Old 12-28-2004, 07:17 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default 89-90 Legacy EDM headlight leveler wiring diagram
I got a set of LHD EDM lights for my legacy. They have the electronic levelers on them. I know I can use the lights without having the electronic levelers hooked up, but I'd like to use them if I can.
I was sent a wiring diagram, but it does not match the connectors I have. I'm assuming it's for the EDM 91-93 Legacies, rather then the EDM 89-90 MY's.
If anyone knows someone in Europe, or could help me out, I'd greatly appreciate it.
Here is the incorrect leveler wiring diagram.
http://www.main.experiencetherave.co...ler_system.jpg
Here are pictures of the connectors on the motors & the switch
http://www.main.experiencetherave.co...connector1.jpg
http://www.main.experiencetherave.co...connector2.jpg
http://www.main.experiencetherave.co...connector3.jpg
http://www.main.experiencetherave.co...connector4.jpg
As you can see, the connector in the diagram only has three pins. Mine have six. Also the switch in the diagram has six pins, my switch has seven.
TIA
Josh
Legacy777 is offline   Reply With Quote
Old 01-04-2005, 10:36 PM   #2
Legacy777
Member#: 4800
Just a little update.
I've done a little homework, and found out that the sti levelers for the WRX are similar but not quite the same.
These two threads on scoobymods go into details how they work.
http://www.scoobymods.com/forums/showthread.php?t=2416
http://www.scoobymods.com/forums/showthread.php?t=952
My switch has an illumination ref source, and a ground for that.
It then takes a 12v switched source and feeds that to the levelers via the switching knob.
The levelers have six inputs. One is 12v power lead (most likely source power for the motor), ground, and the four positioner inputs from the switch. The signal from these leads probably act more or less like the trigger leads for a relay.
I've taken a few pictures of the switch, connector, and labeled them.
I plan on testing the leveler motors this weekend to verify exactly which pins are which. I'll take pictures and label them like I did these, and draw up a wiring diagram for others.
http://www.main.experiencetherave.co...edm_switch.jpg
http://www.main.experiencetherave.co...llum_leads.jpg
http://www.main.experiencetherave.co...front_pins.jpg
Josh
87-89 RX transmission wiring diagrams needed! baccaruda 'Old School' Subaru Forum 0 10-22-2008 03:28 PM
92' Legacy Ignition module wiring diagram Help! Sapote Newbies & FAQs 1 02-02-2007 12:56 PM
92' LEGACY Ignition module wiring diagram Sapote Normally Aspirated Powertrain 1 02-02-2007 12:34 PM
02-03 Cobb AP, JDM hid/EDM headlight switch and leveling wire harness ASpec818 Private 'For Sale' Classifieds 5 05-09-2005 01:47 PM
Wiring diagram for ECU on 90 legacy ciper Legacy Forum 3 07-12-2002 09:58 AM
