Old 03-02-2012, 12:25 AM   #726
SSDD22
Member#: 294452
2007 WRX TR
Satin white peral
I checked the ring and top hat thing ,but nothing has changed. So if you get any ideas on how to fix it i'm all ears guys thx.
SSDD22 is online now   Reply With Quote
Old 03-02-2012, 12:52 AM   #727
Rubr_Duky
Member#: 2159
2015 STi
Are all of the pins aligned properly? Are the plastic rings pushed down all the way? Do the dials move freely when out of the car? Did you remove the needles? Can you take a picture? You give nothing to go on, and want results, I don't know what to tell you. What exactly did you do, and how did you do it?
Rubr_Duky is offline   Reply With Quote
Old 03-04-2012, 10:16 PM   #728
SSDD22
Member#: 294452
2007 WRX TR
Satin white peral
Well I was driving my wrx back home this morning and noticed that my gauge is now working I disconnected the battery and the connector to the gas pump and float assembly. thanks guys everything seems to be working fine for now.
Old 03-25-2012, 10:48 PM   #729
youngxlos
Member#: 232169
2002 Hawkeye
World Rally Blue Pearl
hi im going to try doing this to my car soon but the links on the first page aren't working.... but i did search and found this
http://www.parts-express.com/pe/show...number=070-080
and
http://www.parts-express.com/pe/show...number=070-090
^^^ are those the correct covers?
youngxlos is offline   Reply With Quote
Old 03-26-2012, 12:32 AM   #730
Rubr_Duky
Member#: 2159
2015 STi
^ yes
However, the better way to go - with more choices for colors, and truer color, leaving the needles unchanged (and amply lit) is to use stage lighting gels.
Old 03-26-2012, 12:53 AM   #731
youngxlos
Member#: 232169
2002 Hawkeye
^^^ you lost me at lighting gels.... do i apply the gel to the stock light bulbs?
Old 03-26-2012, 01:01 AM   #732
Rubr_Duky
Member#: 2159
2015 STi
It's a plastic sheet. Instead of changing the color of the light emitting from the bulbs, which will affect the needles and the back lighting alike, you remove the stock filter that is printed on the back of the dials, and then add your own filter. Your needles remain well lit, which in my experience, they did not when I used the filters on the bulbs.
Old 03-26-2012, 05:52 AM   #733
youngxlos
Member#: 232169
2002 Hawkeye
^^ thanks for the help, where do i get the gels from?
Old 03-26-2012, 02:21 PM   #734
Rubr_Duky
Member#: 2159
2015 STi
Any of a thousand places you wish to patronize - I'd start with google. Figure out what color you want, maybe ask for a sample, then buy what you need.
I have templates for my 04 gauges (speedo and tach), but still news to redo the fuel and water temp-change it over from the bulb filers to lighting gels, and when I do, I will make a template for those.
Search my threads for interior redox for it.
Old 04-08-2012, 01:12 AM   #735
subarupagan
Member#: 315716
2013 Wrx premium
Plasma blue pearl
i've tried the sanding method with horrible results... see on the back side were the diagonal slits are pull the prongs straight up and with a screw drive push the tiny circle this pops the gauges out. take nail polish remover with acetone and q-tips and wipe away the green it takes a bit buy the bulbs from here http://www.superbrightleds.com/cgi-b...s%2F74_t15.htm your gonna need about 8 after you cleaned off the right area pop those bulbs in your dash will be almost blinding bright here is a pic of mine with only half the bulbs in
to get the green lcd's blue just put the bulbs in it and it changes the color
subarupagan is offline   Reply With Quote
Old 04-08-2012, 10:36 AM   #736
subarupagan
Member#: 315716
2013 Wrx premium
Plasma blue pearl
also when you take out the gauges there are little covers over the bulbs for the speedo and rpm gauge break those off you'll get more light
Old 04-28-2012, 11:13 PM   #737
kapp_badbloodz
Member#: 203327
Just did this. Replaced the OEM lights with LEDs from superbrightleds.com
Ended up looking alright. Everyone needs to exercise some caution because I played with the needles a little bit too much and now my speedo is messed up a bit. It is a little on the slow side but I think readjusting the needle will fix it.
