Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-11-2005, 07:42 PM   #26
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Would you be so kind as to give some more info on these new headgaskets?
powerlabs is offline   Reply With Quote
Old 01-12-2005, 11:54 AM   #27
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
not much more to elaborate. They are a three layer metal design from Cometic that measures .027 cm in thickness vs the .058 cm of stock. They are readily available directly from Cometic and from a number of vendors...
Old 01-12-2005, 12:58 PM   #28
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
I've been wondering about this incedent since I read some posts refering to the "fragged" motor.
Good job on the quick tear down / rebuild! Hope to see you around soon - we'll have to see how the new CR treats me SS....
-Chad
Farfrumwork is offline   Reply With Quote
Old 01-13-2005, 04:14 AM   #29
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by Matt Monson
The new engine uses my original heads on a 20K mi. EJ25 out of a wrecked Legacy.
So does that mean the bored-out STi block plan was put off for now, or is the block from a new '05 Legacy block?
I upgraded to .027 thin metal head gaskets from Cometic (thanx Storm) and bumped the CR.
OK, I'm lazy. What does the CR come out to with the thinner head gaskets?
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-13-2005, 09:28 AM   #30
Matt Monson
Member#: 832
99 2.5RS, '85 911
I'm lazy too, and am waiting for someone else to bother calculating it.
And the STi bottom end is on hold for a bit. This new block is from a MY00 Legacy, and just seems so solid right now, I don't feel like spending any money on overboring and building my STi block.. My tranny is dying and I have a spare set of heads I can port, so I am going to spend any mod money in that direction for the next six months or so. Eventually, the STI block should go in there, but not for a while yet...
Old 01-15-2005, 01:25 AM   #31
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
*sigh* Do I have to do eeevvverything around here??
Using data from wac's webpage http://wac.addr.com/auto/obs/turbo/ejcalcs.html I get a stock CR of 11.07:1 for a 2000 SOHC with the 0.058cm stock gasket (slightly different from Wayne's number, I imagine due to rounding differences - I'm letting Excel calculate everything out to 8 bazillion places). With the 0.027cm Cometic gasket I get a CR of 11.49:1 - not a huge jump, but enough to be worthwhile.
While I'm busy hijacking the thread, I wonder what the gasket thickness is of the "new" (as of a couple years ago) 4-layer DOHC gaskets. That's what I have on my car - ever since the Cobb stuff was installed back in early '02.
Pat
Old 01-15-2005, 10:15 AM   #32
Storm
Member#: 5218
96L Most Over-
Developed Beater
Holy sheeaayt!!!!! Would the CR bump any more if using DOHC RS heads......that have been shaved .010"????
No wonder I have to use 93 octane and still have an urge to add toluene!!!!
Jay Storm
Old 01-16-2005, 02:12 PM   #33
Matt Monson
Member#: 832
99 2.5RS, '85 911
Pat,
Thanks. That was about what I figured but bailed on the calcs when I started to need rod length and opening degrees.
Jay,
Your would be higher just by using the DOHC heads on a phase II block. According to what Xephyr told me, it is around 11.5:1 just because the head volume is 2 cc smaller on the DOHC heads. Add to that the shaving (mine are shaved too) and the thin gasket, and I bet you are pushing 12...
Old 01-16-2005, 04:49 PM   #34
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
The new HG's are 0.069" uncompressed (yes, I have a new set in my parts bin).
OH, BTW, the PN is SUB11044AA610, same for both sides.
Old 01-17-2005, 01:20 AM   #35
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Jay Storm
Bend 'em. Just don't break 'em (rules).
- Steve
zzyzx is offline   Reply With Quote
Old 01-17-2005, 03:05 AM   #36
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Pat,
I could be wrong, but as far as I know CR is a static ratio, so you shouldn't need to know those numbers. The hard ones to find (which WaC has on his webpage) are the piston volume and the cylinder head volume. Of course, now that I know your heads are shaved the number I calculated is going to be off a bit - your CR is actually higher than what I came up with. Is the shortblock still stock, or do you have different pistons, too?
Pat
Old 01-17-2005, 03:08 AM   #37
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Which of course raises the question, what's the compressed thickness?
Pat
Old 01-17-2005, 10:41 AM   #38
Storm
Member#: 5218
96L Most Over-
Developed Beater
- Steve
It's all good, Steve. This motor is in the 96L! 'Course the rulebook still has the Impreza listed as 2.5.(period) No RS designation at all.....
Jay Storm
Old 01-17-2005, 11:38 PM   #39
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Hey Matt or Storm - I posted some questions in the 2.2L Frankenstein thread, was wondering if either of you might have a minute to stop over there and answer any you are able to?
Thanks much in advance, I'm sure you're both uber busy!
CirrusWRX is offline   Reply With Quote
Built Motor Inside? Help me figure out what is in my motor! turboge Built Motor Discussion 24 02-10-2010 01:21 PM
somebody blew my motor poured rocks in my oil cap ryanpietro Off-Topic 124 04-13-2006 02:27 PM
Should I sell my 18g and a get a Green or wait till my motor is built? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-29-2004 02:01 PM
My motor doesn't like me or my taste in mods(HELP!!!) BlckRabbt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 63 04-06-2004 09:14 AM
pictures of my motor installed and my car STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 05-21-2003 12:08 AM
