Old 12-29-2004, 09:55 PM   #1
db97
Member#: 7140
2009 WRX
satin white pearl
Default my left morette died today! where can i get a replacement bulb on the cheap?
Anyone know where I can get a replacement morettes low beam for cheap? It's lasted 3 years, and it finally died today. Anyone???
Thanks,
DB97
db97 is offline   Reply With Quote
Old 12-29-2004, 09:59 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's an H7, they are available at parts stores. But you shouldn't get the cheapest bulb you can find, and stay away from any of the blue ones. At least look for OEM-type brand name bulbs such as Philips, Sylvania etc. Replace both low beams at the same time, because the other side will probably blow soon anyway and also to maintain consistent light output between both sides.
Use only 55 watt bulbs, do not install anything higher.
Old 12-29-2004, 10:05 PM   #3
db97
Member#: 7140
2009 WRX
satin white pearl
thanks mulder! is the replacement process pretty easy? an easy swap of the bulb and away i go...or no? or do you know?
Old 12-29-2004, 10:17 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Oh, I know all right.
It's not that hard, but if you haven't done it before it may take you a few minutes.
Remove the rubber dust cover from the back of the projector unit. Inside you'll see the bulb and wiring connector plugged into it. Remove the connector from the back of the bulb, it may be on there tight but just wiggle it gently while pulling back on it, it will come off. Once the connector is off the bulb can be removed, it's held in place by a metal retainer spring. You have to push down on the spring in two places and move it over while pushing to release it from the clips. Once released it swings out of the way and the bulb can be pulled straight out. Line up the new bulb, insert it into position, and secure it with the spring. Put the connector back on and then the dust cover.
Do not touch the new bulbs with your fingers. If you do by accident clean them off with alcohol before installing, in fact you can do this anyway. Any dirt or contaminants on the bulb can interfere with heat dissipation and cause it to fail prematurely.
Depending on how large your hands are you may have some difficulty accessing the bulbs with the lights in place, if this is a problem you may need to remove them from the car first.
Where to get a front bumper on the cheap? woodyak Interior & Exterior Modification 6 11-14-2007 02:06 PM
cross-forum post: Screwed up my gauges..where can i get a replacement cluster? kaisersouse General Community 0 05-31-2005 12:53 PM
Where can I get a 27-30" TV for cheap? snvin Tri-State Area Forum 6 09-28-2004 03:38 PM
where can i get a bodykit put on??? enyce4u Interior & Exterior Modification 5 06-13-2001 03:46 AM
Where can I get blue headlight bulbs for my Impreza? 2.5rsMI Interior & Exterior Modification 10 04-11-2001 02:44 PM
