Old 02-11-2009, 09:49 PM   #651
Sudaka
Member#: 199521
02 WRX
SILVER
Originally Posted by Handsdown View Post
that's to prove a point that an uneven cluster looks even when photographed.
i don't like mine because it's not all that even.
i used stage gels and clear bulbs and the original sandpaper method.
what number gel did you use?............I like that red
Sudaka is offline   Reply With Quote
Old 02-11-2009, 10:48 PM   #652
Handsdown
Member#: 29355
oh i don't remember. i went to a theater supply store and got the deepest reddest one i could still see through clearly. it was years ago.
Handsdown is offline   Reply With Quote
Old 02-23-2009, 12:56 AM   #653
CPU GUY
Member#: 203347
07 STi
Thank u
CPU GUY is offline   Reply With Quote
Old 04-07-2009, 01:37 PM   #654
alphaomega0
Member#: 147678
07 wrx
obsidien black
Originally Posted by Trunk_Monkey View Post
Im not familiar with the effects of carb cleaner on plastic, the film is plastic and its sort of sandwiched in plastic, so the carb cleaner couldnt really differentiate between the two. Sanding is definately the best way, its not that hard, I did it without an extra hand with a screwdriver in my mouth pushing down from the top
BTW, I will do within a week, hopefully :
Boost gauge
Cruise and fog buttons
Clock(when I find a better way)
Window buttons (maybe)
i am not sure if this has been covered before or not, but instead of putting a red cover is it possible to just change the clear bulb with a red led bulbs?? wouldnt the color be better?
alphaomega0 is offline   Reply With Quote
Old 06-03-2009, 04:59 AM   #655
JTS88
Member#: 211120
2007 WRX
As any one thought of adding a RED and BLUE cover under the GREEN gel to get a white color?Just curios because when you add red + blue+ green light together you get white.
It may not work but just wondering.
JTS88 is offline   Reply With Quote
Old 06-13-2009, 01:10 PM   #656
2002roxxie
Member#: 213915
that's not going to work. yes, white light is made up of all the colors in the spectrum, but you're talking about pigments, not light. red pigment + blue pigment + green pigment = some ugly color you dont want.
2002roxxie is offline   Reply With Quote
Old 07-03-2009, 12:15 AM   #657
gsk3rd
Member#: 155825
07 WRX TR
WR Blue
Does anyone know what lights keep the needles lit up. I have replaced my bulbs with some led bulbs that have 3 directional leds on a pci board that fits into the socket. my problem is that the needles hardly get any light. The green is a good bright color and is what i want. Should i run some lights behind the guages in order to get light to the needles.
any advice would be awesome. thanks.
gsk3rd is offline   Reply With Quote
Old 08-01-2009, 02:06 AM   #658
explicit_03
Member#: 218188
2003 wrx
World Rally Blue
Going to do this mod tomorrow. Glad to see pics i thought it was much more dificult
explicit_03 is offline   Reply With Quote
Old 08-03-2009, 01:02 AM   #659
drunk909
Member#: 207881
red condoms are no longer sold at the op's link. anyone have any suggestion on where to get the red condoms or a proven reliable alternative?
drunk909 is offline   Reply With Quote
Old 08-08-2009, 08:43 AM   #660
David03WRX
Member#: 28546
00 BMW M Coupe
03 WRX Wagon.
So I tried changing gauge color using the bulb condom method, but frankly I was underwhelmed by the results. I tried to sand down the film as indicated at the beginning of this DIY, but didn’t have much success, even with an extra set of hands. Now it was a bit painful and time-consuming, but I grabbed some of my wife’s nail polish remover and a stack of cotton swabs. I kept the gauge faces on so that I didn’t have to worry about gauge calibration. I peeled back the existing layer and swabbed like crazy, eventually clearing off all the numbers and hash marks. The hardest areas were the area between the speedo and the tach, and the middle areas of the gas gauge and water temp gauge.
After I found the two-layer orange condom method killed the illumination to my needles and odometer, I removed the gauge cluster again and pulled the bulb condoms.
Not wanting to do the whole stage gel/LED route, I started thinking about how I could replicate the results. SO… I grabbed a stack of transparent laserjet paper ($2/sheet at Office Max) and, of all things, an orange Sharpie…
I cut out a section of the transparent sheet and created a template. I kept fitting and refining it on the top of the gauge until it was just right. I then placed it underneath and found a few other bits that needed trimming. Next, I simply colored the sheet with the orange sharpie. I colored both sides to add a bit of depth to the color.
After testing this in the car I noted that there were still a couple of ‘hot spots’ and some blotchiness, just like with the condom method. So I decided to create a blackout template with a sectioned color area to darken the hotspots. I started the same way, but then overlayed it and created the blackouts. I then sectioned out the color area.
