Old 12-28-2004, 06:58 PM   #1
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Default did the high beams/foglight mod, and it doesn't work.
It's a pretty simple mod, orange wire in fusebox, to red/green wire on relay. Tape red/green from chassis, and out that away. Test it all, and put it back together. So simple, a child could do it, but why can't I?!??!?1?!
When I tested the foglights they worked with the high beams. The second I put it all back together, the foglights no longer come on with the brights. It did the same thing last night, and I'm baffled. It's like the mod only works once before reverting back to stock. The green led on the foglight switch doesn't work anymore either, but it did when I tested it all.
Am I missing something?
any help would be appreciated.
steve is offline   Reply With Quote
Old 12-28-2004, 07:04 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
How did you secure the wires? Did you crimp or solder them, and then insulate the connections with heat shrink or electrical tape? It sounds like something came apart and/or shorted when you put it all back together. Check your fuses in case one blew, and open it up again and re-check the wiring.
Old 12-28-2004, 07:51 PM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I just got back inside and it all works.
I forgot to hook up the switch itself, so the foglights only came on when the parking lights were on.
I am teh fool of the day.
but at least my fogs work with the brights.
How Can I Make My Low Beams Stay on With the High Beams? subarumafia700 Interior & Exterior Modification 3 09-24-2009 02:54 PM
Woot! The RSTi now has high beams, foglights, and turnsignals! AcquaCow Mid Atlantic Impreza Club -- MAIC 17 10-02-2006 09:22 PM
1/2W 2.2kokm resistor mod.... It doesn't work! jigga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 06-11-2003 02:24 AM
Those with 03's... Do the high beams suck or is it just me? kkozma Forester Forum 5 01-04-2003 08:36 AM
Anyone done the high beam/foglight mod? MattDell Mid Atlantic Impreza Club -- MAIC 9 08-17-2002 01:00 AM
