Old 12-28-2004, 02:57 AM   #1
SRpoweredS14
Member#: 33135
Default Megan Racing oil pressure gauge install
Anyone install a Megan Racing oil pressure gauge before? We just unscrewed the stock oil pressure sensor and put in the MR sending unit. Then wired up the gauge. Red to 12v ignition, black to ground, purple to ground and orange directly to the sending unit. The gauge lights up fine, but the reading is wack. It jumps around when we hit the headlights and also sits at 0 and fluctuates around. Did we wire it wrong? On the instructions it says to hook the gauge up to ground on the sending unit... but there's nothing on the unit to ground. Can anyone help? Thanks
SRpoweredS14 is offline   Reply With Quote
Old 12-28-2004, 10:55 AM   #2
satrya
Member#: 5887
2002 GDAA
797
Without access to the datasheet of the components (which I doubt is provided to the end user), it's hard to say what the exact cause could be. I'm a bit familiar with industrial pressure measurement equipments, and I imagine the same technology is used for automotive pressure gauges. Having said that, afaik, most pressure gauges use one of 3 types of transducer (commonly called "sender" here), and then wired into a Wheatstone bridge configuration, which requires power and ground connections.
Different types of transducers also have different levels of susceptibility to noise and power source voltage fluctuations. Within each type, there are different quality grades in terms of reading accuracy. Those with a higher susceptibility to voltage fluctuations will exhibit fluctuating readout as the voltage source varies. In the presence of other electrical components, the "+12V" source fluctuates somewhat.
There are 2 possibilities I could think of for the moment:
(1) There may be intermittent connection problem, introducing intermittent readout error. In this case, re inspecting the wiring should solve the problem.
(2) The quality (in terms of sensitivity to noise and voltage source fluctuations) and type of the transducer is such that whatever voltage fluctuation that exists in your vehicle, either due to the standard components or additional electronics, creates the fluctuations in your reading. In this case, replacement of the sender with a compatible one (in terms of the output range) and of a better quality should resolve the issue. But I wouldn't recommend trying other senders unless you know it is a compatible type.
Perhaps you could get better luck if you ask the manufacturer.
satrya is offline   Reply With Quote
FS: New ProSport EGT gauge & 'New' Megan Racing Oil Pressure gauge CasopoliS Interior/Dressup/Audio & Security 4 03-16-2007 04:25 PM
Oil Pressure Gauge Install - Results inside WRX Power Factory 2.0L Turbo Powertrain 8 06-04-2002 09:59 PM
Oil Pressure Gauge Install aov Factory 2.0L Turbo Powertrain 3 11-21-2001 07:58 AM
Completed Greddy oil pressure gauge install! Force[FED] Factory 2.0L Turbo Powertrain 22 09-28-2001 10:14 AM
('93-'01) HEELPPP!!! Oil Pressure gauge install.... T-WReX 2.5RS Impreza Forum 2 05-07-2001 05:06 PM
Message Board Statistics All times are GMT -4. The time now is 07:57 AM.
