Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 12-29-2004, 03:21 PM   #1
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Default replaced my seats and now the horns don't work
I swapped out my WRX seats for a JDM pair and ignored the airbag light. However ever since my horns have stopped working. I dropped it off at a shop for some other stuff and I asked them about it and they said my horns were associated with my airbags and if the airbag light is on the horn won't work.
Is this true? If so, will the resistor mod fix it? What resistor is it again, and where does it go?
Capt Crunch is offline   Reply With Quote
Old 12-29-2004, 03:23 PM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The only connection between the horn and the airbag is that both use the clock spring/roll connector in the steering wheel. But, this only applies to the driver air bag in the steering wheel and has nothing to do with the side airbags in the seats.
It's possible that your roll connector just happened to go out at the same time you changed the seats.
HELP: Changed the A/C and PS belts and now the A/C doesn't work scottjua Service & Maintenance 12 04-08-2010 07:05 PM
Supertones stopped working... But the horns still work. What gives? RP31 Electrical & Lighting 5 11-23-2007 10:13 PM
Help! I disconnected my battery and now the hazard lights keep blinking! Pleasehelp Electrical & Lighting 6 09-25-2004 05:03 AM
I blow my engine and now have to replace it wrx_monster Mid Atlantic Impreza Club -- MAIC 32 09-02-2004 12:54 PM
05 sti, reset my battery and now my parking lights don't flash when arming alram coil222 Electrical & Lighting 1 05-30-2004 03:59 AM
