Old 05-23-2007, 04:00 AM   #101
MAVR3X
Member#: 149576
1997 GF8 STI WRX
Hmm, have to try this one.
MAVR3X is offline   Reply With Quote
Old 05-26-2007, 08:02 PM   #102
impreziveWRX521
Member#: 47113
2002 impreza wrx
wrb + carbon fiber
i changed the radio, hvac, and guage cluster lights today. i then started the car, and there was smoke coming from behind where i put the covers over the lights. has anyone else experienced this? also could it become a problem?
impreziveWRX521 is offline   Reply With Quote
Old 05-27-2007, 01:29 AM   #103
biker921
Member#: 118236
Crap..!
biker921 is offline   Reply With Quote
Old 05-27-2007, 10:38 AM   #104
Mechie3
Member#: 120152
Youlet the magic smoke out! Chances are some bare wires touched, things got hot, and you either burned out a capactitor, or something. I would take it all apart, make sure there are no bare wires that weren't there before/etc and put it back together. It could have just been finger oils or something short circuiting and smoking.
Mechie3 is offline   Reply With Quote
Old 05-27-2007, 05:41 PM   #105
impreziveWRX521
Member#: 47113
2002 impreza wrx
wrb + carbon fiber
i didn't cut, or change any of the wires around, only unclipped them. oils from my fingers could be a possibility though. i'm going to take it apart and check all the lights and wires. hopefully nothing is damaged.
Old 05-31-2007, 03:50 PM   #106
impreziveWRX521
Member#: 47113
2002 impreza wrx
wrb + carbon fiber
ok i put it all back together, and now the fuel, temp, and spedometer don't work. i looked at all the wiring, checked all the connections, and they just dont work.
the tachometer DOES work, but thats it. is there anything else i should look for, or is it time to start looking for a new gauge pack?
Old 06-01-2007, 08:32 PM   #107
biker921
Member#: 118236
OK, I had a problem with the right parts. I got different answers from different people and had to trust someone. I trusted the wrong person and ordered the LED's you see below. I took the green condoms off but am at a fork in the road. I can't decide to use red condoms or use the right red LED's. Can I get some answers as to the proper part numbers and some testimonials???
Old 06-01-2007, 09:25 PM   #108
Mechie3
Member#: 120152
Take the back off of your gauges and look at the circuit board. Look specifically for burned components. If you see some, you might need a new board. You dealer might be able to order the board separately to save you some money IF that is what happened.
Old 06-06-2007, 10:15 PM   #109
biker921
Member#: 118236
bump for help
Old 06-08-2007, 03:37 AM   #110
Celtric
Member#: 150403
2004 Impreza WRX
Originally Posted by biker921 View Post
bump for help
Biker, Why dont you try Radial Ultrabright Leds (175 Degrees viewing angle)
I placed 8 leds with a viewing angle of 60 but thats not good enough, i still have hotspots or places where its completely dark.
Im gonna try the 175 leds within a week, although they need a 470 ohm resistor.
LEDS will be a better solution i think, its bright and clear... im going for the color blue ( the most difficult color i think ) thats why i want to use leds, the condoms are just aqua and not really blue.... choice is up to you.
Celtric is offline   Reply With Quote
Old 06-08-2007, 09:28 AM   #111
biker921
Member#: 118236
I'm feeling really retarded right now. I bought some led's that are just the two thin wires at the end, but they are replacing bulbs that had the wires wrapped around the bottom of the bulb itself. I don't know if that really makes sense to you. Do you have an exact link to show me the bulb that will fit?
Old 06-08-2007, 05:00 PM   #112
Celtric
Member#: 150403
2004 Impreza WRX
I bought 3mm 12v leds with build in resistor, they dont really fit into the neo wedge top hole... i just keep them on top of it. Did this with the fog light switches. I dont really mind, just want to see blue light.
The hvac lights will be 5mm leds, so they wont fit too.. ill figure something out, try to be creative.
