Old 12-29-2004, 01:55 PM   #1
antidote11
Member#: 31074
'06 WRX TR
CGM
Default Car Makes Weird Water Sloshing Noise ??
I have an '04 WRX -
When I start my car, after it has been sitting for awhile and is completely cooled off, I hear a weird water sloshing around sound when I rev the engine or give it gas. It does this until my car heats up fully.
What could be making this noise ?
Again, it's when I first start the car, for about the first 5-10 minutes,
everytime I rev the engine or give it gas, I hear this water sloshing around and it sounds like it's coming from right in front of the steering column in the engine bay. Has anyone ever experienced this ?? Thanks for any info !!
Antidote11
antidote11 is offline   Reply With Quote
Old 12-29-2004, 01:58 PM   #2
subenerd
Member#: 72630
2004 STi
Mine does that too! I have no idea what it is.
subenerd is offline   Reply With Quote
Old 12-29-2004, 02:08 PM   #3
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
You have a little air in your cooling system. I had the same thing for a while - it sounds a bit like a hookah when you rev the gas. When the car is cold, remove the radiator cap and squeeze the coolant hose gently a few times to "burp" the system. Have a rag ready in case some coolant sloshes out into your engine bay, or you will be smelling coolant burning off your motor for a week or so. You can top off with distilled water, coolant, or a 50/50 mix. I say this because it took a very small amount of liquid in my car to remedy the situation...like maybe 100 ml.
Stanley is offline   Reply With Quote
Old 12-29-2004, 02:10 PM   #4
XtianLA
Member#: 29958
03 WRX
Yeah, it happened to me a while ago too. I didn't really know what to do and just randomly though I should bleed my coolant system a little....turns out it worked, lol.
XtianLA is offline   Reply With Quote
Old 12-29-2004, 02:23 PM   #5
subenerd
Member#: 72630
2004 STi
Cool, thanks
Old 12-29-2004, 02:44 PM   #6
antidote11
Member#: 31074
'06 WRX TR
CGM
Very cool man, thanks for that info!! I probably would have never thought
about that remedy. : )
Old 12-29-2004, 02:47 PM   #7
firecordz
Member#: 58901
sold my wrx :(
and moved to japan :)
same problem here, only after a dealer did warranty work on my car... thanks for the advice!!!!
firecordz is offline   Reply With Quote
Old 12-29-2004, 03:04 PM   #8
SubieScottWRX
Member#: 16957
Grey
Originally Posted by antidote11
I have an '04 WRX -
Antidote11
Mine too!!! i dont know what the heck it is!
SubieScottWRX is offline   Reply With Quote
Old 12-29-2004, 03:44 PM   #9
antidote11
Member#: 31074
'06 WRX TR
CGM
SubieScottWRX
I think they said what it could be a few posts up > air in the coolant system.
All I know is that tonight after my car is nice and cool, I'm gonna bleed the coolant system of any excess air and see if that fixes it. And I'll be sure to post the results.
Old 12-29-2004, 07:07 PM   #10
antidote11
Member#: 31074
'06 WRX TR
CGM
This may be a dumb question, but which hose is the "coolant" hose ?
There are three hoses (Labeled 1, 2, 3 in pic below) that
lead to where the radiator cap is. What are these three hoses ?
There is also a place to fill the engine with coolant, in
the front of the engine bay that has a radiator looking
cap and a single hose (Labeled 4 in pic below) - What is this hose?
Thanks !!
Old 12-29-2004, 07:31 PM   #11
antidote11
Member#: 31074
'06 WRX TR
CGM
Bump
Old 12-29-2004, 07:44 PM   #12
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
they are all coolant return hoses. what are you trying to do?
adeliciouspizza is offline   Reply With Quote
Old 12-29-2004, 07:47 PM   #13
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
check your brake fluid too. i had a bubbly/sloshing noise when i needed new pads that went away with a fresh set. i need brakes again and the sound has come back.
ZoomnWRX is offline   Reply With Quote
Old 12-29-2004, 07:57 PM   #14
antidote11
Member#: 31074
'06 WRX TR
CGM
Weitek
I am trying to get air out of my cooling system.
Read my original post at the top and then read
Stanley's post. That's basically what I am up to.
Old 12-29-2004, 07:57 PM   #15
optimusprimerib
Member#: 23665
1997 Legacy GT
Red
Stop driving through the lake, man.
optimusprimerib is offline   Reply With Quote
Old 12-29-2004, 07:59 PM   #16
antidote11
Member#: 31074
'06 WRX TR
CGM
Done. I will no longer drive through lakes!
But, too bad that's not the solution to my problem.
Old 12-30-2004, 12:49 AM   #17
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
ah yea. those are the coolant return hoses. i think he was telling you to mess with the thicker hose at the top/middle of the radiator (you dont have it numbered on your pic). well i just did a quick google search and found a howto.. hope it helps. good luck.
http://www.ehow.com/how_7369_burp-cars-cooling.html
Old 12-30-2004, 01:31 AM   #18
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
yep, squeeze the big hose going to the middle of the top of the radiator w/the little arrow on it pointing to the front of the car. that is you upper radiator hose.
greg donovan is offline   Reply With Quote
Old 12-30-2004, 09:59 AM   #19
antidote11
Member#: 31074
'06 WRX TR
CGM
weitek
Thanks for the link man.
I'll try that out for sure.
Car making weird noise SubieSG2057 Brakes, Steering & Suspension 4 01-11-2010 04:36 PM
car making weird noises coming to a stop fiveoh88 Brakes, Steering & Suspension 5 11-21-2009 02:46 PM
HELP: car makes weird noise in reverse spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-31-2007 11:33 PM
Car making weird noise virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-02-2003 06:58 PM
('93-'01) Weird water pouring noise at startup! 97 Impreza Outback Sport itsmywifescar Impreza Forum 4 10-24-2002 02:54 AM
