Old 03-31-2005, 04:59 PM   #26
antidote11
Member#: 31074
'06 WRX TR
CGM
Cool, thanks man, I just ordered 20 of the blue.
I just wanna do the Key Ring and the AC controls, so that should be plenty.
I figure I can double them up and have them look bluer
or I can cut a peice of deep blue lighting film and place that around the bulb, then put the condom on and see if that gives me a nice blue color. If not, then I will go with the red. Thanks again !!
antidote11 is offline   Reply With Quote
Old 03-31-2005, 06:49 PM   #27
FlyingFishSandwich
Member#: 54228
2005 Impreza PSM
rice bad, sleeper good
I have a diffrent radio. It's half the face size and just does CD and radio. I figure it would be basically he same on the inside but has anyone tried it? I'd like to know it can be done before I go cracking it open. If I get no replies by next weekend I'll dig in and try to get some pictures up.
FlyingFishSandwich is offline   Reply With Quote
Old 03-31-2005, 07:28 PM   #28
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Like I said, blue comes out teal, even "double bagged". The lighting film might help, the problem however is that the incancedent light emits naturally weird hues. I was set on blue, tried it, but then went to red.
I think this will be harder with an aftermarket radio, post pics of the faceplate, some things like LCD readouts color can never be changed.
Trunk_Monkey is offline   Reply With Quote
Old 03-31-2005, 11:00 PM   #29
FlyingFishSandwich
Member#: 54228
2005 Impreza PSM
This is the same radio but this guy's is silver. It came from the dealership but in my car the silver part is black. The radio you modded had an LCD, I just need to find out if it's or not right?
Old 04-01-2005, 07:07 AM   #30
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
The stock radio has a B&W LCD, just lit up by bulbs, some radios have sort of an indoglo in the LCD's which you cant change. Carefullly take it apart and see.
Old 04-06-2005, 11:47 PM   #31
WiCKedReX
Member#: 43763
02 WRX
BLACK
Trunk_Monkey
Did you use 4 .2" condoms for the HVAC?
WiCKedReX is offline   Reply With Quote
Old 04-07-2005, 01:19 AM   #32
DistractioN04
Member#: 84428
04 smokeurSTI
Java junk black
has anyone TRIED this on an 2004 yet??? im dying to, i just need to know exactly how many of what size i need and wheres the best place to order from? However, i dont want to get my hopes up if no 1 else has got 04 feedback... ill keep my fingers crossed
DistractioN04 is offline   Reply With Quote
Old 04-07-2005, 07:06 AM   #33
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
HVAC is do-able, click on the links at the top for where to get them, they should be the same sizes. As for the stereo i think the main LCD part will stay green, looking for some info from the new-gen guys too.
Originally Posted by WiCKedReX
Trunk_Monkey
Yes, two on each, anything else I can help you guys with?
Old 04-07-2005, 01:00 PM   #34
buymeasti
Member#: 24091
The pic for the trickiest part (soldering) comes up as a red X:
Otherwise, can you help me change my underpants? I took a corner too hot and pooped myself.
j/k - your DIY guide is pretty comprehensive. Thanks for taking the time to make the writeup.
buymeasti is offline   Reply With Quote
Old 04-07-2005, 01:00 PM   #35
buymeasti
Member#: 24091
Anyone have a link to do this on the 05's? Or how to do it on the window switches or any of the STi switches?
Old 04-07-2005, 04:13 PM   #36
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
buymeasti - the pic comes up fine for me, anyone else having a problem with the pic, also no specific 05 tutorial as of yet as I have no 05 take pics, examine, etc. Window and other switches are tricky, there is no good way of doing that as of now, I'll try and get a better way to do them, but again I have been pretty busy lately, so dont hold your breath.
Old 04-07-2005, 04:22 PM   #37
buymeasti
Member#: 24091
http://img87.exs.cx/img87/9356/hvac130bq.jpg
That's the one that won't load, and if I try to put it into my browse I get a server not found error.
Old 04-07-2005, 04:29 PM   #38
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
If i click, it comes up fine... anyone else having this problem ?
Old 04-07-2005, 04:31 PM   #39
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Downloaded it from the link and re-uploaded it, should work fine...
Old 04-07-2005, 04:33 PM   #40
buymeasti
Member#: 24091
That works on my end now.
Now for the underpants....
Old 04-07-2005, 04:38 PM   #41
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
You wish...
Old 04-07-2005, 07:28 PM   #42
UKscooby
Member#: 33287
RIP Nik
I will always miss you
When I did this a few years ago, I did the whole car with blue led's. I then changed the button areas on the radio to yellow leds. So now the guages are backlit blue with yellow needles, and the radio lcd is blue with yellow buttons.
I also designed a boost guage to fit in the Subaru din pocket that fits where the clock goes. This was blue 7 segment led too.
CNC machined housing I had done....
UKscooby is offline   Reply With Quote
Old 05-02-2005, 01:47 AM   #43
Max Umbarger
Member#: 1112
2006 FXT
RBP
blue-yellow looks sweet!
Max Umbarger is offline   Reply With Quote
Old 05-02-2005, 11:09 AM   #44
128d
Member#: 7792
2002 Prodrive
widebody Cosworth 2.5 6sp
Those red bulb covers will fade over time to a peach color.
128d is offline   Reply With Quote
Old 05-02-2005, 04:51 PM   #45
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
From my experiance you only get a peach color when they are not put on properly or slip off, have had mine for quite some time now.
Old 06-26-2005, 11:31 PM   #46
kicking1012003
Member#: 73435
2004 Subaru WRX STi
WR Blue two tone w/ CF
kicking1012003 is offline   Reply With Quote
Old 08-17-2005, 01:58 PM   #47
johnnywu
Member#: 73562
05 doh mah
ILikeGurlsThatLikeGurls
i just tried..... no go for me!
it seems that the green color is from the actual faceplate of each button. the faceplate button that lights up green is actually green painted over with grey. unless theres a way to clear colored plastic then im outta ideas. but besides that popping everything off wasnt so bad. pretty self explainatory.. the LED that lights up the buttons are clear
**edit**
second thought.... assuming the STI's are put together the same way i dont know why we cant just get the buttons from an sti pop them in and call it a day?
any takers?
~jwu
johnnywu is offline   Reply With Quote
Old 10-16-2005, 10:05 PM   #48
DaveDangerous
Member#: 44262
06 EVO MR
GG
Default Mdded HU for sale
I have an 04 rex and decided to play with the HU cuz i just installed a clarion HU. The buttons aren't green I held the face up to a red light and the light came through. When I get the bulb covers on and put it all back together, I''ll take some pics. BTW the HU is also for sale
Dave
DaveDangerous is offline   Reply With Quote
Old 10-20-2005, 05:26 PM   #49
Cautiontext
Member#: 74848
07 BMW 335Xi
Nice...
Cautiontext is offline   Reply With Quote
Old 10-22-2005, 03:33 AM   #50
Tada
Member#: 96360
Dude i was just working on this tonight and no matter what i did the bulb condoms did turn to a peach color even after i put them back on... i wish i remembered where the green ones are becuase i want to go back to stock, it doesn't look as good in orange
Tada is offline   Reply With Quote
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 03:24 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Instrument Cluster, Radio, and HVAC color change murph32 Electrical & Lighting 7 08-11-2008 03:50 AM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
