Old 12-03-2009, 11:43 PM   #676
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
Originally Posted by boardinshorty81 View Post
This sounds like a stupid question, but could you just get some red 12v LEDs and then just sand of the green and be set?
If so, are the 12v leds hard to wire?
haha , you got it man,that's how I did mine.But I'd like to let you know it would as bright as white led's with red gule, and I do get a little hot spot.I will post up a picture of mine once I get home.
The 12v is easiler to wire, just + to - and - to +. But remember the sand all led's before you put them into the cluster. and it's also hard to mount the led's( I super glue them and use duck tape to hold them)
sum0325 is offline   Reply With Quote
Old 12-04-2009, 02:14 AM   #677
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
Old 12-04-2009, 11:53 AM   #678
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Does anybody have any ideas on how to make the needles brighter?
and does anybody know where to get red bulb covers? the link provided does not offer red. But the sti cluster looks a little orange...would orange covers looks better?
Would running white leds in place of the bulbs with no film or covers give me the white gauges?
snowflowmfg is offline   Reply With Quote
Old 12-11-2009, 02:06 PM   #679
dandahawk
Member#: 226624
06 WRX Limited
OBP Stg 2 EFI Tuned
Default nail polish remover...
i have an 06 wrx limited and i really wanna do this, what is the nail polish remover for....u say u can use that instead of the sandpaper?.....if so that seems like it would be better because if you have to take the face off anyway to change the condoms on the bulbs, y not do it that way?....im a serious noob....(had the car less than 2 months) so i dont know much....but this faq really caught my eye cause i really really wanna do this....let me know
D.
dandahawk is offline   Reply With Quote
Old 12-11-2009, 07:54 PM   #680
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
D.
nail polish remover and sand paper are for sanding the green film behind the gauge face.I didn't use either of them but just a flathead screw driver.lol
Led's are a lot brighter then just useing comdoms, also better color. And also you can never get some color like blue by just useing the comdoms.
Old 12-12-2009, 03:12 PM   #681
boardinshorty81
Member#: 174965
07 WRX VF43
D.
I would defiantly suggest the LED version of this mod found at this link: LED MOD
The color just seems to be much better, and with patience you have less chance of messing it up(you don't have to worry about those silly "tophats").
boardinshorty81 is offline   Reply With Quote
Old 12-14-2009, 10:54 PM   #682
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Anyone???
Old 02-19-2010, 09:20 PM   #683
shiny467
Member#: 178712
2005 2.5rs
psm
okay so i just did this and in the process the needles of my speedo and tach got really hard to move around and now when i start my car they stick alot and i dont get accurate readings for example im going 30 its still saying like 20 then pops up eventually then when slowing it stays at 30 even if i was stopped for a little then pops down. How do i fix this
shiny467 is offline   Reply With Quote
Old 02-19-2010, 09:40 PM   #684
chi-town
Member#: 45338
2002 wrx
wrb
The same thing happen to me on my 02WRX. There are small of plastic disk, behind the needles and in front of the speedo and tach surface. The are basically plastic washers. It's really hard to see, you must of bend them out of shape, and now that are catching the needles. Don't worry, they are easy to bend back with a butter knife.
Here's what you do.
1)Remove the unit out of your car.
2)Try to tilt the unit until you can see behind the base of the needles. You will see those plastic washers.
3)Bend those plastic washer back into place. Be very careful with the needles, they are very delicate.
4)You should able to move the needles with your fingers. Move the needle up, and let the needle free fall. The needles should fall smoothly, same as you see it when you are driving. If they are not free falling smoothly, then the plastic washer is catching the needles
Good luck.
chi-town is offline   Reply With Quote
Old 02-19-2010, 10:04 PM   #685
shiny467
Member#: 178712
2005 2.5rs
psm
Thank you
Works perfectly now. Appreciate the help
Old 03-03-2010, 12:22 AM   #686
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
I sanded the green film down only. Still haven't put in the supplemental led's that mechie3 has prescribed to remove the hotspots. The needles don't light up as well as they used to either. Kinda bummed about that, but here's some pics of white led's and one of red painted stock bulbs. I decided to just do an STi swap though and will sell this cluster soon. Sorry for the crappy cell pics. Oh and my 36k warranty ended to
Old 03-04-2010, 01:42 PM   #687
antho!
