Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Old 12-28-2004, 11:54 AM   #1
gr8wheels
Vendor
Vendor Sales Rating: (0)
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
Default JDM STi 5 Speed's DCCD & Non-DCCD & Tiptronic
We Include Everything to make your swap as simple as possible, NO ONE includes more!
PRICES LOWERED!!!!
~Version 5 Impreza WRX STi 5 Speed STi hardend gear transmission handle 300+Hp, Linkage, crossmember, driveshaft, R160 Diff, & 4 CV Axles. Low Miles! $2500.00
Also:
~1995 Version 2 WRX STi Type RA 5 speed hardend gear DCCD Transmission, DCCD ECU, DCCD roller knob, Linkage, driveshaft, Rear Lsd Diff, 4 Cv Axles, tranny crossmember. Between 45k miles. $3000.00
Also:
2002 LEGACY B4 RSK Tiptronic Automatic Transmission, Driveshaft, rear diff, $1500.00
More detailed facts from our friends at Ravensblade (click here)
Dont forget to check: http://www.gr8wheels.com/Forsale.html
Thanks, Jon
Gr8wheels.com
480 560 3488
gr8wheels is offline   Reply With Quote
Old 12-29-2004, 02:21 AM   #2
GTScoob
Member Sales Rating: (9)
Member#: 68602
02 STi Wagon
Will the axles be the correct width to fit an 02 wagon?
GTScoob is offline   Reply With Quote
Old 12-29-2004, 03:10 PM   #3
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
I believe so becaue GC's share other suspension components with GD Wagons, I think they are the same.
Old 12-30-2004, 11:01 AM   #4
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
Call us anytime 480 560 3488
Jon
Old 01-02-2005, 10:35 PM   #5
GTScoob
Member#: 68602
02 STi Wagon
Will you be in tomorrow morning/afternoon?
Old 01-03-2005, 11:53 AM   #6
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
We are In right NOW!
Old 01-03-2005, 10:48 PM   #7
blueribbon
Member Sales Rating: (2)
Member#: 22668
2006 AE86 Levin it
NA1
will the ver 5 tranny fit directly with a 2002 wrx sedan?
What is the difference between this tranny and the v6 gears?
Mike
blueribbon is offline   Reply With Quote
Old 01-04-2005, 11:15 AM   #8
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
Mike
Yes it will bolt right up!
From what I know they are the same internaly....possibly different ratios...
Old 01-04-2005, 12:55 PM   #9
TrizzyDizzy
Member Sales Rating: (3)
Member#: 45256
2002 Aspen WRX Wagon
04 STi Conversion
OMG! i iwhs i had the money for this. Its soo much easier it looks to do than puttin the gears in your existing box! How hard to get the DCCD to work?
TrizzyDizzy is offline   Reply With Quote
Old 01-05-2005, 01:01 PM   #10
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
yes its much easier to swap a box than to replace gears, and its sometimes cheaper this way too! Buy donor box 1000+ gears 1500+ labor 800+ installation into car 1000 your at & $4300! its cheaper to just replace the whole tranny! with us!!
The dccd can be wired in since we include so much more than other people it makes it easier to get that wired up.
Old 01-06-2005, 03:38 PM   #11
beecha91
Member Sales Rating: (16)
Member#: 55009
Still have the version 5 trans and etc? Also which would be better for higher hp the version 2 or version 5 and how low is low miles on the version 5? Thanx a lot
Don-
beecha91 is offline   Reply With Quote
Old 01-06-2005, 06:41 PM   #12
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
The version 5 is the best choice for your 02-03 WRX
Kevin
Old 01-09-2005, 02:38 AM   #13
beecha91
Member#: 55009
Any details on the front and center diff's? Also how low is low miles?? thanx
Don
Old 01-10-2005, 12:51 PM   #14
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
what kind of details are you looking for?, miles are under 40-45k on all above
Old 01-11-2005, 11:44 AM   #15
GTScoob
Member#: 68602
02 STi Wagon
Is the ver5 transmission and all still available?
