Old 12-28-2004, 08:16 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Parking brake light stays on
Kinda weird, but I am assuming it is a loose wire somewhere. The brake is not actually engaged but the light stays on. If I accelerate rapidly the light will go off, sometimes for good but not always. If I brake aggressively the light may tend to come back on.
Where would I look to check for this problem? I am going to start by pulling up the center console....any other ideas?
TyranosaurusWRX is offline   Reply With Quote
Old 12-28-2004, 08:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Low brake fluid. The light is also connected to a level sensor in the brake fluid reservoir. When the level starts to get low, usually due to worn pads, the light will come on occasionally when turning, accelerating, braking etc. Eventually it may remain on steadily.
Check your pads before adding more fluid, chances are they are low. If so replace them first before adding fluid, or it may overflow later.
Old 12-28-2004, 08:29 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Ahhh, that makes perfect sense. I think I am still riding on the original pads, so that all falls into place. Thanks for the tip!!!
Old 12-05-2008, 10:05 PM   #4
Teufelhund
Member#: 24792
02 WRXwag, Evo IX
Both Vishnu Tuned
I'm so glad I found this thread. I have been trying to disconnect and reconnect wire connections to my parking break switch to no avail. I'm going to try to add some brake fluid tomorrow to see if this fixes the problem... too bad I don't have access to some nice Brembo rotors and calipers. I would love to slap them on in conjunction with some nice steel braded lines. I wish my ol suby braked like my Evo... maybe some day.
Teufelhund is offline   Reply With Quote
Old 12-06-2008, 12:44 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you almost certainly need new brake pads
and properly done your brakes can be FAR better without any silly Brembos
no....really....just ask me how
Old 02-02-2009, 11:29 AM   #6
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
How?! Buying new pads today. . .
sciroccokid is offline   Reply With Quote
Old 02-05-2009, 08:14 AM   #7
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Hey me too. This makes sense since I've still got the stock pads/rotors.
I'll give it a go.
Addict is offline   Reply With Quote
Old 02-05-2009, 02:46 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I'll give it a go.
OK....
The pre '06 wrx has a garbage stock brake combination and thus the bias is WAY too far to the front.
this is EASY and CHEAP(relativly) to correct....and shift the bias to the rear a bit to make the rear brakes actually DO something.
All ya need is the CORRECT rear---yes REAR brake caliper mounting brackets to use the 290x10 rear brake disc and the discs...and remove the rear 'dust shields' from the backing plate
This is the 'h6' rear brake mod
Now...02 - 05 wrx uses 2 DIFFERENT rear brake pad 'shapes' and this is the only real complicated part......
see the linked thread below and pay attention to the racing brake link in post #19
http://forums.nasioc.com/forums/show...3#post25469273
also....the master cylinder brace is no joke....get one....no really
and good pads and fluid and you will be amazed at how much better your brakes are
Old 02-05-2009, 03:42 PM   #9
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Good advice there Uncle Scotty. I was thinking about the H6 upgrade since I've got to swap them out anyhow. The cost doesn't seem too much more. Also found the RacingBrake rear brackets that allow me to use the newer style pads. Save me from forgetting which pads to order next time around.
Old 02-06-2009, 06:32 AM   #10
channerhewitt
Member#: 201900
Thanks for the info, I had the same problem like that....
channerhewitt is offline   Reply With Quote
Old 02-06-2009, 08:26 AM   #11
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Whaddya know. My brakes started squeaking last night.
Old 02-10-2009, 01:13 PM   #12
twizhimself
Member#: 58294
2004 WRX / 1998 Foz
SoCal F4 #20 / Area1320
just encountered this myself yesterday. Wasnt sure, finally last night i adjusted my parking brake, and today the light stays on. I guess this weekend ill be pulling my brakes and checking their wear/fluid
twizhimself is offline   Reply With Quote
Old 02-10-2009, 02:31 PM   #13
dunk
Member#: 15359
You don't have to pull anything.
You can verify the fluid level by just opening the hood.
You can see the pad wear by just peeking through the spokes of the wheel. You won't be able to see the inside pad, but it will give you a good idea if that's the reason the light is on.
-Duncan
dunk is offline   Reply With Quote
Old 02-11-2009, 10:27 PM   #14
dryvby
Member#: 49931
0305 wrx/Xt
black/gold
h6 upgrade made an awesome difference along with metal lines on my impreza. im gonna take unkle scottys advise and give the cylinder brace a whirl. any manufacturer that you would recommend for the brace would be great scotty.
dryvby is offline   Reply With Quote
Old 02-12-2009, 08:31 AM   #15
dunk
Member#: 15359
Buy the Cusco. It mounts with more bolts than the Perrin and it's made out of steel.
-Duncan
Old 02-12-2009, 03:10 PM   #16
dryvby
Member#: 49931
0305 wrx/Xt
black/gold
coo, thanks dunk
Old 02-24-2009, 08:00 AM   #17
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
So do you think it's the same problem if the brake light only comes on in the morning when I'm driving to work in the cold? The past two mornings I've driven my car to work it's been pretty cold (atleast for SC temps) and the brake light has been on both mornings. but not after work or at night. I wonder if its my fluid level too...
IVGottaBDreamin is offline   Reply With Quote
Old 02-24-2009, 08:15 AM   #18
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Cold causes contraction. Warm/hot causes expansion. Think about it for a sec and you'll answer your own question.
...Its an easy check. Pop the hood and look at the reservoir when its cold.
Old 03-01-2009, 09:57 PM   #19
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Finally got my pads & rotors swapped out. Went with stock OE spec and Hawk HPS pads.
Fronts...
Rears...
Think the change was overdue? Got new fluid and the MBC brace sitting the garage. Those are next.
Brake light is out. Thanks again Uncle Scotty.
installed new mc, bled brakes brake light stays on???? vien Brakes, Steering & Suspension 6 04-27-2010 02:18 AM
Brake light stays on when cold? strohk Brakes, Steering & Suspension 4 12-15-2004 05:21 PM
E-Brake light staying on? Bobalouy Brakes, Steering & Suspension 5 09-07-2004 03:00 PM
Parking Brake light staying on??? NYWRXTASY Brakes, Steering & Suspension 8 04-09-2003 08:57 PM
E-Brake light stays on? sumo Brakes, Steering & Suspension 5 05-05-2002 09:51 PM
Message Board Statistics All times are GMT -4. The time now is 08:59 PM.
