Old 12-30-2004, 01:16 AM   #1
nightdesigns
Member#: 59316
2004 Leg L SP w/ A/T
Default XM Roady 2 Engine Noise
I installed a XM Roady 2 (cigarette lighter power, built in FM modulator) and i've been picking up engine noise only when listening to the XM. The radio is fine.
I'm guessing the noise is coming through the cigarette lighter.
So is there a such thing as a cigarette lighter noise elinimator? I've seen them for hard wire installs, but not for a cigarette lighter.
THanks
'04 Leg L
nightdesigns is offline   Reply With Quote
Old 12-30-2004, 11:04 AM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
you could just wire up one of those hard wire installs behind the cig lighter.
SHane
PARANOID56 is offline   Reply With Quote
Old 12-30-2004, 11:18 AM   #3
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
Try grounding it to another location. Make sure it is bare metal to metal contact. If you grounded it through the wire harness, ground it to the chassis.
skyhawk is offline   Reply With Quote
Old 12-30-2004, 01:17 PM   #4
nightdesigns
Member#: 59316
Well, the system is entirely powered through a cigarette lighter, so should i just cut the ground side of the wire and find some metal to attach it to?
-ja
Old 12-30-2004, 05:42 PM   #5
skyhawk
Member#: 36255
04 WRB WRX
If you have it hardwired to the cigarette lighter then yes. If you have it plugged into the lighter so it can be removed then no, unless you want to hardwire it. Not familiar with the Roady so I don't know how it wires up to the car. I just know that if you have engine noise through the stereo then more than likely it is a grounding issue. But if it is hardwired, just find a good screw or bolt under the dash that is mounted to metal, not plastic, and use that for a ground. You may have to try more than one spot to get a good grounding location.
Old 12-30-2004, 07:15 PM   #6
kb2spn
Member#: 28897
2004 STOLEN WRX STI
Blue/Gold
THanks
'04 Leg L
How is sound being transmitted to the radio,if you are using a wired rf modulator you may have a double ground loop.Disconnect the ground wire from the modulator if this is the case.
ooooooops just saw the built in modulator!!!!!!!!
kb2spn is offline   Reply With Quote
Old 12-31-2004, 06:30 PM   #7
ieiscooby
Member#: 38258
2004 EWG VF30 WRX
the built in modulators are crap, do yourself a favor and get a hardwired one from a local electronics store and use the supplied mini jack to rca splitter. also install an on /off switch in line. i install about 10 of these per week, happens all the time. nobody is ever satisified with the wireless mod.
ieiscooby is offline   Reply With Quote
F/S XM Radio Roady 2 w/ 6 month subscription Car / Home Package $80 wrxnova1 MAIC Private Classifieds 1 06-25-2006 08:01 PM
FS: XM Roady Kit w/ extras $40 redobs New England Impreza Club Forum -- NESIC 0 06-21-2005 08:53 AM
FS (tn): XM Roady 2 DamnYank! Private 'For Sale' Classifieds 0 12-01-2004 05:54 PM
My XM roady 2 mount 2k2 Car Audio, Video & Security 0 11-01-2004 07:25 PM
XM Roady Installed LiquidIQ Texas Impreza Club Forum -- TXIC 8 05-29-2004 02:14 AM
