Old 11-02-2010, 05:43 PM   #51
rallythenorthwest
Member#: 262747
2004 WRX
World rally Blue
is the #74 bulb for the keylight a twistlock bottom like the bulb for the stock turbo gauge?
rallythenorthwest is offline   Reply With Quote
Old 11-17-2010, 04:57 PM   #52
edreyes
Member#: 180496
2006 WRX STi
Originally Posted by spritefiend View Post
I just did this last night on my 06 sti and it was slightly different than the posted directions.
the yellow circle shows where the bottom half is attached to the steering column.. the red circles are the 2 screw that hold the top half to the steering column.
remove them and you can lift the top half up; which makes it a hellova lot easier to remove the ring.
as stated earlier, the wire is reallllly short, and wrapped around another. its the green pair of wires, and after you remove the bulb from the ring, you can untangle it from the other connector, makes it a little easier to get around.
Hope this helps
John.
Can you re-post or PM me the pictures?
edreyes is offline   Reply With Quote
Old 11-22-2010, 09:14 PM   #53
sti103
Member#: 248544
2005 STi
CGM
bump. need help with this on an STi
sti103 is offline   Reply With Quote
Old 01-03-2011, 07:44 PM   #54
93V
Member#: 249092
2007 STI Limited
UGM #507/800
does this only light up when the doors are open? while driving, mine isn't on. just curious. i have an 07 sti ltd.
93V is offline   Reply With Quote
Old 01-16-2011, 08:11 PM   #55
Legend STI
Member#: 41086
2015 Jeep Sahara
Great write up. Just replaced my key ring with the LED by pro driven auto. Matches my gauges perfectly. To 93V i noticed I had to really make sure the bulb was completely seated in order for it to light up. (Snaps down alot further than I initially thought.)
Legend STI is offline   Reply With Quote
Old 01-17-2011, 07:26 AM   #56
93V
Member#: 249092
2007 STI Limited
UGM #507/800
I have the stock one still in. When does yours light up? All the time?
Old 10-01-2011, 04:58 PM   #57
rjp4419
Member#: 292796
2014 STI
anybody have an updated diy? or info on what bulb is needed?
rjp4419 is offline   Reply With Quote
Old 10-02-2011, 06:47 PM   #58
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
I opened up my 04 WRX steering column and found the bulb. It is TINY.
Autozone, O’Riley, Checker, etc don't have bulbs that small. I was told to check with Radio Shack and maybe NAPA.
I’d like to figure out the bulb size/number... then I can ask for it more accurately in person, or just find a new one online. Maybe Subaru dealership parts departments could look it up...
djtoone is offline   Reply With Quote
Old 12-31-2011, 07:01 PM   #59
thorracing160
Member#: 304830
2004 STI
ummm i cant find were to get these condom covers...
thorracing160 is offline   Reply With Quote
Old 12-31-2011, 07:16 PM   #60
RSXNTN
Member#: 287358
2006 2.5i
Regal Blue Pearl
Its pretty tiny so depending on what color you're looking for you could probably just color the bulb with a sharpie.
RSXNTN is offline   Reply With Quote
Old 03-28-2012, 11:47 AM   #61
sytz
Member#: 291712
2006 WRX Wagon
Parts Express has stopped carrying the red .2 bulb covers... can't seem to find an alternative
sytz is offline   Reply With Quote
Old 04-15-2012, 06:58 PM   #62
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Any luck finding red bulb covers for the .2 bulb?
Old 07-12-2012, 10:41 AM   #63
Atombong420
Member#: 321612
1996 Legacy Outback
Original green
Autolumination.com has all the bulbs and covers. They have incandescent and LED bulbs and multiple colors of bulb covers
Atombong420 is offline   Reply With Quote
Old 07-19-2012, 07:23 PM   #64
SubieNubie88
Member#: 325391
2008 WRX
Default 2008+ key ring led
What is the bulb size for the Keyring light on the 2008+ WRX ?? Links would be awesome!
SubieNubie88 is offline   Reply With Quote
Old 07-19-2012, 07:29 PM   #65
LiCelsior
Member#: 182551
2004 STi
http://www.ebay.com/itm/110684296815...ht_1669wt_1396
done deal, super bright and fits perfect.
LiCelsior is offline   Reply With Quote
Old 07-19-2012, 09:41 PM   #66
SubieNubie88
Member#: 325391
2008 WRX
Thank you sir
Old 07-20-2012, 12:20 AM   #67
LiCelsior
Member#: 182551
2004 STi
not too sure if its the same for the 08wrx but dont see why not. just a simple little bulb.
Old 07-20-2012, 12:25 AM   #68
easterbran
Member#: 307359
'05 STi Stage II
easterbran is offline   Reply With Quote
Old 10-10-2012, 10:33 PM   #69
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Thanks for the info & web address!
Old 02-22-2013, 09:44 PM   #70
rally kid2174
Member#: 334187
05 subaru RS
black soon will be paintd
Default reply to ur how to topic
whAT size bulb is the key ring cos i want to do the same thing but get leds
rally kid2174 is offline   Reply With Quote
Old 10-21-2013, 05:41 PM   #71
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Does anyone have an updated link to where to buy those lamp covers/bulbs needed? They don't have them on the site where the original links point to.
mhs5074 is offline   Reply With Quote
Old 03-02-2015, 04:42 PM   #72
Cam Shaft
Member#: 405278
Originally Posted by MK19_ View Post
Question is- can you add a lighted key ring to a 2002-03????
What size bulb is it? I cant find anything on what kind if bulb it is.
Cam Shaft is offline   Reply With Quote
Old 04-21-2016, 04:22 AM   #73
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
It's a 74 led. Found at suberbrightleds for like 2-3 bucks.
Have had it in my STi for ever, no issues.
-Nigel
NewShockerGuy is offline   Reply With Quote
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 03:24 PM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
Interior Color Change Tutorials by Trunk_Monkey munkis Electrical & Lighting 0 12-31-2004 09:56 PM
