Notices
Old 12-31-2004, 10:35 AM   #1
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Default Now putting the Axis 2.5 together-pics of mods
Thought I had a bad cylinder in #4. Low compression - 135psi
Turns out it was a bad exhaust valve. But I had the Axis,.. ej25,.. stage #2 in the back so it is going in.
Sent the heads out. There are putting in .05" St. Steel over sized exhaust valves.??
Am going to port the heads.
Doing the tumbler delete. Also notched out the bottom of the divider plate so the injectors have better flow
Have an FPgreen and a Turboxs fm ready. Vivid said the "turboxs and Perrin FMIC's were fairly equal"??? I'm not so sure.
unkadave is offline   Reply With Quote
Old 12-31-2004, 11:47 AM   #2
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Sweet. That's going to be a stout setup. I love my 2.35 block.
02R6 is offline   Reply With Quote
Old 12-31-2004, 11:50 AM   #3
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
02R6
Did you do the tumbler delete, etc., while you had things apart. Port & p. ?
Old 12-31-2004, 02:50 PM   #4
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Old 01-04-2005, 08:45 AM   #5
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Don't know whether to take the whole accuator bar out or not.
Old 01-06-2005, 11:21 AM   #6
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
FPgreen I think No real id on the ship statement.
Turboxs fm Not as nicely put together as the Perrin. Oh well.
....hope the turboxs can handle an FPgreen. Both from Vivid. I got great pricing
Old 01-06-2005, 11:30 AM   #7
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
Nice setup. Keep us informed on your progress.
mantra1 is offline   Reply With Quote
Old 01-06-2005, 12:53 PM   #8
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Nice motor. With those heads the Green is kinda small. That is a GT35 motor.
ebeck is offline   Reply With Quote
Old 01-06-2005, 01:07 PM   #9
Bailey
Member#: 12572
2004 STi
35R is enough
Looks like its comming together nicely dave.
When do you suspect you'll be ready for startup and some road tuning? ;-)
Tim
Bailey is offline   Reply With Quote
Old 01-06-2005, 01:09 PM   #10
Bailey
Member#: 12572
2004 STi
35R is enough
Who did the valve work? How much?? Same cams??
Bailey
Old 01-06-2005, 01:50 PM   #11
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Hi Tim
The valves are $22 x 8 exhaust valves. Southworth machined the face and are doing the valves - Probably $260 total.
Also thanks to
Eurosport Tuning in Eugene. And Tim (doctor) Bailey. at PDX, who is kind of overseeing the project.
Same cams, and Pete is going to do a mild p & p on the heads.
FP green to small??? I'm tired of the car eating itself as it is. This is it.
FPgreen is what is going in, no sense debating the point, here anyway.
Tips from others who have done this are welcome.
Old 01-06-2005, 02:21 PM   #12
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
I am not saying Green should not go in. Put it in! I am just saying that motor can take a much larger turbo. Compressor maps show that. Getting mighty close to Supra size motor there. Of course that does not mean you should put a bigger turbo in as you illustrate.
As far as eating itself, you have a valid point. However, I am not sure there is a stronger motor. It should survive fine. Drive line could be a problem though if that is what you are refering to.
Any projections on power? I have some. On 93 octane and a Dyno Jet, I bet 380whp at 20# boost but just an absurd amount to torque maybe 400+ ft# at the wheels.
Anyhow, Go Green! Nice project. Good luck and post some plots. I may follow you if my JDM bottom ever goes. I really look forward to seeing the outcome of this!
Old 01-06-2005, 03:21 PM   #13
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
thx ebeck
getting ready to cut out the bumper
Old 01-06-2005, 03:42 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
looks nice dave.
Old 01-07-2005, 01:44 AM   #15
02R6
Member#: 22157
'02 WRX '04 350Z
Originally Posted by unkadave
02R6
My apolgies for not replying sooner. Anyway, yes, I did the tumbler delete, but in the form of JDM STi RA-C housings - of which there are no tumblers whatsoever. No p&p for me, didn't have the money, will save that for another day. Went with JDM STi ver. 5/6 EJ207 cams, JDM STi RA valve springs and USDM STi shimless buckets.
Old 01-07-2005, 12:43 PM   #16
Bailey
Member#: 12572
2004 STi
35R is enough
Hey Dave,
That black FMIC looks awesome!
Tim
Old 01-07-2005, 12:56 PM   #17
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Thanks Tim
Note: It is the turboxs, I was told it was as good as the Perrin by the vendor. It does not look nearly as big, - / - or well built. Kyle down here has a Perrin FM, ..and we eyeballed them side by side so to speak.
As long as it holds up to the FPgreen it's OK.
Old 01-07-2005, 01:22 PM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Looking good.
Dude, your lights fell out.
jblaine is offline   Reply With Quote
Old 01-19-2005, 12:21 PM   #19
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Have the fmic in, putting a black screen in front of it, birds, etc.????
Hope the screen blends into the car.
Engine is waiting on valves. The heads are lightly ported. I will take some pics of the heads.
Old 01-19-2005, 07:04 PM   #20
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
what did you use to along the lines of making your intercooler black?
kharris4 is offline   Reply With Quote
Old 01-19-2005, 07:21 PM   #21
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
a fair sized topmount can handle an FPGreen. I'm hoping a JDM sti topmount will handle it.
Capt Crunch is offline   Reply With Quote
Old 01-19-2005, 08:11 PM   #22
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Depends on how hard you push the boost..... ambient temps, etc.
You're always better off with a FMIC IMO.... there's just much more cooling capacity and thats never a bad thing.
Greens will make power with a TMIC..... but they make more with a FMIC
Cheers
Bailey
PDXTuning is offline   Reply With Quote
Old 01-19-2005, 09:18 PM   #23
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
93.5 Single Supra :)
Cheers
Bailey
I think he has a point capt, you can't use a Green to its potential with a top mount
MomoWRX is offline   Reply With Quote
Old 01-20-2005, 06:07 PM   #24
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Would like to balance my clutch and fly wheel. Or ditch the ACT 13.8lb flywheel. Get miss fire CEL's
Old 01-30-2005, 09:27 PM   #25
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Shoot.
Putting a 1999 2.5 RS back together & need advice mrsdavis09 Newbies & FAQs 3 07-06-2009 11:01 AM
Now putting the Axis 2.5 together: extended / still no power unkadave Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-19-2005 11:04 PM
Crawford VS Axis 2.5 spoolinsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-21-2005 03:29 AM
Putting in an Axis 2.5 shortblock? Advise BriarRabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-13-2004 08:28 PM