Old 01-11-2005, 12:32 PM   #16
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
Yes it is call me
Jon
480 560 3488
Old 01-16-2005, 01:33 PM   #17
THAWA
Member Sales Rating: (15)
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Can you tell me more about the RSK trans, is it a VTD? Does it come with a TCU and wiring? What are the gear ratio's and what is the final drive? How is the "Tiptronic" set up? Does it use the same style as the 03-04 legacy/baja shifter or does it have steering wheel mounted buttons? Will it come with that?
THAWA is offline   Reply With Quote
Old 01-17-2005, 11:42 AM   #18
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
Thats a hole lot of questions!
Yes it has the steering wheel shifter and the wheel is included, you can also shift via shift lever if you slide it over.
Whats VTD? we should have the TCU and we have the Wiring cause its still in the car! Here is the Tranny code I dont know what the ratios are: TV1B4YBDAB
Jon
480 560 3488
Old 01-17-2005, 07:32 PM   #19
THAWA
Member#: 44581
3 Boxers 2 AWD
Heh, I like to be thorough . How is/was the fluid in the tranny? Will it come with the wiring fully uncut from tcu to trans? How much is shipping looking like to 95841? Is it coming with the panel surrounding the shifter aswell? What's the mileage on it? What about the crossmember? Torque converter? Shift cable from shift lever to trans? Is the rear a r160 or r180? Does the steering wheel come with the boss and all related wiring (buttons, cruise, airbag, etc)? Do you have a picture of everything that it comes with? Does the owners manual say anyting about the ratios (assuming it has one)?
Old 01-18-2005, 10:50 AM   #20
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
please call.
Jon
480 560 3488
Old 01-18-2005, 04:04 PM   #21
THAWA
Member#: 44581
3 Boxers 2 AWD
Do you have a toll free number? Or should we just discuss this in e-mail?
Old 01-28-2005, 03:28 PM   #22
Hyper
Member Sales Rating: (29)
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
question on B4 tranny
-bolt on swap from 4EAT?
-how much power can it hold
-comes with TCU/how does it work (ie in terms of distribution between front and rear wheels)
Hyper is online now   Reply With Quote
Old 01-28-2005, 03:46 PM   #23
IDAFC21
Member#: 60471
2004 GTO
QSM
good lord why didnt i see this when i blew 2nd gear on new years eve
IDAFC21 is offline   Reply With Quote
Old 02-07-2005, 08:28 PM   #24
GTScoob
Member#: 68602
02 STi Wagon
Jon,
The transmission got in today up at Subaru of Gwinnett and I'm going by tomorrow to check it all out.
Thanks for all the help.
Old 02-07-2005, 08:43 PM   #25
Homemade WRX
Member Sales Rating: (7)
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you told me to check back in feb about radiators...do you have any in?
thanks, Micah
also quite interested in the ver 2 RA tranny, being my second gear syncros are dieing
are you sure you read the tranny code correctly...TV1B4YBDAB...because I can't find anything on it
DCCD vs non-DCCD tranny milcic07 Transmission (AT/MT) & Driveline 11 03-20-2008 09:51 PM
DCCD and NON DCCD, How to recognise? adofly Transmission (AT/MT) & Driveline 5 11-28-2007 09:37 AM
dccd to non dccd center diff mcu81 Transmission (AT/MT) & Driveline 6 08-30-2006 09:09 PM
jdm sti ver5-6 cluster pinout for dccd? ImprezaRSfan! Subaru Conversions 11 03-05-2006 11:39 PM
STI VER 8 gauge cluster non DCCD and other parts... 996Cabby Private 'For Sale' Classifieds 3 02-18-2004 10:26 AM
Message Board Statistics All times are GMT -4. The time now is 07:47 AM.
