Old 02-20-2006, 02:25 PM   #26
some dude
Member#: 100300
06 WRX
CGM
I have an 06' WRX and the power wire going to the bulb is really short. When they installed in they wrapped it around some other input to the lock cylinder. I broke off on of the tabs on the plastic light housing. And I found out that the car will not stay running with the light housing off of the lock cylinder. My security light stayed on until i put it back on.
some dude is offline   Reply With Quote
Old 02-28-2006, 02:51 PM   #27
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I'd bet the new security key chip receiver is inside that light housing.
Alan is offline   Reply With Quote
Old 10-12-2006, 03:12 PM   #28
spritefiend
Member#: 101190
2016 WRX Limited
Default 2006 STi
I just did this last night on my 06 sti and it was slightly different than the posted directions.
the yellow circle shows where the bottom half is attached to the steering column.. the red circles are the 2 screw that hold the top half to the steering column.
remove them and you can lift the top half up; which makes it a hellova lot easier to remove the ring.
as stated earlier, the wire is reallllly short, and wrapped around another. its the green pair of wires, and after you remove the bulb from the ring, you can untangle it from the other connector, makes it a little easier to get around.
Hope this helps
John.
spritefiend is offline   Reply With Quote
Old 11-14-2006, 03:13 PM   #29
1st Scooby
Member#: 36395
2007 STI Ltd 159/800
"Urban Grey Metallic"
Thanks spritefiend...I have a 07 STi Limited. I will be diving into this tonight. great pics.
1 thing though.. not realted to your write-up, but what's with the damn Mitsu logo on the pert label on the ring? Damn it....hehehehe
Jim
1st Scooby is offline   Reply With Quote
Old 11-14-2006, 05:06 PM   #30
spritefiend
Member#: 101190
2016 WRX Limited
^ hahahhahahaha i never noticed that.
have fun with it, removing the top of the column will make it easier
John.
Old 11-30-2006, 05:38 AM   #31
06STIGO13
Member#: 110526
2007 STI Ltd 306 UGM
2008 STI Nav & BBS AW
Just wanted to bring light to another great write up, and Spritefiend, thanks for the MY06+ addition... that made all the difference. I was able to do the key ring mod (green --> red) as well as the cigarette lighter next to the aux in plug (also green --> red) so when my Ipod is plugged in that ring is now red as well. NASIOC ftw!
06STIGO13 is offline   Reply With Quote
Old 02-23-2007, 11:00 AM   #32
loudaccord
Member#: 99489
The Black Pearl
Yarr!!
Doing mine this weekend(06)... I gotta get my camera back and if I do, I'll take more pics
loudaccord is offline   Reply With Quote
Old 03-26-2007, 05:27 PM   #33
silverwolf
Member#: 47559
02 WRX
thank you so much! nice tutorial.
silverwolf is offline   Reply With Quote
Old 08-04-2007, 06:38 PM   #34
Sti King
Member#: 125594
Thanks alot for this.
Sti King is offline   Reply With Quote
Old 11-23-2007, 10:53 PM   #35
Spider96
Member#: 156059
2015 WRX
Crystal White Pearl
Don't know if anyone will still read this thread but I have a 2007 STI and can't get the ring out to change the bulb in the key ring. Any help would be appreciated.
Spider96 is offline   Reply With Quote
Old 11-24-2007, 10:21 AM   #36
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
On the newer ones (with the antenna in them for the key transponder) there is a screw which holds them in place - if you pull the covers around the steering column you should see it - then it comes off by opening up the clips on either side (which go around the "tabs" which stick out of the ignition cylinder) - where the keylight assembly is held onto one of the tabs, there is a screw (I forget which one) - I don't know if you can remove the bulb housing without removing the keylight assembly from the ignition cylinder - it's pretty cramped back there.
Old 11-24-2007, 01:32 PM   #37
Spider96
Member#: 156059
2015 WRX
Crystal White Pearl
Yeah, I can see that screw and there is NO way to access that screw without pretty much removing the wheel and all the **** behind it (windshield wiper controls, etc.)
