Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 12-15-2004, 06:41 PM   #1
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Default ej20g build up.
hi all-
well i sold the old project. but the good thing is im starting a new one.
anyway i need your guys opinion.
the engine: 94 jdm wrx ej20g
heads: possibly verion 3,4 or 5
crank: i want to go with a bigger displacement so im trying to use the 96-98 2.5 crank.
Rods: what rods do i use????? ive read somewhere that axis make rods just for this application, right? or what else can i use???
pistons: still again clueless?? i dont want to spend the money on STI pistons when i can get something for cheaper. but does JE, Arias ect already make pistons for the ej20g? or am i gonna have to get specs and them have a set custom built.
im on a budget but i can afford a bit more here and there...but are sleeves out of my buget, how much are they?
also im looking to get roughy 400whp with supporting mods(not the question here)
the main question is what rod,piston,crank and head setup will be the best for what i want.
Thanks for looking
Rick
scoobydorift is offline   Reply With Quote
Old 12-16-2004, 04:04 PM   #2
phunkeeHomosapien
Member#: 56061
just buy civic internals and hopefully they will fit i guess
phunkeeHomosapien is offline   Reply With Quote
Old 12-16-2004, 06:10 PM   #3
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Originally Posted by scoobydorift
hi all-
Thanks for looking
Rick
It will be cheaper for you to get a usdm ej25 and start there. The rods are forged. J-E makes pistons for this motor. They also make pistons for the ej20 if you insist and they are about 400 bucks...not sure about the price of the 2.5s. 400 whp is a big order for a 2.0L piston...but it can be done.
For 400 whp, v7 or 8 heads, intake and ecu are what you need. The engine management that is out there is so much better for the later ecus....unless you are going stand-alone...not fun on a street car.
400whp and "on a budget" don't really mix <- stating the obvious
Good luck and keep us updated
_R
RickInLittleElm is offline   Reply With Quote
Old 12-16-2004, 08:09 PM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
im not looking for a 2.5liter semi closed deck short block for 1500 dollars when i can get a 2.0 fully closed deck long block for around 500 with everything needed for a swap including tranny ecu harness and turbo ect.. and i posted this hoping me with my decision of putting a 2.5 crank in a ej20g and what pistons rods to use ect..
but thanks for the input and i will keep everyone posted with pictures and progrees of this swap.
Rick
Old 12-17-2004, 11:51 AM   #5
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Wow! Everything for $500!?! Let me in on your source,please! I will jump into an older swap for that price...
_R
Old 12-17-2004, 01:29 PM   #6
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
lol...last one.. but if you bought it it needs a rebuild... but those were my plans anyway so it works out nicely. i may go get the engine today i will post pictures here shortly.
Rick
Old 12-17-2004, 01:31 PM   #7
phunkeeHomosapien
Member#: 56061
_R
I did
thanks again rick
Old 12-17-2004, 01:48 PM   #8
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
hi all-
Thanks for looking
Rick
Ok man this has already been done in Japan. First take this with a grain of salt Please. You would be better off going 2.5 or going 2.2 stroker. I can post a few Japanese mags for you if you like about the subject but to cut it short its expensive extremely and its not easy by any means due to the stroke of the crank. If you had to do it take the EJ20G block change the internals with a 2.2 or go AM forged 2.0 pistons and ver 7 heads. Again remember grain of salt
DuoMaxwell is offline   Reply With Quote
Old 12-17-2004, 02:03 PM   #9
phunkeeHomosapien
Member#: 56061
so is the answer yes or no to the question of finding benefits in using the 2.5 crank in this build?
Old 12-17-2004, 02:29 PM   #10
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
IMHO no don't do it, my reason is you can build a better motor for the same price and I do mean better. They did this idea he has and had to shave the heads of the pistons to make it work. It was cheap but the car didn't last long in the process and the number were anything but stunning!!!