The results are great! The color is a bit pale in the sunlight – but what do you expect when it’s not LED? It was the same way with the green anyway! In the dark the color is a perfect amber, matching the look of my wife’s Mazda3’s electro-luminescent gauges almost perfectly – and definitely mates up with my Prosport gauge. I’m extremely happy.
These pictures don’t do the project justice:
David03WRX is offline   Reply With Quote
Old 08-18-2009, 11:40 PM   #661
d0ugch0i
Member#: 198861
2004 WRX
what size are the bulbs? i was planning on getting leds for them.
is it the same size as the HVAC?
d0ugch0i is offline   Reply With Quote
Old 08-19-2009, 03:10 AM   #662
dc_adio28
Member#: 185057
Chapter/Region: HIIC
2008 Legacy GT
NBP
bump this question!!!! Im looking aswell. I can only find this link http://www.pinballlife.com/index.php...parent=75&pg=1
but Im unsure as to the quality or even if they will fit. Anyone have experience with these???
dc_adio28 is offline   Reply With Quote
Old 08-25-2009, 06:43 PM   #663
Lithel
Member#: 221307
2007 Impreza
Default Red or Orange?
^ has my question in it.
Lithel is offline   Reply With Quote
Old 08-27-2009, 01:07 PM   #664
Lithel
Member#: 221307
2007 Impreza
Alright, just finished reading all 27 pages. Boom! That took a while. Anyway, I've decided to try it out. I'm thinking I'm going to try out the lamp cover/condom method first and see how they look like with the green film still in place. (Anyone got a picture of what this looks like? I don't remember seeing one in this thread.) Then maybe use nail polish to remove the greenness if needed.
Old 08-29-2009, 05:05 AM   #665
Member#: 221011
02 Outback Limited
doodoo black
will this work in my 2002 legacy outback? (at)
ARcticBJ@Gmail.com is offline   Reply With Quote
Old 10-14-2009, 11:13 PM   #666
Shruggerx
Member#: 126575
2004 wrx wagon
Java Black Pearl
I tried the bulb condoms a while ago and had nothing but trouble. All they did was pop off a few days into having them on. So that idea had to go. Then I bought replacement #74 leds from autolumination.com and had to shave them down to fit in the stock twist bases.
After a few months, my dash lights keep cutting out on my and now only half of my dash is lit.
Any suggestions as to which bulbs would work to solve the problem, I was thinking of these http://superlumination.com/images/au...trix2_r_wm.jpg but I am not too sure if they will have the same problem?
Should I buy some #24 bulbs too? Instead of all #74?
Any suggestions would be great.
Shruggerx is offline   Reply With Quote
Old 10-16-2009, 11:07 PM   #667
prj_miata
Member#: 151043
2005 2.5RS cgm
2003 Wrx psm
going to attemp this tonight.. good info
prj_miata is offline   Reply With Quote
Old 11-14-2009, 02:14 PM   #668
cody805
Member#: 224928
'o4 STi
what would happen if you just changed the bulb to an intense bulb color and didn't sand at all...any effect?
cody805 is offline   Reply With Quote
Old 11-23-2009, 12:07 AM   #669
maxipad
Member#: 85635
'05 2.5RS
CGM
can someone answer this for me??
if you change to all red LED's (except needle bulbs) that are really bright and dont touch the green film, do the LED's still shine thru red? are they bright enough to power through it or are they super gross and brown?
maxipad is offline   Reply With Quote
Old 11-26-2009, 12:55 PM   #670
Sipset
Member#: 221249
2004 S4
Would this work on my 01 RS?
Sipset is offline   Reply With Quote
Old 12-02-2009, 10:47 PM   #671
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
bump up the bulb condom question.
Where do you buy red bulb condoms? or red leds that fit?
snowflowmfg is offline   Reply With Quote
Old 12-03-2009, 09:10 PM   #672
boardinshorty81
Member#: 174965
07 WRX VF43
I am wondering this too.
boardinshorty81 is offline   Reply With Quote
Old 12-03-2009, 10:04 PM   #673
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
If you dont sand out the green film, the red led will only be like 2/3 of sanded. Also the color will be kind of orange, not really red....lol
But I would say it still will brighter than just using blub comdoms and you will get more red.
By the time you changing the blub, why not just sand the green film? It's not hard, all you need is take time and be careful.
sum0325 is offline   Reply With Quote
Old 12-03-2009, 10:14 PM   #674
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
you can find the comdoms from pepboys. If you are going to replace the blubs with the same size LED's, dont waste your time and money. Replace the same size of LED blubs will not really light up the cluster, and worse...
Just go on ebay and buy some 12V LED's , cheaper and easiler.
Old 12-03-2009, 10:24 PM   #675
boardinshorty81
Member#: 174965
07 WRX VF43
This sounds like a stupid question, but could you just get some red 12v LEDs and then just sand of the green and be set?
If so, are the 12v leds hard to wire?
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
