Old 03-24-2009, 09:37 PM   #201
d0ugch0i
Member#: 198861
2004 WRX
guess no help....really wanted to do this.
d0ugch0i is offline   Reply With Quote
Old 03-24-2009, 09:59 PM   #202
jma_1000
Member#: 151694
i ended up using red model paint on the radio. looks really good, and i will be switching the gauges to red paint also. havent mustered up the gall to wire LED's in the HVAC yet. but for your car, you can probably paint them too.
jma_1000 is offline   Reply With Quote
Old 05-28-2009, 03:30 AM   #203
je255j
Member#: 202284
The HVAC controls on the '08-? Impreza, I just disassembled, and it turns out they are illuminated by two tiny white light bulbs - which is to say, not LEDs, so they have a slight yellowish tint. The light from these two bulbs is spread out via a translucent piece of specifically curved red plastic, and then the backs of the HVAC dials are also painted red.
So, if I want to make these any color other than red (and I do), I'd have to remove that red paint first. This can be done with a Q-tip and nail polish remover, correct?
Then I'd have to discard that red plastic piece, which will unfortunately cause the light to be spread non-uniformly, and that's sort of a bummer, but not necessarily a deal-breaker. I mean, what else am I going to do? It isn't like I can just make another one of those made out of clear plastic.
And, lastly (almost), I'd have to replace those two white bulbs with LEDs. That's probably the only easy part of the entire process, and even it won't be that easy, as I didn't see how to even remove those. They should screw out easily enough, if I could expose the back of them.
How does one remove a HVAC control panel from a car, any car, with those metal cables attached to it? It seems pretty tightly tethered in place.
Finally, though it's really not important, I'd also love to replace (or have replaced for me, rather) the red LED for the AC on/off button, and that's soldered to that circuit board. That light totally should've been blue, and I truly have no idea why it's not.
Sigh.
It looks like getting rid of all this red lighting (which I really want to do!) might not be possible. Or, at least, it sure as hell won't be cheap.
je255j is offline   Reply With Quote
Old 06-04-2009, 12:30 AM   #204
nti_hazard88
Member#: 212379
2011 WRX Limited 4dr
Spark Silver Metallic
Alright, I've been reading several threads, but I can't seem to get a 100% confirm. What exactly are the bulb sizes I am looking for?
HVAC: ?
Gauge Cluster: ?
Keyring: ?
anyone?
nti_hazard88 is offline   Reply With Quote
Old 06-04-2009, 04:38 AM   #205
Subiebobby
Member#: 181046
2002 wrx wagon
psm aps s/r55, meth 6 spd
i like and i want!
Subiebobby is offline   Reply With Quote
Old 03-12-2010, 07:47 PM   #206
anthony_delprete84
Member#: 88254
Originally Posted by antho! View Post
here's a link to where i got my bulb covers, hope this helps someone!
link!
T1 = 3 mm diameter
T1 3/4 = 5 mm diameter
Just ordered some of these. Will post some pics when I'm all done. Ill be doing the key ring, OEM boost gauge, and hvac to red with the bulb cover method.
anthony_delprete84 is offline   Reply With Quote
Old 03-13-2010, 03:39 AM   #207
antho!
Member#: 159057
2004 ts wagon
aspen white
HVAC: ?
Gauge Cluster: ?
Keyring: ?
anyone?
should've read this one http://forums.nasioc.com/forums/show...11&postcount=4
and because i'm a nice guy...
gauge cluster: 8 x 5mm (T1 3/4) and 4 x 3mm (T1)
04 hvac: 2 x 5mm
keyring: 1 x 5mm
you're welcome...
antho! is offline   Reply With Quote
Old 08-15-2010, 01:16 PM   #208
rouckey21
Member#: 148207
02 WRX
PPG box'd
link!
T1 = 3 mm diameter
Thanks antho!! ordered and installed. Was a little worried b/c in the baggy they looked orange but in the car red
rouckey21 is offline   Reply With Quote
Old 08-18-2010, 09:20 PM   #209
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
i have done this mod to my 07 over a year now.. done it all by myself.. the hvac , the windows switches , replaced my cluster with an sti one..basically everything is converted into red... and it looks awesome..
you just need some soldering skills for the hvac
hadi10 is offline   Reply With Quote
Old 08-19-2010, 02:46 AM   #210
tahoebru
Member#: 242528
2006 Impreza
CGM
It seems that Parts Express no longer stocks the red bulb covers, but I found another resource, Electronics Plus.
However, they list the covers as .125" inside diameter (1/8") x .187" outside diameter (3/16")
Are these the same as the covers that you've used? They also list ones with a .125" outside diameter.