Member#: 159057
2004 ts wagon
aspen white
to everyone who's looking for bulb condoms, here's a link
T1 = 3 mm diameter
T1 3/4 = 5 mm diameter
you're welcome
antho! is offline   Reply With Quote
Old 04-08-2010, 04:17 PM   #688
darthalal
Member#: 114208
2007 MINI Cooper S
Grumpy Old Man Tan (SSM)
T1 = 3 mm diameter
you're welcome
Thanks! I ordered these before I saw the LED version.. so I'll be trying this out soon and will post pics. Has anyone tried just sanding the gauges and removing the green condoms? I think white speedo/tach with red redline would look good, with the rest of the controls converted to red.
darthalal is offline   Reply With Quote
Old 04-20-2010, 05:53 PM   #689
Marvicamog
Member#: 220183
2010 WRX
Black Errthang
i was just wondering,
could i swap a 07 2.5i cluster with a like any sti cluster?
i need to know cuz im not likin the look of my cluster right now after doing this
Marvicamog is offline   Reply With Quote
Old 05-30-2010, 10:21 PM   #690
cabikejumper
Member#: 226604
2000 Mustang GT
I started with my temp/fuel part in case the needles messed up. sure enough I dont get a gas reading or temp. What could the problem be?
cabikejumper is offline   Reply With Quote
Old 05-30-2010, 10:32 PM   #691
Rubr_Duky
Member#: 2159
2015 STi
I just re-did mine with stage lighting gels, and like the result MUCH better. I did the speedo and tach, but have to re-do the fuel and temp gauge. I made a template for those:
I'll make a template for the fuel and temp gauges when I do them. The gel was like $6.95, I think. I used Lee Filters Red #182, which is a REALLY good match to the needle.
Rubr_Duky is offline   Reply With Quote
Old 07-03-2010, 11:39 PM   #692
biv343
Member#: 246476
2006 Impreza WRX
Gray
http://www.parts-express.com/pe/show...number=070-008
Think this LED could work? sorry, complete electrical noob!
biv343 is offline   Reply With Quote
Old 10-04-2010, 10:25 AM   #693
Studmike02
Member#: 220095
'95 MX-5
Which bulb would be the right one for the temperature part on the cluster, I got a burnt out red one and I forgot which bulb that one is.
2006 impreza 2.5i
Studmike02 is offline   Reply With Quote
Old 10-07-2010, 04:34 PM   #694
Tz000
Member#: 253274
Couldn't you just get red LED's and replace the stock ones behind the cluster and wouldn't it light up red or whatever color you want? Or do you HAVE to get rid of the film behind the cluster?
Tz000 is offline   Reply With Quote
Old 12-13-2010, 03:39 AM   #695
samneumann
Member#: 245075
so are the lamp covers new bulbs? or like little condom sheets you place over them? bc when i link to your "Lamp cover" material link all i go to is LED bulbs, they dont look like little condoms lol or maybe im just blind too
samneumann is offline   Reply With Quote
Old 12-13-2010, 03:56 AM   #696
Rubr_Duky
Member#: 2159
2015 STi
Lamp covers are like little 'condoms' that go over a plain, incandescent bulb.
LEDs require a specific voltage in order to operate properly. To my knowledge, there is nothing available that can directly replace the bulbs in the cluster without electrical knowledge, some soldering, and such. So this precludes just changing to LEDs.
Complicate matters more with the needles. They are red acrylic (2004-2007), or orange acrylic (2002-2003). If you light red needles with red light, your output will be significantly decreased. I tried it, and had that problem when I did mine, which is why I went to the stage lighting gels.
Consult your owner's manual, I have no idea.
Old 01-27-2011, 03:32 PM   #697
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Originally Posted by sum0325 View Post
They look awesome, But why so bright on the odometer
NutWagon is online now   Reply With Quote
Old 01-27-2011, 03:37 PM   #698
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
I have done the HVAC, boost gauge, and the glow ring in red leds. Ill post pics tonight. Have'nt got a chance to do the cluster. Im a lil afraid of sanding the film down. The bulbs i did do look fantastic.
@ Trunk Monkey~ Do you think if i put the red leds in the instead of sanding they will still look greenish?
Old 02-17-2011, 12:49 PM   #699
Studmike02
Member#: 220095
'95 MX-5
What I did was just changing the LEDs directly from the stock ones and had no problem, just one bulb is flickering, had it for around 8 months now.
Old 02-20-2011, 09:17 PM   #700
Wileycyote
Member#: 268173
2003 WRX Wagon
Thanks for the tip on using nail polish remover.
If you take the cluster apart you can remove the speedo/tach and the temp/fuel plates. It makes it much easer to remove the green paint.
Wileycyote is offline   Reply With Quote
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 71 03-02-2015 05:42 PM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 248 10-29-2013 12:47 PM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 08:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 03:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 04:08 PM
