Old 09-24-2008, 12:06 PM   #626
Jus Blaze
Member#: 129428
2002 Wrx
Let say I wanted to wire up some extra blubs to brighten up the dim spots. Anyone know where or how to set these up? Specifically, where can I tap the power from?
Jus Blaze is offline   Reply With Quote
Old 11-11-2008, 09:21 AM   #627
icehockey101
Member#: 192929
1993 Impreza
I have a 93 Impreza wagon, and im wondering which lights I would use... Ive been looking online and im finding all these replacement gauge LEDs.... can you give me advice on which light cover u listed is correct for my car? or do I need the gauge replacement LEDs?
icehockey101 is offline   Reply With Quote
Old 12-05-2008, 12:13 AM   #628
mikeb01453
Member#: 184914
2005 Impreza WRX
Stage 2 WRB
i was wondering if any of you guys have done the condom light mod, if so have you had an issue with not seeing the needles, and i also have a smell of burning which im not to keen about...BTW i have an 05 wrx and i bought the blue condoms, thanks for your help guys
mikeb01453 is offline   Reply With Quote
Old 12-10-2008, 01:19 PM   #629
boardinshorty81
Member#: 174965
07 WRX VF43
If you remove the film and just leave the lights then is it white? I am looking for white with red needles.
Also is this the same for an 07?
boardinshorty81 is offline   Reply With Quote
Old 12-23-2008, 12:08 AM   #630
MNsuby
Member#: 186530
02 Bugeye
MBP
why when i changed my cluster to red does the blinker lights light up
MNsuby is offline   Reply With Quote
Old 12-27-2008, 12:45 AM   #631
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
I am almost finished with this project. When I get it all in my car, I will post pictures. I did everything the OP said to do. It is working out awesome!
emsmap is offline   Reply With Quote
Old 12-27-2008, 12:55 AM   #632
Handsdown
Member#: 29355
the bulbs in pre-08 are so small and dim that they glow a yellow-orange. to get white you need different bulbs/lightsource.
Handsdown is offline   Reply With Quote
Old 01-06-2009, 06:46 PM   #633
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
alrite I did this mod last week but I took the gauges out. I got everything back together and it looks really nice but my speedo and tach wont work!!! I plugged them in good and tight but they just sit there! Anyone have any suggestions?
Old 01-06-2009, 07:04 PM   #634
Jncominco2
Member#: 170212
i dont think they are pushed in all the way
Jncominco2 is offline   Reply With Quote
Old 01-06-2009, 08:14 PM   #635
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
I'm not too sure if it's the same with your 02' or not. Check to see if the "top hat" type black pieces under the speedo and tach are completely down. When lifting up the gauge faces, you may have pulled them up a little and they may just need to be seated again.
Psyk is offline   Reply With Quote
Old 01-06-2009, 09:22 PM   #636
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
I really appreciate it guys!! Ill check tomorrow!
Old 01-07-2009, 06:47 PM   #637
azreal
Member#: 42042
2003 WRX
Graphite Mica
sorry for the hijack but if i just wanted to replace the cluster with an STI one, is it plug and play?
azreal is offline   Reply With Quote
Old 01-07-2009, 09:25 PM   #638
blu04wrx
Member#: 155398
2004 impreza wrx
wrb
does anyone know af a different site that carries the .12" diameter red covers? the linked site only carries the .2" dia. and discontinued the .12" red covers. thanks in advance
blu04wrx is offline   Reply With Quote
Old 01-07-2009, 11:14 PM   #639
Jncominco2
Member#: 170212
we have an STI cluster thread, use it
your answer can be found there
Old 01-08-2009, 04:31 AM   #640
Handsdown
Member#: 29355
just to let you know,
this is my cluster:
it looks pretty even cept for the 70...
because of photo exposures, lights like the cluster look more even than they really are. you really have to see things in person.
Old 01-13-2009, 06:07 AM   #641
Handsdown
Member#: 29355
i just got to thinking...
if i wanted to, i bet i could solder the pots around and switch the faces so i'd have a center tach.
it would probably be balls difficult, but i can't think of a reason why it wouldn't work. of course, the faces would need to be cut to **** and then repositioned.
probably makes more sense to just get an 04 cluster.
Old 01-13-2009, 09:55 AM   #642
Jncominco2
Member#: 170212
um, i really really highly doubt that would work
it wont work
Old 01-13-2009, 03:40 PM   #643
Subiepde
Member#: 167673
2006 Impreza WRX
Metallic Silver
Also what im wondering I cant seem to find any red .12 bulb covers. Just need the 4 already have the .2
Subiepde is offline   Reply With Quote
Old 01-14-2009, 06:56 AM   #644
Handsdown
Member#: 29355
it wont work
well i mean they have those pins that the needle motors sit on, if you just crossed one to the other why wouldn't it work? too sensitive, would the extra wire throw it off? that's the only reason i can see it not working provided the soldering could be precise enough.
Old 01-24-2009, 09:28 PM   #645
FCPremixx
Member#: 181184
2016 Forester XT
CWP
How often do people end up with gauges that don't work after attempting this mod? I really want to do it but i'm afraid to mess up my gauges. Also as stated above where can you find some .12" bulb covers? www.partexpress.com discontinued the red.
FCPremixx is offline   Reply With Quote
Old 01-25-2009, 01:18 AM   #646
Handsdown
Member#: 29355
don't do it!
it's not worth the risk and devaluing. stay green. i wish i did.
Old 01-25-2009, 11:28 AM   #647
FCPremixx
Member#: 181184
2016 Forester XT
CWP
Handsdown.....the picture above of your cluster looks pretty good. How come you don't like it? Also what method did you use?
Old 01-29-2009, 12:47 AM   #648
Sudaka
Member#: 199521
02 WRX
SILVER
I have an 02 wrx, can anybody please tell me how many leds I need for the cluster and how many I need for the radio and hvac....oh yea and what size please? I might be wrong but hvac and cluster might be different size..
thanks
Sudaka is offline   Reply With Quote
Old 02-11-2009, 09:38 PM   #649
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
thanks for the help
jeremywrx15554 is offline   Reply With Quote
Old 02-11-2009, 10:26 PM   #650
Handsdown
Member#: 29355
that's to prove a point that an uneven cluster looks even when photographed.
i don't like mine because it's not all that even.
i used stage gels and clear bulbs and the original sandpaper method.
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 04:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 05:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 08:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 03:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 04:08 PM