Just want to make sure to order the correct size so any help will be appreciated!
tahoebru is offline   Reply With Quote
Old 09-16-2010, 05:00 PM   #211
CabinBoyy
Member#: 252271
02 Impreza WRX
platinum silver
Default clock conversion
hey have you done the clock conversion yet? send me the link if you have
CabinBoyy is offline   Reply With Quote
Old 09-23-2010, 11:19 AM   #212
brianglawson
Member#: 229468
2004 Impreza WRX STI
So in order to do just my HVAC, my OEM Boost Gauge, and My Key ring, i would need about 8 .2 covers?
What about the window switches??
brianglawson is offline   Reply With Quote
Old 12-10-2010, 11:59 PM   #213
Legend STI
Member#: 41086
2015 Jeep Sahara
anyone know where to get the red codom light covers from? Parts express no longer carries them.
Legend STI is offline   Reply With Quote
Old 12-11-2010, 12:47 AM   #214
quicksubie
Member#: 221140
2005 hybrid=fun :-D
93 L 2.5rs rally preped
Autolumination.com sells led bulbs that have up to 5 LEDs a bulb on them if you go to the site then scroll down look for the #74 bulbs click there those should fit they are wedge style bulbs.
I know this cus I changed my gauge cluster with them :-) (in my 05 Wrx)
quicksubie is offline   Reply With Quote
Old 12-11-2010, 12:59 AM   #215
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
how to replave HVAC color on 05 WRX?
Fat Black Pig Sac is offline   Reply With Quote
Old 12-11-2010, 01:27 AM   #216
quicksubie
Member#: 221140
2005 hybrid=fun :-D
^^^ sorry
Take hvac controls out, locate bulbs, fig out how many it takes I'm going to guess two or three. Go to autolumination.com scroll down look for #74 click then buy the color and how many LEDs per bulb you want. Wait for shipping then install, sit back and enjoy your new colored hvac controls
Old 12-11-2010, 02:28 AM   #217
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
05 model has different type of bulbs, they are really small with 4 connectors and require precize soldering
Old 12-11-2010, 12:18 PM   #218
quicksubie
Member#: 221140
2005 hybrid=fun :-D
^^ for what part the hvac?
Old 01-04-2011, 12:25 AM   #219
inszelesta
Member#: 178876
2002 wrx
sti blue
Thanks for the idea will try
inszelesta is offline   Reply With Quote
Old 01-06-2011, 03:48 AM   #220
jma_1000
Member#: 151694
i just re-did my gauge cluster the other day and took all the red condoms out. they didnt look very good, anyways. i cleaned up all the green and black filament coating with nail polish remover and sandpaper, then used a salmon red stage gel. you can find them at any stage lighting/equipment place. it looks infinitely better than before, and the color is clean.
Old 01-12-2011, 10:43 AM   #221
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
Wink
Originally Posted by WRXDilettante View Post
This doesn't work on the '06-'07 WRX HVAC. They changed to surface mount LEDs. Each knob has 3 white and 1 orange. The plastic that the knobs are made of is actually tinted green with silver/grey paint on the face. Even if I change the white LEDs I doubt I'll end up with the color I want. Any ideas?
just replace the LED's with red one's and it will work trust me .
Old 04-04-2011, 05:17 PM   #222
93V
Member#: 249092
2007 STI Limited
UGM #507/800
anyone have an update on whether or not there are instructions for 07 cars?
93V is offline   Reply With Quote
Old 04-09-2011, 12:21 PM   #223
obsaidian scooby
Member#: 276966
2005 wrx
Obsidian Black Pearl
would this work or does any one have a diy of this for a 05?
obsaidian scooby is offline   Reply With Quote
Old 05-06-2011, 04:36 PM   #224
Turbedsti
Member#: 213753
2004 WRX STI
Platinum silver metallic
I just did mine because they were missing ordered from autolumination.com got 5 bulbs with holders and already had red bulb condoms on them,for $13.47 shipped.They look like the stock piece,10mmx3/8 19mm tall.Fit perfect look very good.And only took like 3 days to get.
Turbedsti is offline   Reply With Quote
Old 07-17-2011, 09:34 PM   #225
cam07
Member#: 284006
2007 Wrx Tr Stage 2
Great info! I wasn't sure how to get those bulbs out and I really didnt want to break them. Question tho, the light in the ring around the 12v plug is a smaller led compared to the regular bulbs. Obviously you can buy the regular bulb covers anywhere, but where can I pick up those smaller bulb covers that fit that light??
cam07 is offline   Reply With Quote
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 04:24 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 05:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 08:02 PM
Instrument Cluster, Radio, and HVAC color change murph32 Electrical & Lighting 7 08-11-2008 04:50 AM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 03:52 AM
