Old 07-06-2001, 06:07 PM   #1
RaceFace
Member#: 8072
'04 Forester
Question Legacy GT Wagon Wheel Offset
What is the wheel offset for the '97 GT wagon? Can the offset be varied by a few mm's either direction? Have the opportunity for some 55 mm offset wheels (WRX) and am wondering if there will be any issues. The car has had suspension work done - sits 1" lower - and works well with the stock wheels (ie. no rubbing) and I don't want to have to roll up the insides of the wheelwells to make it all work or worry about rubbing on the strut/springs.
RaceFace is offline   Reply With Quote
Old 07-06-2001, 06:35 PM   #2
Legacy STi L
Guest
Member#:
Please somebody correct me if I am on crack here but...
If you drop you offset to less than 48mm then you run into possible rubbing on the FENDERS. If you were to crank the offset to 58 then you might rub the struts. Correct, or is this ass-backward?
TIm
So. the less the offset the closer to the fender, right?
Old 07-06-2001, 08:39 PM   #3
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
Lightbulb quick 101
The distance from the mounting face to the centerline of the wheel is the offset. This is positive for mounting faces outboard of the centerline and negative for inboard. Only positive offsets are relevant to scoobies. The higher the offset, the further the mounting face is from the centerline of the wheel. If the wheel width is the same but the offset is higher, the whole of the wheel is moved closer toward the body of the car. Oh yes... be sure to take into account the width of the wheel.
General ideal offsets as I've seen on this board...
6.5in wide 55mm (16x6.5 02 WRX oem)
7in wide 53mm (16x7 98-01 RS)
The lowest acceptable offset for a 7 or 7.5 inch wide wheel is observed to be 48mm. Keep in mind rubbing depends on your tire size choice as well. I hope this helps.
AG
Did I forget anything? Anybody?
AGscooby is offline   Reply With Quote
Old 07-06-2001, 09:10 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
To answer the original question, the WRX rims will fit just fine. They are exactly the same size as the 2.5GT rims - 16x6.5" with a +55mm offset. I'd like to see how they would look on a 2.5GT. I personally think they're way too boring for the WRX, but the 5 spoke design on a 2.5GT should look pretty cool.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-06-2001, 11:02 PM   #5
94LegacyGTWagon
Member#: 8082
'97 Impreza OBS
would the WRX wheels fit onto a 94 (previous gen than the 95-97s) as well? and how much do the WRX wheels cost? I'm stuck with the funky 14" webbed wheels, they look ok, but they come across as hubcaps a lot, and they are too small i think.
94LegacyGTWagon is offline   Reply With Quote
Old 07-06-2001, 11:05 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yup, they'll fit on the older cars just fine. I auto-x'd with a guy who had an older Legacy Turbo with 2.5RS rims on it. If those will fit without any problems, the narrower 2.5GT rims will also fit.
Pat
Old 07-06-2001, 11:18 PM   #7
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
this was done kind of quickly, but should give an idea of what wrx wheels look like on a gt:
froggert is offline   Reply With Quote
Old 07-07-2001, 01:39 AM   #8
Legacy STi L
Guest
Member#:
That's what I am talking about. I am in the process of trying to track down some WRX schlepp that bought new wheels and is trying to sell his. Hopefully within the next week I will have a new/used set of wheels for the 'ol Leg.
TIm
FS: Legacy GT Head Unit/HVAC out of an '05 Legacy GT Wagon Geoff Interior/Dressup/Audio & Security 0 07-14-2009 12:33 PM
'05 Legacy GT wagon wheel questions boxerT Tire & Wheel 2 06-27-2007 06:20 PM
WRX wagon vs. Legacy GT wagon vs. Forester XT BPCLFD General Community 27 10-21-2005 11:46 AM
Stock 2002 Legacy GT Wagon wheels for sale BH5Ritch Private 'For Sale' Classifieds 3 10-26-2004 02:33 AM
WTB: MY '00+ Legacy Wagon or Legacy GT Wagon Suspension BrokenCrank Private 'Wanted' Classifieds 0 09-02-2003 12:41 PM
