Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 12-29-2004, 06:21 AM   #1
zeroFX
Member#: 10636
2002 Impreza WRX
World Rally Blue Sedan
Unhappy Help ! High beams and fog lights don' t work ! Low beams are ok.
I just noticed tonight that my high beams and fog lights don' t work. My low beams are ok. My fog lights seem to work sometimes which is weird. When I turn on my high beams, the head lights go out. The parking lights are fine, though. Is there something wrong with my connections or is it a fuse issue ? I have aftermarket head light bulbs. They' re the "HID-look" ones. Some asian no name brand. I also have Oshram yellow fog light bulbs.
I' m going to check out my fuses in the morning. Anyone know what' s going on with my lights ?
zeroFX is offline   Reply With Quote
Old 12-29-2004, 07:59 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If your low beams work it isn't the headlight fuses.
Check the bulbs, the high beam filaments may both be burned out.
And you should avoid those cheap bulbs, even the supposedly stock wattage ones have been known to run hot and cause harness and connector damage. Take a close look at your headlight wiring, the bulbs may have toasted it.
Old 12-29-2004, 01:35 PM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Check out the underhood "switch" fuze just below the headlight fuses. It's a yellow (20a) fuze. I popped mine last night by accident, and it did the same thing.
good luck
steve is offline   Reply With Quote
Old 12-29-2004, 04:45 PM   #4
zeroFX
Member#: 10636
2002 Impreza WRX
I checked the fuses and they seem fine. I' m thinking it' s my bulbs or my connections. My connections don't look fried but I don' t know wiring or electronics.
I' ll check out my bulbs first.
both High beam and Fog light bulb went out at the same time :( Mike7 Electrical & Lighting 1 09-28-2009 11:30 AM
Lost Low Beam, High Beam and Fog Lights zeromax Electrical & Lighting 4 11-05-2005 09:53 PM
Low beam and fog lights Dreamer Electrical & Lighting 4 01-06-2005 11:17 AM
Quick question on hyper white high beams and fog lights to match HIDs IA Performance Interior & Exterior Modification 7 10-05-2002 06:02 PM
High Beam and Fog Light Combo!! Bumsarama Bay Area Impreza Club Forum -- BAIC 8 05-01-2001 10:44 PM