If you need help just ask
Old 06-15-2007, 05:04 PM   #113
Celtric
Member#: 150403
2004 Impreza WRX
What the hell... just changed almost everything
Old 06-17-2007, 06:06 PM   #114
sjs0433
Member#: 86061
I like^. what'd you use to get those results. Think it could be done in white?
sjs0433 is offline   Reply With Quote
Old 06-17-2007, 08:45 PM   #115
biker921
Member#: 118236
I'm sure it could be done in any color
Old 06-18-2007, 02:20 AM   #116
Celtric
Member#: 150403
2004 Impreza WRX
Yes, could be done in any color you want, be sure to use the right leds ( Minimal 175+ viewing angle and bright!)
For the glovebox,cigarette lighter and ashtray.. same leds! Just pull the old bulb out of the socket and cut the wires ( be sure theres no power on it )
I pushed the led into the socket, solder the wire and resistor (if needed).
Now you can still use the old wedge thingy so the led will stay in place just like the old bulb.
As for the foglight buttons, i had to think for a solution here!
You can see the picture below how i solved this with my leds :
The results are GOOD & bright !
As you can see i used a red bulb (not with a condom) if the foglights are on .
These leds run on 3.4 Volt 20mA (473nm / 150mcd) 5mm waterclear.
I used a 470 Ohm resistor.
Btw, i sanded off the green firm from the foglight buttons.. when i´m about to do the instrument cluster ill try without sanding first.
Old 09-07-2007, 06:10 PM   #117
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
on the doors is there any threads on how to change them from green to red?
Thanks!
Fast_Wrx62 is offline   Reply With Quote
Old 09-10-2007, 07:59 AM   #118
jma_1000
Member#: 151694
did anyone figure out how to make this work on later models? MY07 has a green plastic cap painted grey on the HVAC controls, will nail polish remover 'lighten' the plastic enough to let red through? right now it looks brown, and nasty.
jma_1000 is offline   Reply With Quote
Old 10-31-2007, 11:39 AM   #119
cXc5120
Member#: 157497
2003 WRX
Does anyone have any ideas on how to change the gauge needles? I have a 03 so they are yellow, I would really like them either red or blue.
Thanks
cXc5120 is offline   Reply With Quote
Old 10-31-2007, 12:44 PM   #120
Mechie3
Member#: 120152
Instructions for the automatic HVAC (red is the only color that works well):
http://forums.nasioc.com/forums/show...t=270+resistor
Gauges needles can't be changed. The needles themselve are a yellow plastic.
Old 12-26-2007, 07:04 PM   #121
orwrx
Member#: 33869
2002 wrx
rally blue
I read throught the whole 5 pages and can't really figure out what led replacement I should buy since ppl have different year WRX and STI. I have MY02 WRX and I just want to change out the HVAC green to red. Someone posts a links to what size/model led bulb I should get to replace them. Do I need to wire a resistor to it? I'm not a electrical guy, don't flame haha. Just need help!
orwrx is offline   Reply With Quote
Old 01-14-2008, 02:59 PM   #122
simprezl25
Member#: 71647
2002 Bug iD
i just ordered my condoms!
here is the correct page for those who are looking for the red bulb covers/condoms.
http://www.partsexpress.com/webpage....TOKEN=53809745
i ordered 2 packs of .12 and 1 pack of .2 red
packs have 10.
enjoy
simprezl25 is offline   Reply With Quote
Old 01-14-2008, 03:17 PM   #123
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
I just ordered the condoms, can't wait to do this
pDubs is offline   Reply With Quote
Old 01-14-2008, 04:30 PM   #124
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Anyone done this on a GF? I can't even get my damn HVAC out.
Also where do you kids get the wide-angle LEDs?
XanRules is offline   Reply With Quote
Old 01-14-2008, 06:55 PM   #125
orwrx
Member#: 33869
2002 wrx
rally blue
packs have 10.
enjoy
Willing to hook up a fellow member for 4X .2 red condom that you don't need,
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 03:24 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Instrument Cluster, Radio, and HVAC color change murph32 Electrical & Lighting 7 08-11-2008 03:50 AM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
