Old 12-31-2004, 01:31 AM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default version 4 vs. version 5
I know the version 4 is a phase 1 and version 5 is a phase 2, but other than that, are the drive trains very different? I just wonder if it would be regrettable to put a version 4 drivetrain into a 99RS instead of a version 5 or 6.
Lachlan is offline   Reply With Quote
Old 12-31-2004, 01:03 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
lets see
differnt injectors
different intercooler options
and you can't use ecutek on a ej20k.. ecutek does do ver 5 with flash 99 now finding a ecutek dealer in the us that has flash 99 is another question
Old 12-31-2004, 02:19 PM   #3
Kha0S
Member#: 8808
2011 WRX
DGM 5D
As far as I know, the transmission case designs are different as well.
As a data point, RalliSpec sells two different versions of STi and STi/RA gearsets... one set is v4, the other set is v7. The v4 gears are specific to pre-MY98 US cases, and v7 for those manufactured thereafter.
They changed a few dimensions, as well as some bearing styles, as far as I know.
/Andrew
edit: however, on the large scale (entire transmissions, motors, etc.), I believe that the parts are pretty compatible between the two versions.
Kha0S is offline   Reply With Quote
Old 01-03-2005, 02:24 PM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
/Andrew
Ver. 7's are 6 speeds. I assume you know this and meant Ver. 5+.
garface is offline   Reply With Quote
Version 4 vs Bird ScoobKing Tri-State Area Forum 12 11-19-2009 01:15 PM
Version 8 vs Version 9 STI JDM Suspensions StevieD Brakes, Steering & Suspension 29 02-18-2005 09:23 PM
GL-4 vs. GL-5 squeeze Transmission (AT/MT) & Driveline 41 10-31-2004 08:28 PM
Cusco front lower arm bar version 1 vs version 2 jay25RS Brakes, Steering & Suspension 14 03-15-2004 07:54 PM
TXS UTEC V.4 vs V.5 kschmohl Engine Management & Tuning 0 05-17-2003 01:28 AM
