Old 12-30-2004, 01:22 AM   #1
johnnywu
Member#: 73562
05 doh mah
ILikeGurlsThatLikeGurls
Default non dealership oilchange void warranty?
not getting my oilchanged from the dealership will void the warranty?
i just installed a BOV and wasnt sure if that in and of itself void the mfg's warranty, so to be on the safe side i thought that maybe i should just get my oil changed anywhere, but wasnt sure if that would void it as well...
i just installed the BOV and would prefer avoid switching it out just for the oil change.... anythoughts?
johnnywu is offline   Reply With Quote
Old 12-30-2004, 01:47 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Not a problem.
The better business bureau would have a field day if getting your oil changed just anywhere voided your warranty.
The only way your warranty can be "voided" is for any failed parts that died BECAUSE OF A NON FACTORY PART/MOD that killed it.
Thus, a new stereo can't void the warranty of your trans when it blows up.
But, a BOV, single puck clutch, bigger turbo can all void the trans warranty since they raise the HP above stock limits or overstress the trans.
Old 12-30-2004, 01:52 AM   #3
johnnywu
Member#: 73562
05 doh mah
so keep the bov and get an oil change anywhere else?
Old 12-30-2004, 01:55 AM   #4
Jejunum
Member#: 15773
2011 Impreza WRX
search search search.
oil changes else where or any other service will not void your warranty.
Jejunum is offline   Reply With Quote
Old 12-30-2004, 08:30 AM   #5
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
Originally Posted by Charlie-III
Not a problem.
BOV does nothing power wise, or transmission wise. It does, however, cause car to run rich on shifts, potentially causing unburned fuel to burn up in the uppipe cat, which can then break up destroying your turbo...
realwomble is offline   Reply With Quote
Old 12-30-2004, 08:51 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It doesn't matter where you get your maintenance done. What does matter is that you use the recommended parts and fluids and keep good records so it can all be documented. You can have the dealer do it, go to an independent shop, or do it yourself.
Old 12-30-2004, 11:51 PM   #7
andrewt461
Member#: 70647
2004 WRX
last one is the best. spend 30 minutes, save 30 bucks. =)
andrewt461 is offline   Reply With Quote
Old 12-31-2004, 06:53 PM   #8
OAK STI
Member#: 71728
Piece of mind is worth all the money in the world. Nobody will treat your car as good as you will; do it yourself
OAK STI is offline   Reply With Quote
Dealership scared me about voiding warranty! HAL1 General Community 36 06-14-2006 07:41 PM
STi strut clunk with GF210's, will dealership void warranty if I go for replacements? Moshpit552 Brakes, Steering & Suspension 1 05-11-2006 07:53 PM
Dealership voided warranty Honkey3k Warranty Issues & SOA Problems 58 05-29-2005 09:09 PM
Dealer says SOA reps are voiding warranties and denying warranty work PaulRex Warranty Issues & SOA Problems 31 08-09-2002 12:52 AM
will lowering void warranty chauncey Newbies & FAQs 7 02-07-2001 01:19 AM
