Old 03-04-2011, 05:00 AM   #701
bane.x07
Member#: 275777
2007 WRX STI
hey i just got my 07 sti today and i wanted to change the cluster to green but keep the tinted faces when off
bane.x07 is offline   Reply With Quote
Old 03-04-2011, 09:16 PM   #702
mmaxamus2010
Member#: 273696
How do you do it using the nailpolish remover? I could find it
mmaxamus2010 is offline   Reply With Quote
Old 03-10-2011, 09:54 PM   #703
Wileycyote
Member#: 268173
2003 WRX Wagon
Get some nail polish remover and a bunch of qtips. Have some small flat heads around to fix the needles if need be.
Remove the cluster and take off the plastic lens to expose the tach/speed and gas temp gauges. If you look at the back of the cluster you will see holes for the lights and long thin rectangular slots cut out of the back. In those holes you will see a tab a hole with a silver circle then a tab. (I 0 I) Straighten the tabs and push the pannel out by using a small screwdriver to push on the silver circle. There are 2 sets of tabs for each side. They are right behind each gauge.
Once you have each section out you can reach behind the painted layer with a nail polish soaked qtip and remove the green paint. I used about 50 qtips. You can check you progress by shining a light behind the removed pannel.
When you have removed the paint to your liking, carefully press the gauges back in and rebend tabs. Done and looks great.
Wileycyote is offline   Reply With Quote
Old 05-06-2011, 08:21 PM   #704
Scissor
Member#: 281484
2005 WRX
CGM
parts express doesn't have the red covers anymore. anywhere else to get them?
Scissor is offline   Reply With Quote
Old 06-08-2011, 06:56 PM   #705
Aprice24
Member#: 231892
2007 Impreza WRX
Bump. Anyone else looking to do this?
Aprice24 is offline   Reply With Quote
Old 06-10-2011, 11:33 AM   #706
Twrex2002
Member#: 283490
uh oh, i was planning on trying this.... anyone find where we can get the red covers?
Twrex2002 is offline   Reply With Quote
Old 06-11-2011, 10:36 AM   #707
Aprice24
Member#: 231892
2007 Impreza WRX
I did this last night and it looks awesome, but now I'm having problems with my speedo working. Any help here?
It looks like my clip popped up into the needle. How can I get it down? Flathead isn't working. Maybe dental floss?
Old 06-11-2011, 11:48 AM   #708
Aprice24
Member#: 231892
2007 Impreza WRX
Update. I was able to fix it. By wiggling the needle slowly back and forth I was able to separate the clip from the needle. From there I could use a small eye glass/computer flathead to push it back down.
It looks awesome, now I'm going to order some stage gels to replace the color.
Old 07-15-2011, 02:33 AM   #709
knbetz
Member#: 288123
2003 Impreza WRX
Question new car, christmas tree effect on lights.
So I recently purchased an 03 WRX, half the lights in the gauges were "out" so i thought what the heck i'll just get some LED's and do a overhaul on the lights inside the car. Changed the lights and found out one of the 74 bulbs and twistlocks were completely missing.
Is that why half my gauges (speedometer and tach) are not lighting up? I'm assuming they run in series not parallel, correct?
PS the writeups on changing the color of lights were fantastic help, i'll be doing the radio, hvac, keyring, and boost gauge asap.
knbetz is offline   Reply With Quote
Old 07-26-2011, 04:58 PM   #710
ThatMichiganSubaru
Member#: 288162
Smile
Nice steering wheel! i have the same one =)
ThatMichiganSubaru is offline   Reply With Quote
Old 10-09-2011, 06:47 PM   #711
HFR_WRX
Member#: 294789
2006 WRX TR
Obsidian Black
So question. If I were to throw some #47 red led twist and locks. (Look similar to stock) would they work? Or is it not that simple?
HFR_WRX is offline   Reply With Quote
Old 12-05-2011, 09:46 PM   #712
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
After losing my speedometer light, I decided to do this mod with 3x brightness blue lights from autolumination.com. I'm pretty happy with the results. I didn't scrape off the green filter either. The gauge is actually brighter than it appears in the picture with the red line now purple.
ShinjiML is offline   Reply With Quote
Old 12-05-2011, 09:46 PM   #713
ShinjiML
Member#: 257231
double post
Old 02-14-2012, 04:17 PM   #714
ayashifx55
Member#: 309809
E46 M3 & Outback
Will 74 LED bulbs work? Thanks.
ayashifx55 is offline   Reply With Quote
Old 02-14-2012, 09:17 PM   #715
rustyg23
Member#: 277681
05 sti
graphite metallic black
about how long did this take you i would love to do it to my 05
rustyg23 is offline   Reply With Quote
Old 02-15-2012, 10:06 AM   #716
Salvation27
Member#: 292403
2012 Legacy
Graphite
anyone ever check these guys out??
http://interiorflair.com/Services.html
Salvation27 is offline   Reply With Quote
Old 02-15-2012, 10:15 AM   #717
Salvation27
Member#: 292403
2012 Legacy
Graphite
Also, if anyone is in the NNJ area, let me know, as I'd definitely compensate anyone who can do this............
Old 02-15-2012, 06:14 PM   #718
ShinjiML
Member#: 257231
It took me about 30 min. (including removing the gauge cluster), just be careful to not lose one of the little metal clips on the cluster mount like I did >.>
It's actually really easy, the bulbs just twist off and you twist a new bulb on.
Also, just to note, doing this WITHOUT removing the green film might not work well with all colors. I believe it worked in this case because blue and green are close to each other in the color spectrum.
And yes, the bulb size is 74
Old 02-16-2012, 07:59 AM   #719
rustyg23
Member#: 277681
05 sti
Sweet thank you. I am going to do the blue I was looking on that website u linked did u get the led with three lites for wide angle or the signal one they both say 3x brighter.. also anyone have a idea on how to keep the red line still red?
Old 02-16-2012, 10:32 PM   #720
ShinjiML
Member#: 257231
I got the "3 LED wide angle 3X brighter" bulbs, it's the third one from the top of the page http://autolumination.com/74.htm
Old 02-20-2012, 06:10 PM   #721
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
I've been looking, and I'm tired of doing so, but is there a tutorial on how to change the color of the door switches? I have an 07, and upon opening it up, I realized it was all LED's. Are the LED's green, or is it a film/the plastic on the switches themselves? I just did my cluster/hvac, and I've given up looking around the forum. Any help would be greatly appreciated!
NVsubaru is offline   Reply With Quote
Old 02-20-2012, 06:28 PM   #722
Rubr_Duky
Member#: 2159
2015 STi
I changed the green LED in my door window switch to red. YRMV
http://forums.nasioc.com/forums/showthread.php?t=821215
Rubr_Duky is offline   Reply With Quote
Old 02-20-2012, 07:32 PM   #723
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
Yeah, just took it apart again, and there's no film, so LED's it is...time to bust out the 'ol soldering iron...
Old 02-29-2012, 11:32 PM   #724
SSDD22
Member#: 294452
2007 WRX TR
Satin white peral
Default fuel gauge doesnt work now
So I changed the color of my gauges the other day and noticed my fuel gauge isn't working I've went back and forth taking my gauge cluster apart trying to figure out what is going on with it. I have no clue with what it could be any ideas ?
SSDD22 is offline   Reply With Quote
Old 03-01-2012, 04:09 PM   #725
Rubr_Duky
Member#: 2159
2015 STi
Read the thread again. Many people have had the same problem, and the solutions have been gone over.
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
