PM.