Old 12-08-2007, 02:35 PM   #38
UTKaviator
Member#: 165102
2007 Subaru WRX Ltd
WR Blue Pearl :)
Default Blue 07 WRX
I replaced my 07 WRX with a blue LED in place of the factory one....works great! if anyone needs some info PM me
UTKaviator is offline   Reply With Quote
Old 12-08-2007, 02:37 PM   #39
UTKaviator
Member#: 165102
2007 Subaru WRX Ltd
WR Blue Pearl :)
another quick note, on the newer models (at least my 07), you dont need to pull the whole key ring light assy off, just twist and pull the bulb out....remove the little black piece that helps shroud and direct its light, then rotate the bulb about 90 degrees and it should come out....the use your condom, replace with LED, or whatever else...good luck
Old 12-11-2007, 05:06 PM   #40
Spider96
Member#: 156059
2015 WRX
Crystal White Pearl
The litle black piece comes right off? Any tricks to it?
Old 11-10-2008, 04:37 AM   #41
alex.rides.bikes
Member#: 151816
'05 STI
any specific part numbers for a red LED instead of just a bulb cover?
alex.rides.bikes is offline   Reply With Quote
Old 12-05-2008, 09:15 AM   #42
Jncominco2
Member#: 170212
NVM
found it
Jncominco2 is offline   Reply With Quote
Old 06-03-2009, 11:10 PM   #43
nti_hazard88
Member#: 212379
2011 WRX Limited 4dr
Spark Silver Metallic
holy sh**.. this is an old thread... does anyone know what bulb size it is? If I'm to do this, I'll probably just replace the bulb with a color of my liking.
nti_hazard88 is offline   Reply With Quote
Old 06-10-2009, 11:11 AM   #44
06mattsti
Member#: 174796
2006 STI
Parts-express no longer has the covers, I can't find them anywhere.
06mattsti is offline   Reply With Quote
Old 06-10-2009, 11:40 AM   #45
nti_hazard88
Member#: 212379
Just switch out the bulb for wide-angle LED's man. I've found out the proper bulb size now. For the key ring and gauge cluster, it's 74. The HVAC is #24 (slightly larger than 74, slightly smaller than 194 - people have been known to "shave" 194 to make it fit)
Old 06-11-2009, 02:53 PM   #46
W0R7Xsubi
Member#: 148853
99 Exploder/15 Foz
RIP Edwin *fingerpoint*
i need to do that asap
W0R7Xsubi is offline   Reply With Quote
Old 06-12-2009, 05:02 PM   #47
Rextion
Member#: 212790
2002 Built WRX
World Rally Bule
Would any of you have a spare key ring that you would be willing to sell to me??? My '02 WRX doesn't an illuminated key ring fail....
Rextion is offline   Reply With Quote
Old 09-22-2009, 10:39 PM   #48
alphaomega0
Member#: 147678
07 wrx
obsidien black
did you just put an led light or did you have to do any soldering ?
alphaomega0 is offline   Reply With Quote
Old 07-01-2010, 04:15 PM   #49
jdmimprez
Member#: 153318
08 EVO X GSR
<<<<<<< is doing this tomorrow!
jdmimprez is offline   Reply With Quote
Old 07-08-2010, 04:12 PM   #50
tyscat
Member#: 196438
2006 STI
Crystal Gray Metallic
This is excellent info. Can you provide a little more info on the type of bulb? For example, is the #74 one of the types listed here:
http://www.superbrightleds.com/cgi-b...ini-wedge.html
I think the option of installing a new bulb instead of a cover is a lot better (especially since red covers are not available anymore). Thoughts anyone?
tyscat is offline   Reply With Quote
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 03:24 PM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
Interior Color Change Tutorials by Trunk_Monkey munkis Electrical & Lighting 0 12-31-2004 09:56 PM
