Old 12-30-2004, 02:11 PM   #1
scoobysnowrally
Member#: 76478
06 STI & Tribeca
Aspen Graphite
Default need help, weird light problems
yesterday I was pulling out of my garage when I turned my lights on and nothing happened.I turned them off then back on again and they worked. A few moments later down the street I turned my turn signal on and all my lights (headlights and dash) flickered off while making the relay sound. but then they worked again. Is this a possible short to ground somewhere
scoobysnowrally is offline   Reply With Quote
Old 12-30-2004, 02:16 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There may be something wrong with the headlight switch on the column stalk. If there is any time left on your 3/36 warranty have a dealer look at it.
Old 12-30-2004, 02:27 PM   #3
scoobysnowrally
Member#: 76478
06 STI & Tribeca
Aspen Graphite
Im at 34500 right know. do you think it would be advisable to take off the grounding kit and lightweight pullies before I take it in
Old 12-30-2004, 02:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I would never recommend removing mods before going to a dealer since that's a form of fraud. But you can do whatever you want.
However neither of those mods would have anything to do with malfunctioning headlights.
Old 09-01-2005, 02:42 AM   #5
rayw1128
Member#: 15800
2002 impreza wrx
platinum silver
I have the exact same problem on my 2002 WRX. It started about two weeks ago. Looked around the forums and many people with the same problem concluded that its a bad connection within the headlight/signal stalk.
Hopefully you can get that replaced under warranty. Let us know if that solves the problem.
rayw1128 is offline   Reply With Quote
Need help.. weird problems generalee69 Motorsports 32 06-14-2009 12:11 AM
Weird Light Problem mobilemidget Electrical & Lighting 0 03-14-2007 01:42 AM
help - weird coolant problem user06237 Newbies & FAQs 2 02-15-2007 02:17 PM
Quite a turnaround: I need Excel help, weird VB problem sonicblue Off-Topic 8 08-18-2006 11:26 AM
Help, WEIRD turbo problem. wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-10-2002 09:01 PM
