Old 12-29-2004, 09:23 AM   #1
tcmo
Member#: 12817
2013 Legacy 2.5i LTD
Default head gasket sealant longevity
Our 1999 Forester had the head gasket sealant added in Feb 2004 at 50500 miles. It started leaking worse than originally on 12-20 at 57000 miles. The dealer replaced the head gaskets under warranty. Can the head gaskets be replaced without removing the engine? Thanks.
tcmo is offline   Reply With Quote
Old 12-29-2004, 10:21 AM   #2
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
If it's the SOHC motor, yes they can. However, it would be easier to remove the motor. You'd be surprised how easy it is to pull a motor.
Diz is offline   Reply With Quote
Old 12-29-2004, 11:11 AM   #3
tcmo
Member#: 12817
Yes, it is the SOHC engine.
Thanks for the reply.
Should I apply gasket sealant on intake manifold gasket? gopsu Newbies & FAQs 0 07-30-2009 11:54 PM
Can I use Liquid Gasket Sealant on OEM Gaskets? nerdydorkus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-24-2007 03:13 PM
Head gasket sealant redwagon Service & Maintenance 7 09-22-2005 10:14 PM
Using Gasket sealant between dp/midipe questions KanosWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-09-2005 01:56 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 10:22 PM