The sanding was a pain in the ass! 100 grit might be a little rough because I got some blotching. I suggest using 120 instead and you get the same results with the same amount of sand time with less blotching. Great mod
kapp_badbloodz is offline   Reply With Quote
Old 05-03-2012, 12:05 PM   #738
AirforceWRX
Member#: 317829
2004 WRX STi
Nice job man. I'm going to do this now so I can get the blue air force theme for my Wrx.
AirforceWRX is offline   Reply With Quote
Old 05-13-2012, 12:38 PM   #739
jambaj
Member#: 293850
2005 WRX STI
Does anyone know the led bulb size for a 2004 dash??????
jambaj is offline   Reply With Quote
Old 06-23-2012, 10:09 PM   #740
AznDisaster
Member#: 259746
2007 Impreza 2.5i
Can i buy those LED's from http://www.superbrightleds.com/cgi-b...s%2F74_t15.htm and plug and play into the HVAC controls and the key ring?
AznDisaster is offline   Reply With Quote
Old 06-25-2012, 06:57 PM   #741
bm880
Member#: 324299
2001 BUG
i was doing it today on my bug, but seems i have a few f* up bulbs, can some one please tell me those bulbs name? i`ve searched around the forum but couldn`t find any topic related..
first one is from the green illumination from the fog button, second from HVAC, third and fourth from the cluster... any help will be appreciated! thanks!
bm880 is offline   Reply With Quote
Old 07-12-2012, 10:37 AM   #742
Atombong420
Member#: 321612
1996 Legacy Outback
Original green
The small ones with small bases are T4 base type 74 bulb. They have a regular size and a tall size. Next is the bigger base is a T10. The smaller bulb is a 5mm (.2) and the bigger one is a 10mm (.12). I found the bulbs and covers on this site called autolumination.com. They have incandescent and LED bulbs
Atombong420 is offline   Reply With Quote
Old 07-12-2012, 10:49 AM   #743
Atombong420
Member#: 321612
1996 Legacy Outback
Original green
Smaller bulbs are 5mm (.12) and larger are 10mm (.2) sorry about confusion
Old 10-09-2012, 07:57 PM   #744
Daletehbest
Member#: 308617
1999 Impreza
Can anyone tell me anything about doing this to a 99 impreza? I want to go to blue but am hesitant because I'm not sure Whats back there. I've been searching but can't seem to find much information
Daletehbest is offline   Reply With Quote
Old 02-06-2013, 08:34 PM   #745
mtbtimr
Member#: 346214
Default Well Done
Thank you! im going to try this myself, the tutorial was very clear. Is it just as easy to replace the entire bulb with say a red LED? Because it seems the link to light condoms is dead..
mtbtimr is offline   Reply With Quote
Old 02-17-2013, 11:04 PM   #746
Handsdown
Member#: 29355
well after a few years of a fairly well dispersed red condom mod I'm finally going to attempt to redo this with some more features. I just picked up an LED strip from ikea that is 12volt and RGB selectable. the idea is to put them up around the sides of the inside of the cluster and wire them into an actual circuit for the dash. ill lose the dimmer feature in pretty sure but being able to cycle colors will be super cool.
Handsdown is offline   Reply With Quote
Old 02-20-2013, 10:09 PM   #747
ordep3333
Member#: 347746
09 sti
swp
Thanks for the great write up gives something to do over the winter!
ordep3333 is offline   Reply With Quote
Old 02-28-2013, 01:05 AM   #748
06wrx1994811
Member#: 338378
2006 wrx
How do you turn off the abs light after installing new bulbs and putting everything back together? Now my abs light is on. How do I reset it
06wrx1994811 is offline   Reply With Quote
Old 02-28-2013, 02:29 AM   #749
cincysubie
Member#: 191389
2005 Impreza WRX STi
Obsidian Black Pearl
The links are dead. Where do I get the proper bulbs? Bulb condoms? I need some numbers so I can pick them up locally or worst case scenario online.
I want the brightest such fitment bulb.
Someone please pm me about this. I already tried contacting all the users who posted the stickies with no response...
cincysubie is offline   Reply With Quote
Old 02-28-2013, 08:09 PM   #750
thebeephaha
Member#: 248063
2003 Forester 2.5XTi
Supercharged in Gold
Here is how I changed the color of my cluster, with provided links to the right LEDs.
http://forums.nasioc.com/forums/show....php?t=2474210
There is also some info on how to invert the trip LCD and change the color of the gear selector for us 4EAT drivers.
thebeephaha is offline   Reply With Quote
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
