Welcome to the North American Subaru Impreza Owners Club Saturday November 1, 2014
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 12-28-2004, 08:24 PM   #1
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Default Hydra Launch control setup
Does anyone know how to set up the drag launch feature? I assumed that you would just be able to set it, and begood to go, but i think there is more to it than that. It seems like you would need to run a wire from the hydra to the clutch sensor in order for the hydra to know that you are wanting to launch.. lol.. Any help or what ever would be greatly appreciated. Thanks!
-Kevin
Pi7467mp is offline   Reply With Quote
Old 12-28-2004, 08:28 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
It's triggered by some pin on the ECU. I know with the MR2 Hydra they sell a "launch control cable". The input for the launch control actuator may be something that needs to be enabled by the Hydra dealer, I'm not sure.
Old 12-28-2004, 10:03 PM   #3
awdvf22
Member#: 73926
how you like the hydra im thinking on getting one those and what kind of injectors are you runing and whp. pm
thanks.
awdvf22 is offline   Reply With Quote
Old 12-28-2004, 10:05 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
M-F, 9AM to 5PM Eastern
jblaine is offline   Reply With Quote
Old 12-29-2004, 12:18 AM   #5
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
I like it so far, I am completely untuned, but even being untuned it runs so strong it is ridiculous!
jblaine: I am guessing you have the info, and that is your number to communicate? Thanks guys!
Old 12-29-2004, 09:37 AM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
No, that's Element Tuning's phone number (Phil Grabow).
Old 12-29-2004, 03:41 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
you are going to have to set the launch request in the I/O tab of the settings menu.
The Hydra has 6 Aux inputs. These inputs can be mapped to control various things by setting the drop down menu.
I'm not sure about your map, but on the one I have been working on Launch request was set to Aux input 3, and AC high request was set to Aux input 5. If you wanted a quick solution and don't have AC, you could use the AC button as your launch request toggle, or find the wire which the AC button connects to and rewire it to a switch for your launch control.
I would check to make sure that your AC button input to the hydra is working by going to view/panal and seeing if the AC lights up when you push the AC button in the car.
If its working, you can go back to your I/O menu and change "AC high request" in the drop down menu to "Launch High Request".
Then Hydra will run your launch control setting when the AC button is pushed in.
You could obviously run Launch Control off any other AUX input, but as out wiring harnesses don't seem to be wored for them as we get it you will have to get some cables from Hydra or Phil and the right locations of the connector for Aux inputs.
Todd
Hitokiri is offline   Reply With Quote
Old 12-29-2004, 11:42 PM   #8
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Ok so I go to IO tab, and just switch the launch from 3-5, and then that will control launch? Interesting, I guess it wouldn't hurt to try?
Old 12-31-2004, 02:29 AM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
Hitokiri has the winning post. Set any request signal to engage the launch control and it will dump into the main fuel map following engagement.
Old 12-31-2004, 05:56 AM   #10
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
ummm. doesn't work... sorry
Element Hydra launch control wiring ? pollawrx06 Engine Management & Tuning 3 11-17-2009 05:50 PM
Hydra launch controll harness help RichWRX Other Engine Management 5 08-21-2009 08:09 PM
Launch control setup for 02-05 wrx theguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-07-2008 10:56 PM
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
hydra launch control rjrutzky Other Engine Management 19 06-05-2006 09:34 PM
