Old 03-01-2013, 11:46 AM   #751
cincysubie
Member#: 191389
2005 Impreza WRX STi
Obsidian Black Pearl
I'll check it out. I wanted to go the simplest route. But idk what parts to get
cincysubie is offline   Reply With Quote
Old 03-01-2013, 12:50 PM   #752
thebeephaha
Member#: 248063
2003 Forester 2.5XTi
Supercharged in Gold
If you have a WRX around the same era as my Forester, the bulbs I used will be the same for you.
thebeephaha is offline   Reply With Quote
Old 03-27-2013, 02:29 PM   #753
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
how long does this process take?
XSV Klutch is offline   Reply With Quote
Old 03-29-2013, 10:38 AM   #754
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
Originally Posted by Rubr_Duky View Post
^ yes
However, the better way to go - with more choices for colors, and truer color, leaving the needles unchanged (and amply lit) is to use stage lighting gels.
I looked at your post about this but all the pictures are gone! I want to change my cluster blue can't find a custom one to buy, doing the LED change out with sanding film off seems to lose the needles and give bright spots . I hate my dim green lighting!!!!! makes me want to go to sleep
How do you remove the existing filter ?
I don't quite understand how these gels work. I googled staging gels but there are a million sites and I dont' even know where to begin!
silverbullet7 is offline   Reply With Quote
Old 03-29-2013, 11:52 AM   #755
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
Wait .. you have a template then you have a place create something with the stage lighting gel? How does this come out? Do you have a pic I can see??? I really am interested in this process
Old 04-08-2013, 06:45 PM   #756
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
I would like to go blue as well, but i do not know what to use
Old 06-05-2013, 01:18 PM   #757
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
I'm assuming if one were to want a white gauge cluster, you would only have to sand away the green tint?
CrazyCatfish5 is offline   Reply With Quote
Old 06-09-2013, 10:34 AM   #758
ShinjiML
Member#: 257231
2011 STI
^^^ yes, you would have to sand away the green tint if you want a white gauge cluster
Also, as for going blue, you don't actually need to sand away the green tint because the two colors are close in the color spectrum. If you go back 2-3 pages, you can see a picture of my gauge cluster. I simply used blue LEDs that were 3 times the brightness without modifying anything else and the result is quite blue. It does looks slightly teal, but I was fine with it.
Just leave the Odometer bulb stock, or maybe use a white led, because otherwise your needles would become very dim and hard to see.
The whole process took me about 30 min., including the time it took to remove the gauge cluster.
ShinjiML is offline   Reply With Quote
Old 06-09-2013, 12:28 PM   #759
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
To go white, would I have to use white LEDs or is removing the green tint enough?
Old 06-09-2013, 01:50 PM   #760
ShinjiML
Member#: 257231
2011 STI
Removing the green tint would be enough to make it white, but since you already have the gauge cluster out, you might as well swap in some bright white LED bulbs.
Old 06-12-2013, 12:21 AM   #761
Shiftee
Member#: 345258
2003 WRX
Sonic Yellow
by swapping bulbs, what size bulbs do you need? I wanna do white lettering but wasnt sure on the bulb swapping process. I lost my soldering iron :/
Shiftee is offline   Reply With Quote
Old 12-27-2013, 01:52 PM   #762
Baxid
Member#: 358468
Thought I would add on to this a little more since many people still seem to have questions. I decided to do this mod to my rex, took me all together about 2hrs and I was pretty meticulous so could be done faster if wanted to.
I went ahead and ordered 10 red #74 bulbs from autolumination.com, not LEDs, just the regular ones, ran me $20. I didn't use all 10 but bought extras just in case.
Then I used this video:
for most of what I needed to do, this guy shows how to remove the gauge faces completely (easy and pretty harmless) making the job much easier, doesn't seem that that's included in TrunkMonkey's DIY.
Then did a little sanding with 100 grit sandpaper and finished off the areas with nail polish remover and qtips, works awesome!