Old 12-17-2004, 02:43 PM   #11
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Nice deal! $500!
jamesfacts is offline   Reply With Quote
Old 12-17-2004, 05:36 PM   #12
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
thanks for your input, but give me some ideas for a "better engine"... right now im in the what to do phase. i know what i want my final result to be, but i just need peoples opinion on how to get there. if worst come to worst and i dont get any real solid answers for teh 2.5 crank i will just got with 2.0 forged pistons and rods, and version 4 heads and maybe a slight over bore. and for what it is worth i will be running a apexi power fc.
keep the ideas coming guys im open to everything. and thanks for everyones input.
Rick
Old 12-17-2004, 09:56 PM   #13
JDM_Scobaru
Member#: 57809
Hmm...I might have to take notes on this.lol
JDM_Scobaru is offline   Reply With Quote
Old 12-17-2004, 10:09 PM   #14
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Ok lets put it like this
If you can get it cheap a EJ20G stroked to 2.2 can lay down the smack in a vary serious manner and I am not talking 400 that can be accomplished without stroking. The engine management you have is perfect and the heads will work fine. Though I would save up for some bigger cams (nice long flat tq curve). You problem would be a suitable turbo IMHO and I would leave the green out of the picture.
My Picks
EJ20G stroked 2.2
TD06-25G or HKS 3037
Bigger cams 256in 262ex
Headgasket gonna be like a 1.8 or a 2.0mm
Oh and the Apexi boost actuator for the Power FC to hold boost nice and long
Its expensive but building something like that will pale a 2.5 STi heavily modded!!!!!
Old 12-17-2004, 11:00 PM   #15
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
are you talking about the stroker kits from aftermarket companies(cant remember which ones)..arent they like 2200 dollars.. thanks for the info. post a link to the stroker kit please.
Rick
Old 12-18-2004, 05:16 AM   #16
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
scoobydorifto
I am gonna build my EJ20G now while you build yours. We will see if this works because I can get my hands on the Forrester 2.5 STi crank new for $500. I will use the EJ20G block but I will be using the EJ20G heads ported and polished with different cams!! As for the kit I have to do some research but they have a 2.2 kit that goes for like $1500 now. I will get back with you after I go to Autobacs tomorrow!!!
Reason:
I got a very nice Christmas gift from my Family and Friends back home.
Old 12-18-2004, 02:34 PM   #17
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
hey let me know on that stroker kit.
Old 12-18-2004, 09:46 PM   #18
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
well i went and picked up the engine today...pictures are soon to come(it was too dark to take any)
Rick
any more info on buildups would be great.
Old 12-19-2004, 07:27 PM   #19
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Default Pictures
Sorry if they are too big.
Rick
Old 12-19-2004, 08:21 PM   #20
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
oh sick red needle nose pliers...are those JDM? jk
snowman4us is offline   Reply With Quote
Old 12-26-2004, 03:09 PM   #21
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
more pics coming soon.
Old 12-30-2004, 10:30 PM   #22
Jelphree
Member#: 48316
Good luck with your project. It has sparked some interest. EJ20g fully closed deck. I wonder if I can find one in LA?
Jelphree is offline   Reply With Quote
Old 01-01-2005, 02:03 AM   #23
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Hey Toda makes a bore up kit the running price is $1500!!
Old 01-04-2005, 01:25 PM   #24
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Would the N/A EJ22 phase 1 crank stroke the EJ20G? or are they the same?
I ask because, I'm also working on getting an EJ20G in my car to replace the current ej22 n/a block
subachad is offline   Reply With Quote
EJ20g build ideas ThermosMcJug Pre-2002 Factory Turbo Powertrain 11 01-06-2010 02:08 PM
EJ20g Build globalrex Built Motor Discussion 9 02-28-2009 12:35 AM
ej20g build question kike_ej20 Built Motor Discussion 3 11-29-2007 03:59 AM
New Guy, ej20g build Shh!ItGoes11's Built Motor Discussion 1 11-06-2006 11:42 PM
ej20g build up scoobydorift Factory 2.0L Turbo Powertrain 12 12-19-2004 07:24 PM
