Old 05-26-2006, 09:36 PM   #451
WejR20X
Member#: 58101
Originally Posted by pt435
hi , i am preparing the photo shoot and will be posting the pic soon.......
stay tune!!!
i hope that means you're making a tutorial on how to do this.
WejR20X is offline   Reply With Quote
Old 05-30-2006, 02:26 PM   #452
WejR20X
Member#: 58101
bump for some updates...
Old 06-01-2006, 03:02 AM   #453
The an$wer
Member#: 113656
05 STi
wrb
Just posting so i get the email once you post those pics
The an$wer is offline   Reply With Quote
Old 06-01-2006, 07:36 PM   #454
marcus.raw
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
/subscribe
marcus.raw is offline   Reply With Quote
Old 06-02-2006, 06:42 PM   #455
darroj
Member#: 113645
2004 PSM WRX
Stage 1ish
Note for anyone doing this on an 04 - few things I ran into.
-When sanding, use a thick durable tape, but I wouldn't recommend duct tape, to cover up the areas such as highbeams, turn signals, you know, the other stuff that isn't actually a gauge. I used painters masking tape (blue) and a layer of normal masking tape over it. That way I could tell how much I had removed already from the sanding and if I need more tape to protect it.
-When sanding the speedometer and tackometer, be careful about the little clip that's around the needles. Either carefully bend the edge and try masking it off or just be sure to stay away from it. I had to glue one of mine back on
-For some of them, I'd recommend just gently bending the plastic up (move the needle out of the way so you don't stress it) and really getting at it with the sand paper. It will save you a lot of time and you won't need someone to help you with those portions of the sanding.
happy sanding
darroj is offline   Reply With Quote
Old 06-06-2006, 05:51 PM   #456
Pimpn'06
Member#: 112626
2006 2.5i impreza
Regal Blue Pearl
i bow to you.
Pimpn'06 is offline   Reply With Quote
Old 06-12-2006, 11:42 PM   #457
rudy_t2004
Member#: 77017
Question
So here is my delima, I have an 05 WRX and basically took the green off of the plastic hopeing that it would light up White. To you all that have done this you know it comes out an orangish color. I dont mind that but what is making me furious is that half of my speedo which is on the right hand side of the cluster is dim (hence for some reason or another it isnt a hot spot). Are there any suggestions.
Thanks in advance,
Rudy
rudy_t2004 is offline   Reply With Quote
Old 06-12-2006, 11:46 PM   #458
Handsdown
Member#: 29355
it's because there's no bulb there. you need to install another bulb. just read through the thread.
Handsdown is offline   Reply With Quote
Old 06-16-2006, 05:04 PM   #459
wrx23x
Member#: 103370
2006 STi
cgm
How do you get the needles so bright? Mine came out very dim and i can barely see them at night.
wrx23x is offline   Reply With Quote
Old 06-26-2006, 06:16 PM   #460
Keif
Member#: 107302
so has anyone done this with red and had it actually come out good, i wanted to do it at first but after reading tyhrough the first 10 pages it seemed like all the pictures looked like crap
Keif is offline   Reply With Quote
Old 06-26-2006, 06:45 PM   #461
npietran
Member#: 115517
I ordered some red lighting gels and am going to give it a shot with that. I also have some bright leds that I'll try if it comes out too dark. Will keep everyone posted on how it comes out.
npietran is offline   Reply With Quote
Old 06-26-2006, 09:01 PM   #462
The an$wer
Member#: 113656
05 STi
wrb
i did mine blue, looks nice but i cant realy see my needles at night... any solutions?
Old 06-27-2006, 03:31 AM   #463
Handsdown
Member#: 29355
what color are you doing?
my needles are bright yellow because they're lit by white bulbs. if you try to light the needles with LEDs in the stock locations, they won't be bright. if you try to light them with colored light(that isn't green or orange), they also won't light. put some white bulbs behind them, they'll light up better.
Old 06-27-2006, 03:33 AM   #464
The an$wer
Member#: 113656
05 STi
wrb
How do you do that?
Old 06-27-2006, 03:36 AM   #465
Handsdown
Member#: 29355
basically i'm running clear incandescent bulbs in the stock bulb holders, but i'm using red stage gels in place of the green film(which i scratched off a while ago), directly on the back of the guage faces. the light's white inside, but it gets filtered to red before illuminating the guages. the needles then light up yellow because that's their color. it's really the best way to do it- i've tried replacement LED bulbs, LED circuits wired in behind the faces, and bulbs with colored condoms on them, and it's really just too much of a hassle with all the problems. i'd strongly urge people do to their coloring with stage gels and use density filters/diffusers in order to tone down the highlights, because there will be hotspotting.
Old 06-27-2006, 02:39 PM   #466
npietran
Member#: 115517
That's what I figured but I didn't want to say anything until I actually tried it. With stage gels you can always fix bright spots by adding another layer or diffusing the light a bit at the hot spot with a piece of normal printer paper.
Will post my results if I ever get my gels
Old 06-27-2006, 02:56 PM   #467
The an$wer
Member#: 113656
05 STi
wrb
Where do you buy stage gels? Any locals stores carry them?
Old 06-28-2006, 02:32 PM   #468
npietran
Member#: 115517
ebay - I could have gotten gels locally but wanted specifically
apollo bludgen red AP8350 gels (google it, I can't post links until I have more posts) and couldn't find them anywhere but the net... Taking forever to ship though
Old 07-06-2006, 10:45 PM   #469
beat22
Member#: 113763
15 sti launch
04 wrx wrb
can anyone tell me where i can pick up a temp/fuel part of the cluster?....im one of the unlucky that fuxor'd it up.... its coming along nicely though
beat22 is offline   Reply With Quote
Old 07-13-2006, 12:28 AM   #470
zags13
Member#: 116305
05 WRX
Default 05 wrx
hey, i just want to make sure i ordered the right covers. i want to end up doing the cluster, radio/climate control and fogs (etc) and maybe windows. will 20 of the .2 and 20 of the .12 be enough???? im going with a darker green, so idk if ill need to double up any of the lights.
thanks in advance
zags13 is offline   Reply With Quote
Old 07-23-2006, 12:08 PM   #471
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
bump for anyone who can help us 06 owners do this if there any differences between 06s and the previous years. i want blue like pt435!
roccer is offline   Reply With Quote
Old 07-23-2006, 12:31 PM   #472
nuclear
Member#: 100304
I've already done this on an '06. It's likely no different but feel free to search for posts made by me for pictures of the cluster.
nuclear is offline   Reply With Quote
Old 07-23-2006, 02:30 PM   #473
BLK REX
Member#: 102673
2000 Legacy GT LTD
Is it the same process to change the color in an STi?
BLK REX is offline   Reply With Quote
Old 07-23-2006, 03:13 PM   #474
e28fixer
Member#: 25037
The individual cluster components are available from the dealer for reasonable money. That's probably cheaper than picking up a used complete cluster but shop around.
e28fixer is offline   Reply With Quote
Old 07-26-2006, 08:07 PM   #475
thexxshogunxx
Member#: 119010
2004 wrx
wrb
Did anyone have any trouble with the needles while doing this? I think i might of not been careful enough with them. They are not alligned correctly. I would like to know if anyone out there had the same problem and knows how to fix it. If there is no way of fixing it, then i guess i will have to purchase a new one. But that is my last option.
Thanks for the help!
thexxshogunxx is offline   Reply With Quote
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
