Old 12-29-2004, 06:57 PM   #1
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Default Optima install..Is it easy?
I just got a Group 35 today and Im contemplating the install tonight or should I just wait till the weekend? Does it go right in or do I need to get anything else? The battery is the correct one for the car with the proper terminal orientation..
I guess my question is do I need anything else or is it just plug and play?
Thanks for the help..
wrx05 is offline   Reply With Quote
Old 12-29-2004, 07:02 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
As long as you got the true 35 and not one of the "universal" 35/75's, it is a direct replacement for the stock battery. Disconnect negative terminal, then positive from old battery, remove hold-down clamp and take battery out. Drop in new battery and reverse procedure, done.
Old 12-29-2004, 10:04 PM   #3
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Thanks again Mulder...I got the true 35 from TNA.. I had read somewhere that the stock hold down clamps were too long..I didnt know if this was true.
Old 12-29-2004, 10:08 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Hm, not sure then about the clamps on your car. On my 02 with the 35/75, which is the same height as the 35, the lower height of the battery meant I had to screw the nuts way down on the studs to secure the clamp, but it did go down far enough. I haven't looked at the hold-down arrangement on an 05 but I wouldn't think it's that different.
Old 12-29-2004, 10:15 PM   #5
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
I'll give it a try on Saturday..I have a set of Osram Silverstars going in as well. I can always hit Autozone for 8" clamps. If I remember right the OEM ones are 10".
Old 12-29-2004, 10:20 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yeah, I don't think you'll have a problem. There is also a spacer available to put under the battery to raise it up to stock height, but you'd have to order it. Shouldn't be necessary.
Old 12-30-2004, 01:05 PM   #7
scoobysnowrally
Member#: 76478
06 STI & Tribeca
Aspen Graphite
my cables woudlnt reach if I mounted it regular so I had to mount mine on its side. then I had to use a few washers on each side to tie it down with the stock tie downs
scoobysnowrally is offline   Reply With Quote
Old 12-30-2004, 10:03 PM   #8
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
then i'm going to assume you used the wrong battery.
tooocool49723 is offline   Reply With Quote
Old 12-31-2004, 01:12 AM   #9
wrxspdr
Member#: 10570
2002 wrx
Default surprised mulder didn't jump on this
I had this issue and mulder rescued me on it. You have to replace the starter cable with a longer one. The one from a legacy fits or the one from your local autoparts store. The trick is to undo the winshield washer tank and sneak yuor hands in to the starter. Worked well for me optima is a great battery.
wrxspdr is offline   Reply With Quote
Old 12-31-2004, 01:08 PM   #10
Skell
Member#: 75638
new metalocalypse
is effin funneh
Another KUDOS for the Optima, I dont fear our cold NW morning starts anylonger...
Skell is offline   Reply With Quote
Old 12-31-2004, 03:08 PM   #11
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
ditto....
Old 12-31-2004, 05:10 PM   #12
Skell
Member#: 75638
new metalocalypse
is effin funneh
did u mod your bolt rails? Im thinking bout hacksawing a few inches off my two....
Old 12-31-2004, 07:01 PM   #13
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
I just picked up a set of 8" bolt rails from autozone for 5 bucks..battery is going in tomorrow.
Old 01-01-2005, 03:05 PM   #14
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
battery is in and I managed to screw it up..I tightened down the clamps too much when I put some bulbs in awhile back and now when I let them out today the hole for one of the rails is all torn up. Its just sheetmetal and is pretty soft. I got the battery in and I was able to get the rail to seat somehow in the torn up hole but Im just not confident that its going to be okay. Maybe Im just being paranoid because it is solid.
You guys think it will be cool?
Old 01-01-2005, 04:16 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I would fix that, it isn't that hard to get replacement parts (you can even go for some bling as in the pic above). You don't want your battery rattling around.
Old 01-01-2005, 07:07 PM   #16
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
mulder--i was thinking the same thing but i dont think that it is replaceable..its the sheetmetal "stand?" that the battery and tray sit on top of. It has a hole on each side for the tie down rails to attach to. When I go in for my oil change I'll ask them to look at it and see if it can be replaced. The battery is very secure so Im hoping that it will never turn into a problem. I drove most of the day today and it didnt move at all.
Thanks for the input Mulder..BTW, the Osram Silverstars are awesome..
Old 01-01-2005, 07:13 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, as long as the battery is tight and not in danger of loosening as you drive around. Maybe you can add some washers to reinforce the area, or I suppose it could be welded.
Glad you like the bulbs.
Is it easy to swap the stock wastegate with another stock wastegate? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-23-2005 07:19 PM
Is it easy to take off the sti foglight cover? cinemaster Newbies & FAQs 21 09-15-2005 12:06 PM
DIY vinyl tile.. Is it easy to do? MrBlue Off-Topic 3 03-07-2005 01:57 PM
is it easy to make front lights clear on 04 wagon? subaru_wrxwagon Electrical & Lighting 2 10-22-2004 11:58 AM
Is it easy to change the cams in the 2.5RS Impreza i need details thanks Imprezive2002 Normally Aspirated Powertrain 15 05-13-2003 07:15 PM