When white light shines through like in the picture above and there's no traces of green, you're good!
Then, I replaced 5 of the cluster bulbs with the red ones (2 behind the gas/fuel gauge face and 3 behind the tach/speedo, no need to replace more, all the other bulbs are responsible for different cluster lights, not actual illumination.
And here's the result!
Really happy with it, turned out great in my opinion! The pictures are a little off, looks better in person. I did leave the odometer green because I kind of like the contrast, it's pretty easy to change to red as well (replace the odometer bulb to red and pull out a little green rectangular film from it). Like I said, took about 2hrs and is a pretty easy job, don't need to be mechanically savvy, just need to be careful. Cheers!
Baxid is offline   Reply With Quote
Old 02-03-2014, 12:30 PM   #763
redneckbane
Member#: 348080
2004 impreza wrx lim
wrb
My speedometer is stuck after doing this any ideas
redneckbane is offline   Reply With Quote
Old 02-23-2014, 11:47 PM   #764
Baxid
Member#: 358468
Both my speedometer and tachometer didn't work at first when I put everything back together, check for tiny black rings under the base of the needle, they're supposed to be pushed down to the gauge face, mine by accident pushed up into the base of the needle and I didn't even see them at first but then I pulled them down with tweezers and pushed them back to the gauge face.
Old 03-04-2014, 09:44 PM   #765
22kahn
Member#: 350750
2003 WRX wagon
Black (wish it was JBP)
Ive been playing with an Idea.
About 6-7 months ago I did a cluster color conversion. I am at the point where I can not stand the hot spotting and Im thinking about doing something a bit more extensive than just properly diffusing the light or adding more LEDs. Heres some photos and some explination.
Here is the bulb swap and cluster conversion pretty much right after I finished it.
Yesterday I finally completed a clock conversion. Could not stand the green with so much else now white. (dont get me started on the head unit. Im working my way down the project list towards the Raspberry Pi based headunit.) I bought this clock and then 3d printed a caddy to make it all fit as close to OEM as I could.
The picture of the clock installed really made me want to fix the cluster.
I am playing with a couple of other ideas right now. One of which involves the Adafruit Neopixel ring.
These Neopixel rings are made up of RGB LEDs, so you can tune the color to exactly what you want through a USB connection without taking a single part off of your car.
They are also individually controllable. You can base how they are controlled on analog inputs. For example; progressive or abrupt integrated shift lights based off of your rpm gauge, or color change of the temp gauge backlight.
At the moment Im still learning to program, and possibly looking for help in that department. Im also looking for any feedback you guys have on what I have done and plan on doing in the future.
22kahn is offline   Reply With Quote
Old 03-06-2014, 01:32 AM   #766
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Buy an sti cluster lol.
Scoobiesdoobies is offline   Reply With Quote
Old 02-21-2015, 12:44 PM   #767
MMK21
Member#: 399805
2004 Impreza WRX
I took off too much of the film around my gas gauge and now it illuminates some of the warning lights. Do you think I'd be able to color part of it back in with a sharpie or paint part of it?
MMK21 is offline   Reply With Quote
Old 04-09-2015, 03:27 PM   #768
DeathhGhost
Member#: 418232
Default Needles
Hey guys, sorry I can't find anything about my problem. I recently changed all the bulbs for my 07 Impreza 2.5i and the lighting for the gauge needles isn't working everything else lights up.
DeathhGhost is offline   Reply With Quote
Old 05-20-2015, 03:45 PM   #769
koticone
Member#: 419673
well this might be my weekend project. the stock are way to dim
koticone is offline   Reply With Quote
Old 03-09-2016, 09:48 PM   #770
Lucien_Gauvin
Member#: 442228
2006 Subaru Sti
Grey
I'll have to give this a try this weekend, thanks for the write up
Lucien_Gauvin is offline   Reply With Quote
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 248 10-29-2013 11:47 AM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 07:02 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
changing Sti gauge cluster color Basshead STi Forum Archive 7 09-12-2003 03:08 PM
