Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 12-28-2004, 01:45 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default Please help, how do you get rid of moisture in the car?
I dunno what the deal is, but every morning on my trip into work my windows are so foggy I have moisture running down them by the end of my trip. At night there's ice on the INSIDES of the each window!!!
Not only is it annoying, it's dangerous, I cannot see out of my side windows and I have to cross left across 4 lanes of traffic to get to the exit I need
Please help, I've tried just about everything and no improvement has been made!
Bry.
BrysImpreza is offline   Reply With Quote
Old 12-28-2004, 02:14 PM   #2
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Might want to try leaving a couple small boxes of baking soda under your seats. Might help
audio1der is offline   Reply With Quote
Old 12-28-2004, 02:38 PM   #3
Malik
Member#: 29272
2002 WRX Wagon
Run the AC before you park the car and run it in the morning to deal with the moisture. Don't recirc your air - have it vent and open a rear window. This works here when the temperature drops and the humidity levels are high.
Good luck.
Malik
Malik is offline   Reply With Quote
Old 12-28-2004, 02:43 PM   #4
WRXplatinum
Member#: 75660
USMC
Viva La Resistance!
Dehumidifier (sp)?
WRXplatinum is offline   Reply With Quote
Old 12-28-2004, 03:00 PM   #5
cboggess
Member#: 30804
87 Yugo
Red
Get a length of nylon tube (like panty hose) or an old tube sock, fill it with that special crystal cat litter (it's just silica gel), tie off the end and throw it under the seat. It will absorb moisture. To "recharge" it stick it in the over at 200-250 for about an hour each week. when you drive the car turn the A/C on as it will act like a humidifier, but leave the vent to get outside air, not recirculation.
cboggess is offline   Reply With Quote
Old 12-28-2004, 03:30 PM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
This sounds like a home-made version of DampRid. You could try that or you could go down to Lowe's/Home Depot and get some DampRid.
http://www.damprid.com/
Either way start by seeing if you have any leaks (like in the trunk). The trunk on my Civic was leaking and I ignored it for way too long. After a few months of foggy windows, the musty smell started and I had to do something. Since I waited so long, I found at least a gallon of water in my spare tire well. I had to clean that out before even bothering with something that would pull the moisture out of the air.
offset
offset is offline   Reply With Quote
Old 12-28-2004, 05:22 PM   #7
joey1313
Member#: 53839
2005 STi, 06 S2K
Take offsets advice and look for a leak.
joey1313 is offline   Reply With Quote
Old 12-29-2004, 12:35 AM   #8
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
Try turning Recirculate off when the defroster is turned on. (If you haven't done this already).
Jonnyfilmboy is offline   Reply With Quote
Old 12-29-2004, 01:06 AM   #9
aznatama
Member#: 60316
2004 STi
if it fogs up during your drive, it's most likely a combination of your own personal water vapors and moisture in the air.
running either the AC (the evaporator dries up the air) or running the heater to prevent condensation... and yeah, no recirculation.
aznatama is offline   Reply With Quote
Old 12-29-2004, 11:32 AM   #10
FIREX
Member#: 13479
2002 WRX SEDAN
SILVER
Put a couple of boxes of uncle ben rice under your seat, no kidding, you ever seen restaurants put rice in their salt shakers to absorb moisture.
FIREX is offline   Reply With Quote
Old 12-29-2004, 11:34 AM   #11
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
clean and dry all windows
drive with your ac on
adjust the heat for comfort
this should cure the fogginess
jamie <----AC on 365 days a year
www.subiegal.com
Old 12-30-2004, 04:08 AM   #12
Rev
Member#: 9681
2010 Outback 2.5L
The reason for all the fog in the subarus is that the ac compressor comes on when the defroster is turned on. The condensor located under the dash acumulates all the moisture in the car when the ac is on. However when the ac cycles off or you manualy turn the defrost off the moistue on the condensor gets heated by the heater core and is vapoized right back in to the car.
Having the ac on to defrost the car works well in the summer but on a cold November when it's raining out it sucks. The subaru engineers really goofed by not letting you turn the ac off. Not to mention there is no indicator to even let you know it came on. On a honda the ac automaticaly comes on with the defroster but you can turn it off just by hitting the ac button.
I think this is a new D.O.T. regulation or somthig because alot of the new cars seem to operate this way. Some jackass who knows nothig about the mechanical operation of a light switch was probably paid of by oil or ac companies to pass some sort of bill on this issue.
This also sucks because you use more fuel when operating the ac. As well your ac compressor will not last as long.
The solution. remove the Micro switch that turns on the ac when the dial is in the defrost position. You do not need the ac on to defrost the car when it's 45 degrees out! However if you still want it on all you have to do is press the ac button.
Here is the link for the quick solution. The whole job only takes about 30 min.
http://forums.nasioc.com/forums/show...ir+Conditioner
Rev is offline   Reply With Quote
Old 12-30-2004, 07:50 AM   #13
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
No leaks to speak of, I think it was just from me getting in the car with wet hair or after a shower, then having all that snow sticking to my shoes and melting.
So far drying the windows after a drive, running the AC with the recirculation off and cracking a back window has helped quite a bit, no more ice on the insides in the morning, no more fogginess.
I think it was largely due to me leaving the recirculation on at all times. I go by a waste disposal plant on my commute and on rainy or hot days, it stinks like nothing else, so I shut out the outside air to keep from getting nauseous.
Thank you again guys!
Bry.
Old 12-30-2004, 03:33 PM   #14
vapore0n
Member#: 21356
2010 BMW 335i
go buy some crystal cat litter. They are made of silica gel crystals. They absorb moisture and odors. Worked like a wonder in my friends car that had this moisture stink.
Put them in a breathable (sp) bag, or a zip-lock and make lots of holes in it.
I always have one in my car.
vapore0n is offline   Reply With Quote
How do you get rid of the seatbelt beep? miiike Interior & Exterior Modification 26 05-03-2010 08:09 PM
how could i get rid of moisture in the headlight? Otaku64 General Community 11 09-11-2003 08:01 AM
how did you get rid of moisture in gauges? iloveturbos Interior & Exterior Modification 1 12-13-2002 09:56 PM
How Do You Get Rid of Old CRT Monitors? bobski Bay Area Impreza Club Forum -- BAIC 8 04-29-2002 01:24 PM
How do you get rid of clutch pedal squeak FatCatTurbo Transmission (AT/MT) & Driveline 6 12-11-2001 10:45 AM
